The Cat and Duck Method of Instrument Flying
Today's flight age is an era highlighted with increasing emphasis on safety. Instrumentation in the cockpit and in ATC has reached new heights of electronic perfection to assist the pilot during take-off's, flight and landing. For whimsical contrast to these and other marvels of scientific flight engineering, it is perhaps opportune to remind pilots of the basic rules concerning the so called Cat and Duck Method of Flight. Place a live cat on the cockpit floor. Because a cat ( when dropped ) always remains upright, he or she can be used in lieu of a needle and ball. Merely watch to see which way the cat leans to determine which wing is low. The duck is used for the instrument approach and landing. Because any sensible duck will refuse to fly in IMC conditions, it is only necessary to hurl you duck out of the aircraft, and follow it to the ground. There are some limitations to the Cat and Duck Method , but by rigidly adhering to the following check list, a fair degree of success will be achieved. · Get a wide-awake cat. Most cats do not want to stand up at all, at any time. It may be necessary to get a large fierce dog in the cockpit to keep the cat at attention. · Make sure that your cat is clean. Dirty cats will spend all their time washing. Trying to follow a cat licking itself usually results in a flick-roll, followed by a flat spin. You can see that this is very unsanitary. · Old cats are best. Young cats have nine lives, but an old used-up cat with only one life left has just as much to loose as you do, and will therefore be more dependable. · Beware of cowardly Ducks. If the duck discovers that you are using the cat to stay upright she will refuse to leave without the cat. Ducks are no better at instrument flying than you are! · Be sure that the duck has good eyesight. Near sighted ducks often go flogging off into the nearest hill. Very short sighted ducks will not realise that they have been thrown out and will descend to the ground in a sitting position. This manoeuvre is quite difficult to follow in an aeroplane. · Use a land loving duck. It is very discouraging to break cloud and find yourself on short finals for a Yorkshire village duck pond. Yorkshire farmers suffer from an insanity when chasing crows off their fields and will shoot anything that flies. · Choose your duck carefully. It is easy to confuse ducks with geese. Whilst geese are competent instrument fliers, they seldom wish to go in the sane direction as you. If your duck heads off for the nearest Wildfowl Trust, you may be sure that you have been "given the goose". |
"Richard Bennett" wrote in message
... The Cat and Duck Method of Instrument Flying snip Richard............. Google show this thread has been posted at least 40 times, though it is funny. Remember - your search button is your friend. Regards, Rich S. |
It is also possible to use a cat as an emergency alternator/generator. It is a
well known fact that a cat will always land feet-down. It is also true that a piece of buttered bread will land butter side down. Simply strap a piece of buttered bread to the cat's back, put a couple of magnets on the sides of the straps, and drop the cat into the center of a coil of wire. Viola, spinning cat-bread generates a voltage. Jim "Richard Bennett" shared these priceless pearls of wisdom: -The Cat and Duck Method of Instrument Flying - Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
On Fri, 05 Nov 2004 10:58:34 -0800, Jim Weir wrote:
It is also possible to use a cat as an emergency alternator/generator. It is a well known fact that a cat will always land feet-down. It is also true that a piece of buttered bread will land butter side down. Simply strap a piece of buttered bread to the cat's back, put a couple of magnets on the sides of the straps, and drop the cat into the center of a coil of wire. Viola, spinning cat-bread generates a voltage. Jim ++++++++++++++++++++++++++++++++++ Viola 1. A stringed instrument of the violin family, slightly larger than a violin, tuned a fifth lower, and having a deeper, more sonorous tone. 2. An organ stop usually of eight-foot or four-foot pitch yielding stringlike tones. -------------- Voila Used to call attention to or express satisfaction with a thing shown or accomplished Barnyard BOb - old phart ballbuster and pain in the ass g |
Barnyard BOb - wrote:
On Fri, 05 Nov 2004 10:58:34 -0800, Jim Weir wrote: It is also possible to use a cat as an emergency alternator/generator. It is a well known fact that a cat will always land feet-down. It is also true that a piece of buttered bread will land butter side down. Simply strap a piece of buttered bread to the cat's back, put a couple of magnets on the sides of the straps, and drop the cat into the center of a coil of wire. Viola, spinning cat-bread generates a voltage. Jim ++++++++++++++++++++++++++++++++++ Viola 1. A stringed instrument of the violin family, slightly larger than a violin, tuned a fifth lower, and having a deeper, more sonorous tone. 2. An organ stop usually of eight-foot or four-foot pitch yielding stringlike tones. -------------- Voila Used to call attention to or express satisfaction with a thing shown or accomplished Barnyard BOb - old phart ballbuster and pain in the ass g CatGut may also be used for Viola strings. Dick |
Dick Steel
shared these priceless pearls of wisdom: Jesus, I know the difference between viola and voila (grave missing from my character set). Can't you let a humorous intentional misspelling slide by? Do I have to put a funny face (I'd like one for up-yours, but it hasn't been invented yet -- how about oo|oo ) by all my little peccadillos? Sheesh. Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
On Fri, 05 Nov 2004 19:36:06 -0800, Jim Weir wrote:
Dick Steel shared these priceless pearls of wisdom: Jesus, I know the difference between viola and voila (grave missing from my character set). Can't you let a humorous intentional misspelling slide by? Do I have to put a funny face (I'd like one for up-yours, but it hasn't been invented yet -- how about oo|oo ) by all my little peccadillos? Sheesh. Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com What are you going to do? He's our resident pedantic ass! |
"Rich S." wrote in message ...
"Richard Bennett" wrote in message ... The Cat and Duck Method of Instrument Flying snip Google show this thread has been posted at least 40 times, though it is funny. Remember - your search button is your friend. I'd not seen it, so I'm guessing others had not as well. It's it's unlikely I'd have stumbled across it by searching randomly. So while I can see why you'd point out to search first if someone posts a question that had been asked before, I don't believe that applies to humor. Rich |
Richard Bennett wrote: The Cat and Duck Method of Instrument Flying Here is the Duck method taken a step further.. http://centercomp.com/cgi-bin/dc3/gallery?14511 Dave |
Jim --------------------------------------------- Dear Jim, You've confused the the aviation term with the French word. The proper spelling is 'wah-la' even though it is pronounced the same: 'Vie OH la' (preferrably with a Texas twang) -R.S.Hoover |
| Thread Tools | |
| Display Modes | |
