John Galloway wrote:
Further to my posting yesterday I have identified the 6 point harness in our Std Cirrus as as Luke PRO6F designed for single seat race cars. See: http://www.lukeracing.co.uk/rec.php?cat=17 Flying with it today was the most comfortable I have ever been in a glider as I felt totally secured with the lap strap held low and no tendency to slide forward in the seat pan with the lap strap rising as happens in so many gliders. Even a deep seat pan like the front seat of a Duo comes nowhere near in terms to achieving that feeling. It may be non approved but I really don't care as the benefits for comfort and safety are so clear cut. John Galloway Could you double check and repost the URL. I am getting a blank page when I try to load the page. Thank-you. |
At 18:12 07 June 2004, Jc Cunningham wrote:
John Galloway wrote: Further to my posting yesterday I have identified the 6 point harness in our Std Cirrus as as Luke PRO6F designed for single seat race cars. See: http://www.lukeracing.co.uk/rec.php?cat=17 Flying with it today was the most comfortable I have ever been in a glider as I felt totally secured with the lap strap held low and no tendency to slide forward in the seat pan with the lap strap rising as happens in so many gliders. Even a deep seat pan like the front seat of a Duo comes nowhere near in terms to achieving that feeling. It may be non approved but I really don't care as the benefits for comfort and safety are so clear cut. John Galloway Could you double check and repost the URL. I am getting a blank page when I try to load the page. Thank-you. Thats odd because when I click on the link in your reply I go straight to it. If all else fails go to www.lukeracing.co.uk main site and click on the main link for 'race and rally safety harnesses' and then on 'Recommended' it will take to the page with a list of their harnesses. At the bottom is the link for PRO6F which looks identical to what is in our Std Cirrus except that instead of the bolt clips at the aircraft attachment end of the lap and shoulder straps we have normal glider buckles. Also the attachment points of the 2 thigh straps under our seat pan is a flat hook/clip instead of the bolt clip. Our central quick release buckle also looks to be an older less sleek model (our straps must be 12 years old but hardly used). Otherwise the picture gives a good idea of how the straps work - except that in practice the upper ends of the thigh loops pull at the lowest point of the shoulder straps and not a few inches higher as shown in the non-tensioned photographs. BTW it would be more difficult to attach the straps to a glider in which the lap straps attach to the seat pan rather than - as in the Std Cirrus - to a fuselage mounted metal point with a hole in the seat pan. This allows access to the mounting point for the lap straps from above the seat pan and for the thigh straps from beneath the seat pan. In other gliders I would envisage extra mounting points being required forward on the seat pan - perhaps bonded to the bottom of the seat pan under the upper thighs. John Galloway |
There are quite a few 6 point harness suppliers in the UK. Just google '6
point harness' Best price I found on the Luke 6 point PRO6F was £103 including VAT and shipping from www.rallynuts.com Ian |
At 18:12 07 June 2004, Jc Cunningham wrote: John Galloway wrote: Further to my posting yesterday I have identified the 6 point harness in our Std Cirrus as as Luke PRO6F designed for single seat race cars. See: http://www.lukeracing.co.uk/rec.php?cat=17 Flying with it today was the most comfortable I have ever been in a glider as I felt totally secured with the lap strap held low and no tendency to slide forward in the seat pan with the lap strap rising as happens in so many gliders. Even a deep seat pan like the front seat of a Duo comes nowhere near in terms to achieving that feeling. It may be non approved but I really don't care as the benefits for comfort and safety are so clear cut. John Galloway Could you double check and repost the URL. I am getting a blank page when I try to load the page. Thank-you. Thats odd because when I click on the link in your reply I go straight to it. If all else fails go to www.lukeracing.co.uk main site and click on the main link for 'race and rally safety harnesses' and then on 'Recommended' it will take to the page with a list of their harnesses. At the bottom is the link for PRO6F which looks identical to what is in our Std Cirrus except that instead of the bolt clips at the aircraft attachment end of the lap and shoulder straps we have normal glider buckles. Also the attachment points of the 2 thigh straps under our seat pan is a flat hook/clip instead of the bolt clip. Our central quick release buckle also looks to be an older less sleek model (our straps must be 12 years old but hardly used). Otherwise the picture gives a good idea of how the straps work - except that in practice the upper ends of the thigh loops pull at the lowest point of the shoulder straps and not a few inches higher as shown in the non-tensioned photographs. BTW it would be more difficult to attach the straps to a glider in which the lap straps attach to the seat pan rather than - as in the Std Cirrus - to a fuselage mounted metal point with a hole in the seat pan. This allows access to the mounting point for the lap straps from above the seat pan and for the thigh straps from beneath the seat pan. In other gliders I would envisage extra mounting points being required forward on the seat pan - perhaps bonded to the bottom of the seat pan under the upper thighs. John Galloway It must have been my browser that was having a problem. I use Opera. When I used internet explorer it came up fine. |
![]() "Ed Byars" wrote a good piece on belting yourself in. Before you just go and install marginal belts, look at what is available in the sports car world and choose the correct parts. Crotch belts or "5 point harnesses" were developed for upright seated positions. They worked by holding the lap belt in the proper position over the hips and weren't designed to take impact loads without "stuffing your balls through your throat". As cars became faster and aero considerations moved drivers to the supine driving positions used today, "6 point systems" evolved. The load path in grontal impacts could no longer be absorbed by the lap and shoulder belts because the vectors were wrong. What has evolved is a belting method that creates a web seat secured to the lap belt attach points. This prevents the driver from sliding forward out from under the belting system. My SCHROTH harness hooks up like this. Connect lap belt. left 6 point go's under my leg, around my upper thigh, over to the left lap belt anchor, thru a loop and back to the buckle. Same for right side connect shoulders done. What this does is transfer any decelleration loads into the upper thigh/lower butt area and is quite comfortable. It virtually eliminates soft tissue bruising .. I would not fly a 5 point harness as I feel they are unsafe, the risk of internal injuries to the soft stuff is too high. BUT the 6 point harness works very very well. I have had the unfortunate "experience" of stuffing a formula car and know exactly what works, and what doesn't. I don't have good pictures, but looking at the WILLANS web site gets the message across. Look at the way all the sub straps create seats to support you against sliding forward. http://www.willansharness.com/ Scott Correa |
The 'crotch strap' is what used to be known as a 'negative-G'
strap. Usually it works to keep your skull away from the canopy during the bumpy bits of sky; rarely, it helps you in a crash by preventing submarining. However, a single strap is both inconvenient and potentially painful. A better design is a double strap, like an inverted V, but it needs two hard points. Another variation is an upright V, with one hardpoint and some secure way to fasten the ends of the V to the lapstraps rather than the buckle. The conventional 4-point or 5-point harness shows its ancestry from the lapstrap by having the primary mounting [the buckle] on the lapstrap. Would a better design not have the buckle assembly permanently mounted to the [adjustable] negative-G strap and the two lap and two shoulder straps plugging in later ? Ian At 15:00 06 June 2004, Bill Daniels wrote: 'Robertmudd1u' wrote in message ... You may be interested in my latest crotch strap experience. I'm still analyzing my June 2003 accident and the cause. More later on this. The role of the crotch strap is significant and worthy of mention. Dr. Byars, thank you for this interesting and important feedback based on real world experience. The standard line from the German manufactures is that a crotch strap is not needed because the submarining hazard has been taken care of through use of the 'H point' when locating the anchoring point of the lap belts. This system locates the lap belt a bit further forward than in older designs with the aim being to get the lap belt lower on your hips. This is supposed to prevent it from being pulled out of place when tightening the shoulder harness. It does, but I believe the lap belt has to be tightened to an un-necessary degree to get anywhere near the effect the 'H point' is credited with bringing about. My experience is that the 'H point' is not adequate to keep the lap belt from being pulled up when tightening the shoulder straps. This is especially true when flying out west in strong lift at high speed. A crotch strap helps keep you from bouncing around thus providing more comfort and better control. The difference is security in the cockpit is dramatic. I normally retro fit a crotch strap to my gliders and feel a lot safer and more comfortable with its use. This holds true even with my Genesis which used the 'H point' system to locate the lap belt anchor points. Robert Mudd After reading Ed and Robert's posts, I intend to install a crotch strap in my Nimbus. At the very least, it will let me get the shoulder straps REALLY tight without pulling the lap belt up too high. When you are riding 10 - 15 knot mountain thermals with a stiff carbon wing you just can't be strapped in too tight. Bill Daniels |
On 6 Jun 2004 16:55:50 GMT, Ian Cant
wrote: The 'crotch strap' is what used to be known as a 'negative-G' strap. Usually it works to keep your skull away from the canopy during the bumpy bits of sky; rarely, it helps you in a crash by preventing submarining. However, a single strap is both inconvenient and potentially painful. A better design is a double strap, like an inverted V, but it needs two hard points. Another variation is an upright V, with one hardpoint and some secure way to fasten the ends of the V to the lapstraps rather than the buckle. I followed the link to Willans Harnesses in "plastic guy's" post and moused round the site a little. They supply a Y-strap that's designed to connect to the 5th slot on their quick release fitting, passes under your legs and attaches to the lap strap hard points. They say its designed to upgrade their 4-point racing car harnesses to 6-point standard. This looks potentially like a quick and easy way to upgrade a 4-point harness because it requires no extra hard points in the glider. Presumably the lap strap hard points are already designed to take the full deceleration loads in a crash so fitting it would not put additional loads on them. Does anybody on here know if this upgrade has been done? If so, how does it compare with a traditional 5-point system with regard to anti-submarining and negative-G properties? Are our 5-point rotary action quick-release units the same as the car racing gang use? -- martin@ : Martin Gregorie gregorie : Harlow, UK demon : co : Zappa fan & glider pilot uk : |
Dale Thompson and I had an inverted V crotch strap in our 1-35. It served to
keep the lap belt in position. More important was the assurance that the legs and hips would probably take the stress instead of other more "important" parts that could not be so easily repaired. Fortunately, we never had a test of its effectiveness. The design is very simple and easily made. Our was made by Alan Silver, in the San Francisco bay area, who repacked our chute. I do not think he is still in business. "Martin Gregorie" wrote in message ... On 6 Jun 2004 16:55:50 GMT, Ian Cant wrote: The 'crotch strap' is what used to be known as a 'negative-G' strap. Usually it works to keep your skull away from the canopy during the bumpy bits of sky; rarely, it helps you in a crash by preventing submarining. However, a single strap is both inconvenient and potentially painful. A better design is a double strap, like an inverted V, but it needs two hard points. Another variation is an upright V, with one hardpoint and some secure way to fasten the ends of the V to the lapstraps rather than the buckle. I followed the link to Willans Harnesses in "plastic guy's" post and moused round the site a little. They supply a Y-strap that's designed to connect to the 5th slot on their quick release fitting, passes under your legs and attaches to the lap strap hard points. They say its designed to upgrade their 4-point racing car harnesses to 6-point standard. This looks potentially like a quick and easy way to upgrade a 4-point harness because it requires no extra hard points in the glider. Presumably the lap strap hard points are already designed to take the full deceleration loads in a crash so fitting it would not put additional loads on them. Does anybody on here know if this upgrade has been done? If so, how does it compare with a traditional 5-point system with regard to anti-submarining and negative-G properties? Are our 5-point rotary action quick-release units the same as the car racing gang use? -- martin@ : Martin Gregorie gregorie : Harlow, UK demon : co : Zappa fan & glider pilot uk : |
Alan Silver is very much still in business. See http://www.pia.com/silver/
-Bob Korves LAK-17a "5K DuoDiscus "5H" "Dusty" wrote in message m... Dale Thompson and I had an inverted V crotch strap in our 1-35. It served to keep the lap belt in position. More important was the assurance that the legs and hips would probably take the stress instead of other more "important" parts that could not be so easily repaired. Fortunately, we never had a test of its effectiveness. The design is very simple and easily made. Our was made by Alan Silver, in the San Francisco bay area, who repacked our chute. I do not think he is still in business. |
On Sunday, June 6, 2004 9:26:17 PM UTC-5, Bob Korves wrote:
Alan Silver is very much still in business. See http://www.pia.com/silver/ That pia URL seems faulty. I have the following URL for Allen Silver's 5 point harness and you can order the crotch strap as a separate item. http://silverparachutes.com/acrobelt/ BTW: We had Allen as a speaker at the ChicagoLand Glider Council's bi-annual conference and he was GREAT. http://silverparachutes.com/safety-seminars/ - John |
eScrew zen story | [email protected] | Owning | 0 | December 20th 04 07:19 AM |
Funny story about naval | [email protected] | Naval Aviation | 0 | December 20th 04 03:37 AM |
Funny story about piloting | [email protected] | Piloting | 0 | December 20th 04 12:34 AM |
Amazing, True Story and Lessons | jsmith | Piloting | 5 | March 24th 04 03:32 PM |
PFC Lynch gets a Bronze Star? | Brian | Military Aviation | 77 | August 2nd 03 11:15 AM |
