I can recall spending many a late night out there re-rigging the control
surfaces on the Prowler (Navy EA-6B) when I worked in Quality Assurance. The Airframes guys would make an adjustment and we'd have to witness the 'throws' to ensure all was within specs. That dam Hydraulic Genny was screaming and the hydraulics were whining- It's no wonder I lost most of my hearing. All that 'so we could 'make the flight schedule'. Now it's somebody else's turn to 'wrench on those jets'. Larry AECS (AW/SW/MTS) USN 'Retired' 20 years if gettin 'em off the pointy end AND safely home again! You QA guys get that "partial ejection" incident in an A-6 figgered out? :-)) Warren, |
Warren,
Here is the complete story: http://www.gallagher.com/ejection_seat/ My person recollection of the story was a bit fuzzy. Wayne (A-6 Bombardier that has logged more takeoffs then landings.) "Whunicut" wrote in message ... I can recall spending many a late night out there re-rigging the control surfaces on the Prowler (Navy EA-6B) when I worked in Quality Assurance. The Airframes guys would make an adjustment and we'd have to witness the 'throws' to ensure all was within specs. That dam Hydraulic Genny was screaming and the hydraulics were whining- It's no wonder I lost most of my hearing. All that 'so we could 'make the flight schedule'. Now it's somebody else's turn to 'wrench on those jets'. Larry AECS (AW/SW/MTS) USN 'Retired' 20 years if gettin 'em off the pointy end AND safely home again! You QA guys get that "partial ejection" incident in an A-6 figgered out? :-)) Warren, |
![]() "Whunicut" wrote in message ... I can recall spending many a late night out there re-rigging the control surfaces on the Prowler (Navy EA-6B) when I worked in Quality Assurance. The Airframes guys would make an adjustment and we'd have to witness the 'throws' to ensure all was within specs. That dam Hydraulic Genny was screaming and the hydraulics were whining- It's no wonder I lost most of my hearing. All that 'so we could 'make the flight schedule'. Now it's somebody else's turn to 'wrench on those jets'. Larry AECS (AW/SW/MTS) USN 'Retired' 20 years if gettin 'em off the pointy end AND safely home again! You QA guys get that "partial ejection" incident in an A-6 figgered out? :-)) Warren, I don't recall that particular one, but the Safety Stand-Downs we attended ALWAYS had some real "what were they thinking" stories that always had a 'messy ending'. Sometime it was a movie, sometime just still photos (of the aftermath), and sometimes just a long message (even a very 'dry' story in message format can paint an accurate picture). I recall one similar to what you've described Warren, where somebody (some stupid maintenance guy) ejected into the hangar overhead. A lot of my co-workers used to just climb in and out without checking the pins- I ALWAYS checked the seat pins. I respect the power of those rocket motors and did not want to see first-hand what they can do. Larry AECS (AW/SW/MTS) USN 'Retired' 20 years if gettin 'em off the pointy end AND safely home again! |
I just don't get it. Can anyone successfully explain how flaperons
work? Are they better or worse than seperate flaps? What are the pro's and con's? It seems to me if one fails you have no recovery. Lou Lou, I have flown several gliders with flaperons but no airplanes so equipped. The glider I have the most time in is the Apis 13, this has a wing span of 13 meters about 42.5 ft. The roll rate is great because the entire trailing edge acts as a aileron, and the flaps really work well because they are the full span of the trailing edge, so independently I get very good results for these controls. When thermaling with a notch or two of flap I see little if any reduction in roll rate, Yes the aileron that is going up does not go as far up as if the flaps were at the zero setting, but it does not seem to matter. Bill Daniels mentioned his glider, which has a 20 meter wing, that is quite heavy. It has, (for a glider) a relatively slow roll rate anyway. The Apis is much lighter and nimble and so roll control with full flaps is just fine, in fact they make the glider a real blast to fly. The mechanism is quite simple. Each flaperon is driven from its root end by a torque rod, the flaperons are center hinged. The flaperons on the Apis are of carbon fiber so torque loads are easily handled. If you are near a glider club look at a DG brand glider, they use flaperons a lot in their gliders. I do not know if they are more effective than separate flaps and ailerons but they do cover a larger part of the wing's trailing edge so in some or maybe even most circumstances I think they maybe more effective. So far I have had no reason to complain. Robert Mudd |
![]() "Robertmudd1u" wrote in message ... I just don't get it. Can anyone successfully explain how flaperons work? Are they better or worse than seperate flaps? What are the pro's and con's? It seems to me if one fails you have no recovery. Lou Lou, I have flown several gliders with flaperons but no airplanes so equipped. The glider I have the most time in is the Apis 13, this has a wing span of 13 meters about 42.5 ft. The roll rate is great because the entire trailing edge acts as a aileron, and the flaps really work well because they are the full span of the trailing edge, so independently I get very good results for these controls. When thermaling with a notch or two of flap I see little if any reduction in roll rate, Yes the aileron that is going up does not go as far up as if the flaps were at the zero setting, but it does not seem to matter. Bill Daniels mentioned his glider, which has a 20 meter wing, that is quite heavy. It has, (for a glider) a relatively slow roll rate anyway. The Apis is much lighter and nimble and so roll control with full flaps is just fine, in fact they make the glider a real blast to fly. The mechanism is quite simple. Each flaperon is driven from its root end by a torque rod, the flaperons are center hinged. The flaperons on the Apis are of carbon fiber so torque loads are easily handled. If you are near a glider club look at a DG brand glider, they use flaperons a lot in their gliders. I do not know if they are more effective than separate flaps and ailerons but they do cover a larger part of the wing's trailing edge so in some or maybe even most circumstances I think they maybe more effective. So far I have had no reason to complain. Robert Mudd Yup, and that 20 meter wing gets a lot heavier when I put 75 gallons of water in it. (H2O - the go-fast juice). Bill Daniels Bill Daniels |
"Lou Parker" wrote in message
om... I just don't get it. Can anyone successfully explain how flaperons work? Are they better or worse than seperate flaps? What are the pro's and con's? It seems to me if one fails you have no recovery. Lou I'll try ;-) Flaperons are control surfaces that look like full span ailerons. They work both as ailerons (i.e. move in opposite directions when the stick is moved) and as flaps (i.e. move in the same direction when the flap handle is moved). There is a mechanical "mixer" device connected to the stick and flap handle that transmits the movement to the control surfaces so that they move as described above. The advantage, in theory, is that you can have effective, full span ailerons at the same time with effective full span flaps that can bring the stall speed down. To get the same effect with conventional control surfaces, the flaps need to be of more exotic design such as the split or Fowler type flaps. The main disadvantage is that when the flaps are in use you get an increased adverse yaw moment, which may make steering more difficult during approach. Also, as the flap deflection angle is limited compared to conventional flaps, the drag increase (speedbrake effect) is smaller. This means the airplane floats longer in ground effect on landing, making short field landings more difficult. A pilot friend had a Rans S-10 Sakota with flaperons. He told me he rarely used the flap function, preferring to sideslip on approach. The French DynAero MCR-01 high performance plane (Ban-Bi in the US) was originally designed (in the microlight/UL version) with double slotted flaperons to comply with the stall speed requirement of 35 knots (65 km/h) even with a very small wing area. After a few years, they were able to tweak the wing design to fulfil the stall speed requirement also with a conventional arrangement with ailerons and double slotted flaps, and this is the current configuration. A number of airplanes (gliders in particular) have ailerons which are connected with the flaps and move with them. In these planes, the main idea is to be able to reduce drag with negative deflection of the ailerons together with the flaps. But I'd hesitate to call them flaperons in this case, where the wing also has separate flaps. Please correct me if I got something wrong, my practical exeprience of flaperons is limited to radio controlled model airplanes ;-) // N |
The Mosquito (glider) has an unusual arrangement, not flaperons, but quite
related. The ailerons and flaps move together when commanded by one lever. That's quite common on 15meter ships. The ailerons move independently of the flaps for aileron control. When you pull a different lever, for airbrake, the flaps deflect downward and a spoiler comes up (the spoiler is hinged at it's trailing edge and actually pushes the flap down) but the ailerons do not move. Then you can move the ailerons up and down in unison with the lever that I first mentioned while at the same time can be moved like normal ailerons. The ailerons have differential as well, more up than down. It is quite a system. The drag range is very large. The stall speed is hardly changed at all between flaps up and down. Typically I will takeoff with the flaps and ailerons full up. It makes a distinct difference in roll authority. After landing the first order of business is to get the ailerons up for this better aileron authority. By modulating the flaps/speed brake you can control your landing roll considerably (on hard surface). I must note - just because the stall speed doesn't change much with speed brakes it doesn't mean that the lift isn't changed much. The way we do stalls is not measuring your descent rate, it is measuring the speed at which you lose the ability to control the aircraft. Nils Rostedt wrote in message ... "Lou Parker" wrote in message . com... I just don't get it. Can anyone successfully explain how flaperons work? Are they better or worse than seperate flaps? What are the pro's and con's? It seems to me if one fails you have no recovery. Lou I'll try ;-) Flaperons are control surfaces that look like full span ailerons. They work both as ailerons (i.e. move in opposite directions when the stick is moved) and as flaps (i.e. move in the same direction when the flap handle is moved). There is a mechanical "mixer" device connected to the stick and flap handle that transmits the movement to the control surfaces so that they move as described above. The advantage, in theory, is that you can have effective, full span ailerons at the same time with effective full span flaps that can bring the stall speed down. To get the same effect with conventional control surfaces, the flaps need to be of more exotic design such as the split or Fowler type flaps. The main disadvantage is that when the flaps are in use you get an increased adverse yaw moment, which may make steering more difficult during approach. Also, as the flap deflection angle is limited compared to conventional flaps, the drag increase (speedbrake effect) is smaller. This means the airplane floats longer in ground effect on landing, making short field landings more difficult. A pilot friend had a Rans S-10 Sakota with flaperons. He told me he rarely used the flap function, preferring to sideslip on approach. The French DynAero MCR-01 high performance plane (Ban-Bi in the US) was originally designed (in the microlight/UL version) with double slotted flaperons to comply with the stall speed requirement of 35 knots (65 km/h) even with a very small wing area. After a few years, they were able to tweak the wing design to fulfil the stall speed requirement also with a conventional arrangement with ailerons and double slotted flaps, and this is the current configuration. A number of airplanes (gliders in particular) have ailerons which are connected with the flaps and move with them. In these planes, the main idea is to be able to reduce drag with negative deflection of the ailerons together with the flaps. But I'd hesitate to call them flaperons in this case, where the wing also has separate flaps. Please correct me if I got something wrong, my practical exeprience of flaperons is limited to radio controlled model airplanes ;-) // N |
connected with the flaps and move with them. In these planes, the main idea is to be able to reduce drag with negative deflection of the ailerons together with the flaps. But I'd hesitate to call them flaperons in this case, where the wing also has separate flaps. Gliders with connected but separate flaps and ailerons are commonly referred to as having interconnected flaps and ailerons. This is a very common system on gliders that have flaps, not all do. In the negative flap position the entire trailing edge is at a negative setting. This reduces drag and increases performance. When applying positive flap the ailerons also drop with the flap so that the entire trailing edge is at a positive flap setting. The ailerons still work as ailerons separately from the flap on some gliders. On a glider such as the ASW-20 you have to see the interconnect system to believe it. As the flaps go to positive positions so do the ailerons then as the flap is put further down to the landing position the ailerons go back up to a neutral or almost neutral setting thus reducing the angle of attack at the tips and allowing for better lateral control during the landing roll. When the control stick is moved laterally, for roll, the flaps and ailerons deflect together but at different rates. Truly an amazing system and I always think of it whenever someone mentions how "simple" gliders are. Robert Mudd |
![]() "Robertmudd1u" wrote On a glider such as the ASW-20 you have to see the interconnect system to believe it. As the flaps go to positive positions so do the ailerons then as the flap is put further down to the landing position the ailerons go back up to a neutral or almost neutral setting thus reducing the angle of attack at the tips and allowing for better lateral control during the landing roll. When the control stick is moved laterally, for roll, the flaps and ailerons deflect together but at different rates. Truly an amazing system and I always think of it whenever someone mentions how "simple" gliders are. Speaking of gliders, I wonder if any gliders have an arrangement whereby both ailerons can be moved in unison to a really high negative (up) angle, in effect acting as spoilers or speedbrakes. This was available on a Multplex radio control system I had in the late eighties, using electronic mixing (aileron control was of course still available) . I think it was called "scarecrow mode" or something similar. The advantage would be that separate speedbrakes are not needed. But in a full scale glider it might be hard on the hinges and cause too big wingtip twist? // N |
Nils Rostedt wrote...
Speaking of gliders, I wonder if any gliders have an arrangement whereby both ailerons can be moved in unison to a really high negative (up) angle, in effect acting as spoilers or speedbrakes... What you describe sounds like "crow" mixing, where the flaps go down and the ailerons (both) reflex up. It's still used in RC gliders, and given that there are several powered airplanes that use it or something similar I'd bet that there are full-size gliders that use it as well. There's also trailing edge reflex, where flaps and ailerons all move *slightly* trailing edge up, but not a lot, and that's for drag reduction in cruise, not drag increase for approach. Some full-size gliders use this as well. Dave 'poor man's DLC' Hyde |
