I'm no bird expert, but did 20 years competing hang
gliding around the world, before really getting into gliding. Hang gliders mixed with (soaring) birds far more than sailplanes. Probably a performance thing. The birds seem to do different things depending upon the task at hand. IE: want to gain height quick - they'll be in the best core or thermal within the vicinity. Want to go somewhere- they'll be heading towards the next thermal that optimises their route. Want to 'hang out' they'll be in any old lift. I witnessed the whole USA hang gliding team joining a flock of circling Orubu in Brazil. They all landed next to the dead cow. Larger raptors can be more territorial and therefore don't have the same choice on area, thus might put up with inferior lift. Storks just seem to follow the leader. Swifts and Swallows are almost always in good cores, but I haven't a clue how they transit between thermals so quickly. The soaring birds not only find the best cores, but seem to very quickly know where the next thermal is. Many times I've watched their transiting direction - always dead straight - and altered my course to intercept or get ahead. It usually works. When we fly a lot, we pick up those extra sensory inputs - the micro turbulence, the twitch of the wing - it gives us huge amounts of info if we're open to it. By the end of the soaring season, I've sometimes just known where the core was by feel - which way to turn, etc. I don't know how - just intuitive. Birds fly all the time, so should be totally tuned in. Lastly, I'm sure they plot sink. We tend to focus on lift, whereas, of course, it's just a part of the equation. If you know where the sink is, then happy days, avoid it! Pete Harvey A falconer at the Parowan regionals last week told us that soaring birds have sensory organs that are able to measure the pressure differential between the outside air and inside their hollow bones. I have not been able to confirm this, but it would seem to make sense - think of the bones as capacity bottles. Any bird experts out there? |
Take a look at Darryl Stinton's book "The design of the aeroplane" - there
is a captioned picture in the front of it showing a gull (an Albatross, I think) soaring a cliff in front of the camera. The caption points out aerodynamic function of various parts of the birds anatomy in a most enlightening manner! I don't have the book in my possession right now (I loaned it to the CFI of a local club, I should get it back I suppose) or I would post the picture and it's caption. Rgds, Derrick Steed On 4 Jul 2004 20:39:04 GMT, Andy Blackburn wrote: Any bird experts out there? While still in India I met a German lass who was an ornithologist and in India do a PhD on vultures. Naturally, I asked her about their flight performance. She just looked at me like I was a dinosaur: she knew nothing and cared less about their flight performance or operating methods. All she was interested in was stuff like population densities, diet and their behaviour when not flying. I found her attitude most odd. That was 25 years ago so things, hopefully, might have improved in ornithological circles. So, pick your bird expert carefully before asking about how birds fly. BTW, a good book about flight in general (literally from insects to 747s) is 'The Simple Science Of Flight' by Henk Tennekes. It won't tell you how raptors find lift but has a good analysis of how flying creatures size and weight affect their way of making a living and vice versa. Besides, any book on flight that can sensibly show everything from a Monarch Butterfly to a 747-400 on the same graph can't be all bad! |
WinPilot and Mobile SeeYou already do this to a very
great extent by plotting out the flight path with climb rate indicated on the moving map display. I have used this to return to thermals going in and out of turnpoints to good effect. They are not fast enough to really be helpful in coring except over many turns, and even then it's hard to stay oriented between the glider, the display and the ground reference. WP Pro also has a 'climb optimizer' that assumes your are flying in a more-or-less circular path - it works pretty well in my experience and can help the pilot divert attention to other tasks while climbing. I'm not sure you really need the strain guages to do this as you already can measure rate of climb directly, either through differential altitude readings from the GPS, or more precisely through the TE pressure system. I believe the CAI 302 also has an accelerometer built in, so if you want to use acceleration you can get it directly rather than having to derive it from wing strain. 9B At 14:48 09 July 2004, Ventus45 wrote: And so could we, if we installed strain gauges along the spars, say at 5 foot intervals, and connected them up to a minicomputer which read them, add an accelerometer, a standard netto vario setup, a gps, and some fancy software, and we should be able to create a computer display that will be able to produce a PPI 'map' display of a thermal as we turn, gradually building up the data, plotting 'lift' like contour lines on a map, so we could soon see where the 'core' was, and centre accordingly. A good research/thesis project for some bright spark at university. Any takers ? |
Yes, but could you hear their varios beep?
Derrick Steed wrote in message ... It's a well known fact that birds bones are very light and filled with holes, just like we have sinuses in our head bones. I've pondered how birds might sense rate of climb many times and I now hold the view that they sense it via the cavities in their bones - this would provide them with a very sensitive variometer, the capacity being automatically incorporated so to speak. I'm also convinced that birds soar for pleasure as well as because they might have to (e.g. Pelicans soar when they are migrating and follow similar climb/glide patterns to us). I once observed a seagull from the restaurant at the top of the OMPI building in Geneva - a seagull was already soaring near the ITU building when suddenly another shot past the window in a fast glide headed straight for a point below the other seagull, when it got there it pulled up into the climb underneath the other gull turning in the same direction. Obviously his/her CSI (Chief Seagull Instructor) had made the point about proper thermal entry. Rgds, Derrick Steed Does anyone have an idea of how the birds know where to thermal? Do they have a vario? Where is it? Where is its capacity? Assuming they breath while thermalling, then I doubt they use their lungs as capacity... or maybe they stop and sense the air coming out their noses. Just wondering... Uri 4XGJC (Andy Durbin) wrote in message news:... "Bill Daniels" wrote in message news:... Most hawks circling low are looking for rodents, not lift. Bill Daniels But many times I have shared thermals with Hawks at high altitude. How did they get there if not by working thermals at low altitude? I have never been in a thermal with a Red Tailed Hawk that didn't seem to be trying to optimize climb rate. Turkey Vultures are a different story. They seem to be happy with any sloppy thermal technique as long as they maintain altitude. Andy |
It's pretty well established that soaring birds have extremely good
eyesight. I think they just see the ground moving away when they are climbing. Thermals also have a lot of stuff in them like insects and seeds. The birds are probably able to see these rising at a considerable distance There's a lot of visual cues while thermalling. If you are trying to thermal near a mountain peak it's easy to see the glider rise at the onset of lift. The varios will signal lift two or three seconds later. BTW, that story about the USA hang glider team chasing buzzards and landing next to a dead cow is really funny. Bill Daniels "Derrick Steed" wrote in message ... It's a well known fact that birds bones are very light and filled with holes, just like we have sinuses in our head bones. I've pondered how birds might sense rate of climb many times and I now hold the view that they sense it via the cavities in their bones - this would provide them with a very sensitive variometer, the capacity being automatically incorporated so to speak. I'm also convinced that birds soar for pleasure as well as because they might have to (e.g. Pelicans soar when they are migrating and follow similar climb/glide patterns to us). I once observed a seagull from the restaurant at the top of the OMPI building in Geneva - a seagull was already soaring near the ITU building when suddenly another shot past the window in a fast glide headed straight for a point below the other seagull, when it got there it pulled up into the climb underneath the other gull turning in the same direction. Obviously his/her CSI (Chief Seagull Instructor) had made the point about proper thermal entry. Rgds, Derrick Steed Does anyone have an idea of how the birds know where to thermal? Do they have a vario? Where is it? Where is its capacity? Assuming they breath while thermalling, then I doubt they use their lungs as capacity... or maybe they stop and sense the air coming out their noses. Just wondering... Uri 4XGJC (Andy Durbin) wrote in message news:... "Bill Daniels" wrote in message news:... Most hawks circling low are looking for rodents, not lift. Bill Daniels But many times I have shared thermals with Hawks at high altitude. How did they get there if not by working thermals at low altitude? I have never been in a thermal with a Red Tailed Hawk that didn't seem to be trying to optimize climb rate. Turkey Vultures are a different story. They seem to be happy with any sloppy thermal technique as long as they maintain altitude. Andy |
Bill Daniels wrote:
It's pretty well established that soaring birds have extremely good eyesight. I think they just see the ground moving away when they are climbing. Good eyesight is one thing, precision at judging distance another, the latter basically dependent on how far apart your eyes are. No way can they judge their climb rate based on seeing the ground moving away. Thermals also have a lot of stuff in them like insects and seeds. The birds are probably able to see these rising at a considerable distance That could be, and other visual cues as well. CV |
C'mon, now. Binocular depth perception ends for humans at about 20 feet and
is only really useful up to arms length, yet we can still judge distance well. Since the bird is moving, they can use dynamic field depth perception that has nothing to do with interocular distance. Close one eye and move your head back and forth or up and down. You will see what I mean. Birds and other small animals are observed to move their heads constantly to better judge distances. Ever ride one of those glass elevators (lifts) on the outside of a tall building? Did you notice how powerful the impression of climbing is? I still claim that they can see themselves rise away from the ground. Excellent vision and the experience to use it to the fullest is the likely explanation. It's the simplest explanation and requires no internal vario. Bill Daniels "CV" wrote in message news ![]() Bill Daniels wrote: It's pretty well established that soaring birds have extremely good eyesight. I think they just see the ground moving away when they are climbing. Good eyesight is one thing, precision at judging distance another, the latter basically dependent on how far apart your eyes are. No way can they judge their climb rate based on seeing the ground moving away. Thermals also have a lot of stuff in them like insects and seeds. The birds are probably able to see these rising at a considerable distance That could be, and other visual cues as well. CV |
Bill Daniels wrote:
C'mon, now. Binocular depth perception ends for humans at about 20 feet and is only really useful up to arms length, yet we can still judge distance well. Since the bird is moving, they can use dynamic field depth perception that has nothing to do with interocular distance. Close one eye and move your head back and forth or up and down. You will see what I mean. Birds and other small animals are observed to move their heads constantly to better judge distances. Ever ride one of those glass elevators (lifts) on the outside of a tall building? Did you notice how powerful the impression of climbing is? I still claim that they can see themselves rise away from the ground. Excellent vision and the experience to use it to the fullest is the likely explanation. It's the simplest explanation and requires no internal vario. I can't believe that, except for very low heights. The elevator experience you mention mention is for such heights, or at least when something (the building itself) is very near. The best processing system (e.g. the bird's brain) cannot infer anything from missing or non significative input. In the case of climbing, the only information on which you say they rely is the change in the apparent size of ground features. I didn't do the computation, but I bet that the change during one full turn is below the optical resolution of a bird's eye. In this domain, we are better equiped than they are, our eyes are larger. Nevertheless we can't decide if a glider or a bird is climbing when watching them from below just by watching the change of their size during a short time, except when they are very low. However I agree that after watching a bird for a long time, as it changed from a beautiful thing with discernable separate feathers at the tips to a vanishing little point in the sky, I can say that it was climbing. |
In article , Robert Ehrlich
I can't believe that, except for very low heights. The elevator experience you mention mention is for such heights, or at least when something (the building itself) is very near. The best processing system (e.g. the bird's brain) cannot infer anything from missing or non significative input. In the case of climbing, the only information on which you say they rely is the change in the apparent size of ground features. I didn't do the computation, but I bet that the change during one full turn is below the optical resolution of a bird's eye. In this domain, we are better equiped than they are, our eyes are larger. On the other hand, do you think you'd be able to spot a mouse from 3000ft? No problem for some birds of prey. -- Mike Lindsay |
Changes in Instrument Proficiency Check Requirements | Richard Kaplan | Instrument Flight Rules | 71 | June 10th 04 08:02 PM |
Kerry begins circling the drain: | Tarver Engineering | Military Aviation | 0 | February 12th 04 06:04 PM |
What determines LNAV "circling mode"? | Jack | Soaring | 11 | November 20th 03 05:15 AM |
Circling To Land On NDB-B and NDB-C | S. Ramirez | Instrument Flight Rules | 7 | July 13th 03 03:46 PM |
