Hi Kirk,
I'm sorry to hear it is not working for you. My testing is limited because I don't have any large flight logs in my SN10 units. I'll do my best to try it with a friends unit soon. I was able to download small flight logs just fine using an iPAQ 3970. I guess more testing is needed. Thanks, Paul Remde "Kirk Stant" wrote in message om... I went out and tried this procedure using an Ipaq 3950 and it didn't work worth a can of beans. I only tried downloading a flight log from my SN10B. Running PocketDOS and getting the SN10 to recognize the HL file transfer program worked fine, but as soon as I started to download the flight log it was apparent that the speed of the download was INCREDIBLY SLOW! I could live with that, but after a few minutes of uninterrupted downloading, the connection would self disconnect, and I would have to start all over again. After fooling around for about an hour, and only getting 33% of the flight log (a 4 hour flight) downloaded before it aborted, I quit. So, am I missing something? Is there a setting in PocketDOS (or the PDA) that will make the file transfer faster? What could be causing the connection to be interrupted? Once I start it, I walk away and don't touch a thing! Are there some weird problems with the 3950 that I don't know about? Mine refuses to format or read SD cards, could that mean that the PDA is bad? Has anyone else had any luck with this, or similar problems? Kirk |
Hi Kirk,
We must be doing something differently because it didn't work well for you and worked great for me. On Saturday I download a friends flight log from his SN-10b using my iPAQ 3970 with PocketDOS and the HL utility from ILEC. It worked perfectly. It downloaded the flight log in only about 1 to 2 minutes. However, the SN-10 then seemed to "think" for several minutes, but eventually the SN-10 reported that the transfer was successful. My iPAQ 3970 is basically the same as the 3950 you are using. Perhaps something was set differently in Pocket DOS? I tested PocketDOS without buying a license initially but later bought a license. I think it cost around $35. Without the license the software has some delays at startup and other differences. Could that be the problem? Paul Remde "Paul Remde" wrote in message news:SR55d.105486$MQ5.55893@attbi_s52... Hi Kirk, I'm sorry to hear it is not working for you. My testing is limited because I don't have any large flight logs in my SN10 units. I'll do my best to try it with a friends unit soon. I was able to download small flight logs just fine using an iPAQ 3970. I guess more testing is needed. Thanks, Paul Remde "Kirk Stant" wrote in message om... I went out and tried this procedure using an Ipaq 3950 and it didn't work worth a can of beans. I only tried downloading a flight log from my SN10B. Running PocketDOS and getting the SN10 to recognize the HL file transfer program worked fine, but as soon as I started to download the flight log it was apparent that the speed of the download was INCREDIBLY SLOW! I could live with that, but after a few minutes of uninterrupted downloading, the connection would self disconnect, and I would have to start all over again. After fooling around for about an hour, and only getting 33% of the flight log (a 4 hour flight) downloaded before it aborted, I quit. So, am I missing something? Is there a setting in PocketDOS (or the PDA) that will make the file transfer faster? What could be causing the connection to be interrupted? Once I start it, I walk away and don't touch a thing! Are there some weird problems with the 3950 that I don't know about? Mine refuses to format or read SD cards, could that mean that the PDA is bad? Has anyone else had any luck with this, or similar problems? Kirk |
"Paul Remde" wrote in message news:YxL5d.117055$MQ5.57483@attbi_s52...
Hi Kirk, We must be doing something differently because it didn't work well for you and worked great for me. On Saturday I download a friends flight log from his SN-10b using my iPAQ 3970 with PocketDOS and the HL utility from ILEC. It worked perfectly. It downloaded the flight log in only about 1 to 2 minutes. However, the SN-10 then seemed to "think" for several minutes, but eventually the SN-10 reported that the transfer was successful. My iPAQ 3970 is basically the same as the 3950 you are using. Perhaps something was set differently in Pocket DOS? I tested PocketDOS without buying a license initially but later bought a license. I think it cost around $35. Without the license the software has some delays at startup and other differences. Could that be the problem? Paul Remde Paul, Not sure. I also bought the license, so it should be the same setup. Like I said, I couldn't use the SD card, and that could be part of the problem. I might play with it this winter some more. Kirk |
New File Library Email Service | Tom Allensworth | Simulators | 2 | July 19th 04 10:33 PM |
WingX for the Pocket PC - Version 1.2 | Hilton Software LLC | Products | 1 | October 17th 03 01:38 PM |
gpligc map file | Mike Stramba | Soaring | 0 | October 3rd 03 08:20 PM |
Cross post - NASA/ARMY TRANSFER UNIQUE AIRCRAFT TO AIR AND SPACE MUSEUM | Tim Luton | Rotorcraft | 0 | September 11th 03 11:14 PM |
WinPilot Now Supports Ipaqs with Pocket PC 2003 Ipaqs 2200, 5510, 5400, 5500 Series. | rhpf | Soaring | 0 | August 15th 03 01:21 AM |
