Herbert Kilian wrote:
[....] Another comment: poking fun at the use of check-lists in this thread is very unfortunate. Herb, I see the main thrust of references to checklists in this thread as a denigration of overly detailed checklists, and as a warning against using checklists in situations where time is of the essence in responding to an abnormal attitude or condition of flight. I hope that everyone understands it is the misuse of checklists and not their proper and very necessary uses at which fun was being poked. Some immediate action steps must be committed to memory and become second nature. In many phases of flight, both normal and abnormal, a checklist is best used as a review. I think you are right about the conduct of control checks. Anybody should be able to move the stick as instructed, but only the pilot can be expected to know the feel of a properly connected system and that feel is best gained at the control surface. Assembly, control, and walk-around checks (always performed separately) seem to me to be the best examples of the "menu" approach to using a checklist. Jack |
is very unfortunate. Exactly which part of my post was "poking fun"? I thought that I was being dead (pardon the pun) serious. I have 4 opportunities to catch an error on control linkages: 1. The initial hookup. 2. An immediate check of each control linkage after hookup. 3. The walk-around inspection. 4. Visual observation of control movement standing by the cockpit. Missing all 4 falls into the "being hit by an asteroid" category. Tom |
![]() "Herbert Kilian" wrote in message (snip) Another comment: poking fun at the use of check-lists in this thread is very unfortunate. Herb, J7 I wasn't making fun of using a checklist. Using a checklist is important and I use a fairly detailed one religiously before each flight. I do not, however, need a line item telling me to remove the canopy cover before flight! -Bob Korves |
Tom Seim wrote:
I recently read the accident report of the ASW20 crash (fatal) at Williams, CA. Per the check list, they did a positive control check of the elevator by having the assistant (co-owner) hold the elevator while the pilot applied force on the stick. Resistance was felt, check list passed. Only problem was the elevator was not hooked up and what the pilot felt was the push rod hitting the bottom of the elevator. Now, if the guy just LOOKED at the connection it would have been obvious that it was not hooked up (it is in plain site). Following a list may give you tunnel vision. A DC-9 was landed gear up by two experienced pilots following a check list (they missed one step). They were so certain that they had done everything right that they ignored the lack of the sound and thump of the gear lowering (common sense, again). I took my CFIG checkride with the FAA. On it, I told him "there is no PCC in the schweizer manual for any checklist. The checklist requires inspection during preflight of the connections. I find the (over)use of the PCC distracts the pilot from the more important action: checking the connection itself." He nodded, and we moved on to other things. My understanding of contests is that an "assisted PCC" is required by many CDs. I wonder if an "assisted connection inspection" wouldn't be a better, higher, priority... As far as the DC-9, I'd guess this is another example of information which is lost in the noise. I remember asking a car dealer about his warranty. He had a super long list of covered items. He said just about everything was covered. I asked him to make a nice short list of what WASN'T covered. He couldn't, and we parted. Useful information is prioritized. When I write professionally, I do a 200 word abstract, then a 1000 word introduction/summary, then a 5000 word detail. And yes, the 200 word abstract is first. I'd like to see all writing (including the checklists) follow this idea. A few important points at the front, the nit details at the back. -- ------------+ Mark Boyd Avenal, California, USA |
The discussion of a) overly-long checklists that don't get used and,
on the other hand, b) the need for checklists reminds me of a discussion with a power instructor (instrument), who made a distinction I hadn't encountered before, but it made sense. He distinguished between a written procedure, a written checklist and an oral checklist. Here's the idea: Written procedu a written sequence of steps to take. Written checklist: a written list of things to check. Oral checklist: a memorized checklist. Should be very short, and memorable, used only for a few last-minute and "death/destruction" items. A written procedure may be quite long and can be detailed. It may contain some lower-importance items. It is used for setting up the aircraft and should be used when there is time for it. Sitting next in line for takeoff on the runway, barreling down final approach, or right after a rope break - not good times for a written procedure. A written checklist may also be quite long. Often it's the same as the procedure list, but it should contain only short reminders of only the important items: its purpose is to confirm that the aircraft is already properly set up. Written checklists should also be used when there is time for them. They provide a double-check; their disadvantage is that they rarely identify anything wrong, so human nature makes it easy to miss something. It's mostly for that reason that a checklist should be as short as possible and should stick to truly important items: no zipper-checks. In 2-pilot operations, the written procedure and checklist can be combined in a single document, but the functions are separated by the challenge-response between the two pilots. For single pilot operation, this instructor did NOT like the approach of read-it-do-it-confirm-it all in one pass. It's too easy to either skip a line, or skip an action (to avoid missing a line, pilots have a tendency to touch the control but keep their eyes on the list, so they don't actually confirm the step or even think about what they're doing). Hence his preference for separating the roles of the two pilots - read it (copilot role), do it (pilot role), check it (copilot role) - into entirely separate sequences. An oral checklist should be short and memorable. It should contain only last-minute items and the few items most likely to cause death and/or destruction. It can be used when the pilot is busy, because it's short and doesn't require reading. In fact, busy moments - when something may get overlooked - can be a good place to insert one! The takeoff and landing checklists are the best examples. I'm still working on how this translates for gliders. I think those long checklists ("zipper check / chewing gum quantity check / attach tow rope") are actually procedures: most pilots probably don't need to keep using the written version (how likely is it that you'll forget to attach the tow rope? - and if you do, what will happen?). Shorter checklists have their place - "task set up on the nav computer" - but probably should be done before you become #1 in line for takeoff. And oral checklists should be used right before takeoff ("brakes-trim-belts" or whatever) and landing (USTALL, or your own favorite) as a last-minute confirmation that nothing really stupid is going to cause something really bad. There's a somewhat separate question of what the right contents for the procedures and checklists should be! |
the procedures and checklists should be! With apologies to pilots whose memories never fail even under stress, I'm one of those guys who does use a very detailed written checklist. Chewing gum isn't on it but things like food, drinking water, reading glasses, and landout jacket are. But I don't wait until I'm #1 on the takeoff line to use it. One reason is that it's in sections. The first and longest section is the post-assembly checklist with all the stuff on the glider, arranged in the proper walkaround order. I can do that immediately after rigging. Then there's another list of all the stuff that should be in the cockpit--things that wouldn't kill me if I forgot but which might make life less comfortable. Then there are sections for task items (applies only to contests: task sheet, retrieve telephone #, etc.), on the grid (tail dolly, etc.), and pre-takeoff (I use the very old SSA A-B-C-C-C-D sequence that I committed to memory back in the mid 1960s). I've got a section for landing out: remove multi-probe, download trace to CF card, etc., since in the pre-cellular world I once got to a pay telephone without my wallet or the retrieve #. There's even a section for my crew to use for hooking up the trailer. I keep a copy in the cockpit at all times. If I do things out of sequence, I literally check off each item with a pencil. On a normal day at the gliderport, I just run my thumb down the list and make sure I'm not interrupted during one of the sections. OK, maybe this is overkill. But whether I'm crewless or accompanied by my wife and two 10-year-old daughters, it seems like I'm always rushed before takeoff. Having a written checklist not only guarantees I won't forget something but gives me peace of mind when I launch that I've done everything right and lets me focus on flying safely. And in the post-Clem Bowman/Genesis accident era, it gives my family the same peace of mind. I'll confess that in the past 40 years, I've taken off without my map (pre-GPS days), with my dive brakes open, without taping, and with a landing gear door hanging loose. And that doesn't count the time I was on the line ready to launch with the tail dolly still attached. It's fun to scoff about obsessive/compulsive types reaching for their checklist and pencil during a spin recovery. ![]() use my written checklist before every flight, as I noted in the safety talk I gave at this year's U.S. Standard Class Nationals. Chip Bearden |
Finbar wrote: The discussion of a) overly-long checklists that don't get used and, on the other hand, b) the need for checklists reminds me of a discussion with a power instructor (instrument), who made a distinction I hadn't encountered before, but it made sense. He distinguished between a written procedure, a written checklist and an oral checklist. Here's the idea: Written procedu a written sequence of steps to take. Written checklist: a written list of things to check. Oral checklist: a memorized checklist. Should be very short, and memorable, used only for a few last-minute and "death/destruction" items. A written procedure may be quite long and can be detailed. It may contain some lower-importance items. It is used for setting up the aircraft and should be used when there is time for it. Sitting next in line for takeoff on the runway, barreling down final approach, or right after a rope break - not good times for a written procedure. One other item. I've found that numbering the written checklist helps. Then, even solo, I read it aloud. I read "1", and aloud then I do "2". I've found that if I skip a step, my brain goes instantly "3 isn't after 1!" and I'm saved. Again, I also prioritize it. This makes for an awkward flow in some aircraft, but I can repeat items to get a good flow. Anyway, all good stuff... -- ------------+ Mark Boyd Avenal, California, USA |
Kirk Stant wrote: (Mark James Boyd) wrote in message news:412fa9ba$1@darkstar... Kirk Stant wrote: 1) If they ain't locked for takeoff, a gnarly pio 1. Use a checklist. Oh, and why is the tow pilot fanning his rudder at me? LOL! "use a checklist." Kind of covers everything, huh? "Oh yeah? He had an accident? I bet he didn't use the checklist!" So Mark, you don't use any checklist before taking off? Yeah right, bull****. What is it, not macho enough for you? Kirk. I am very sorry that this appeared to be a condemnation of checklists. It was not, and in fact my intetion was to strongly support the significance of what you and others have stated. The elevator connection on preflight, and the dive brakes closed, as you mention, are very important. I was simply pointing out that the bland assertion that one should "use a checklist" can actually cause an accident. If the pilot now uses that to (wrongly) make a checklist which is very long and does not prioritize the importance of the items, it can cause fatigue and inattention. So yes, I certainly use a checklist, but I ALWAYS use a prioritized checklist. And I teach students how to make a custom prioritized checklist for a new aircraft by looking at the accident reports and starting with that. Again, Kirk, I apologise if this seemed offensive. I was only wanting to gently steer us into a more detailed discussion. I use CBSIFTCBE (instead of the useless SSA ABCCCDDEEEEFGHHHwhatever) RELIGIOUSLY before every takeoff. It's as sacred as the old GUMP checklist. No paper required, only need one brain cell awake to run it. And even with that, I've managed to get airborne twice with my spoilers unlocked - in an LS4 and my current LS6. Both due to interrupted/rushed launches. No big deal, the tow didn't even notice (because LS brakes don't suck open, they just stay cracked) the decreased climb rate. I caught them both below 100', closed the boards, swore a bunch, then went on to convincingly blow the task of the day. So CBSIFTCBE. Ok, what are the top 3? Is spoilers locked one of the top 3 for you? I'm just saying put that one as the FIRST item, instead of elsewhere if a) it is the number one checklist item cause of fatal accidents in the type of glider you fly where you fly it and b) if it is something that you tend to miss more often than other items. At Truckee, maybe the low rope break briefing is more important than the trim set. In the PW-5 at Avenal, maybe the spoilers locked is more important than the emerg. brief. If the student often reaches out to close the vent on takeoff and this makes a PIO, then for him, maybe the vent closed for takeoff is the number one item. I simply do not believe that there is a correct ordering, or a correct checklist that can work for all gliderports and all pilots and all aircraft. I strongly believe in prioritized, personal checklists. The checklist, and the process to make it, are really important. Seriously, if your students aren't going through a "last chance" check before commiting to takeoff, they have really bad instructors, to say the least. And that is "using a checklist". And it will usually prevent brainfade idiotic accidents from happening. Usually. I agree with you Kirk, just in a little more detail...ok? Thanks for the responses...and again sorry if it looked like I was pickin' on you... -- ------------+ Mark Boyd Avenal, California, USA |
SR22 Spin Recovery | gwengler | Piloting | 9 | September 24th 04 07:31 AM |
Spin Training | JJ Sinclair | Soaring | 6 | February 16th 04 04:49 PM |
Cessna 150 Price Outlook | Charles Talleyrand | Owning | 80 | October 16th 03 02:18 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
