Bill Daniels wrote:
Four aero retrieves! What you flyin' boy, a 1-26? Come on, now: landing out is caused by the pilot, not the glider. If you don't know when to turn back, even a 60:1 glider isn't going help. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
And the ones I researched that were closest were in Arizona or
Washington, and aren't getting anywhere even remotely close to 50 launches a day. Well, a friend and I got about 25 launches in four hours. Take off, fly the pattern, land on the cross wind, rotate the glider 90 degrees, and then off again. Of course, then you also have the esteemed contingent at my club who take off, do a complete pattern landing back into the wind, and then have to push back to the take off spot again. About half the efficiciency. Best line ever after dropping off the 'chute and driving back to the winch for the next go. "We're still figuring out who is going to fly next." All depends on the efficiency of the operation. Slow cycle time is zero fun. Jim Vincent N483SZ illspam |
Jim Vincent wrote:
And the ones I researched that were closest were in Arizona or Washington, and aren't getting anywhere even remotely close to 50 launches a day. Well, a friend and I got about 25 launches in four hours. Take off, fly the pattern, land on the cross wind, rotate the glider 90 degrees, and then off again. Of course, then you also have the esteemed contingent at my club who take off, do a complete pattern landing back into the wind, and then have to push back to the take off spot again. About half the efficiciency. Best line ever after dropping off the 'chute and driving back to the winch for the next go. "We're still figuring out who is going to fly next." All depends on the efficiency of the operation. Slow cycle time is zero fun. Jim Vincent N483SZ illspam You don't need any magic number of launches a day to make a winch viable. You need to have enough to cover the overheads, but that is a very modest number. Our vintage (30years +) winch is a good example of how a winch can make a gliding club viable with few members and resources. Built originally for a small club, we have stayed in business with less than 10 active members. Our average is around 30 launches per day. Worst case 12 minute cycle time with 2km of cable - shorter retrieve is quicker turn around. There is no substitute for experience if you want it slick, when we have a bunch of experienced guys doing the winch driving and retrieving and radio control it can come down to 8 minutes per launch. This is typical of a weak day when we have 3 to 5 gliders on the line and folk are managing to stay up long enough to allow us to launch before they land. Record day this way was 46 launches. Launch marshal makes sure someone is ready to go when the wire comes back. If you appear lees than keen to get in the air you might get sent to drive the winch for a bit. Tends to focus minds. Works well for a club that does proportionally high amount of training. Early and late part of the day focus is on teaching flights, the private guys and more experienced club pilots get to use the better part of the day for longer flights. Everyone gets to fly, as long as everyone contributes. It is cheap and sociable. Club membership getting back over 30 again. We charge ~$4 per launch, and keep the maintenance on the winch at an acceptable level. Means we have some guys flying at our club who could not afford it anywhere else. ALso means that in the depths of winter there are queues waiting for the trainer, with students banging out cheap instruction circuits. SOmetimes they get lucky and come back an hour later... |
Winching.
1. You may be able to secure a long term lease for land much cheaper than buying it. If use is weekends only, the land may be used for grazing or some other activity in the interim. In the case of my club, we could conceivably lease enough dry land a few miles east for what we pay in property taxes annually. Site selection is important. Multiple sites may be needed to cover then changing seasons. 2. At Avenal, are there roads at either end of the runway? If not, perhaps the neighboring property owners could be convinced to allow the winch to be put 2000-2500 off the end of the airport a couple of days a week. This should give you a land back area and provide for great launches. We have days when pilots tow 20 miles away to 11,500ft and still land back. Wait for the convergence to come to you. 3. Launch rate is important. With our single drum winch, I can drive a launch, drag the wire, return to the winch, and launch again with an 8 minute cycle time on a 5000ft run. If the headwind is good, I can have both CG equipped two-seaters in the air at the same time. When there's lift, we launch about every 15 minutes, giving each training sorty about 20-25 minutes. I will chastise anyone who is not ready to launch when the wire arrives. Do your ground school after hours or week nights, not at the launch point. 4. When there's lift, at least 75 percent of the launches commit soaring. My average aero tow release height is less than I normally get from a winch launch. Sometimes you just need to be patient and work it for a while. If you get impatient, you'll land back more often. However, the price of a re-light is okay too! When I did primarily winch launching in the UK, I could count on one hand the number of re-lights I took in an entire season. Depending on the year, I averaged more than 3 or 4 hours per flight (with long wings admittedly). 5. My club has actually done a retrieve with a winch. It's on a licensed trailer chassis and portable. Our tow plane is not covered for off airport tows. 6. If you get a ground launch endorsement in six launches, you've been cheated. Don't expect to exercise your privileges at my club. There are some insidious things about ground launching that could bite you, and you will practice and understand avoiding them. They can't be exercised in six launches. No matter how many winch launches we've flown or driven, we're still learning. I, for one, haven't seen it all, nor do I care to. Frank Whiteley |
My club (Rattlesden in Suffolk, England) operates both winch and aerotow
simultaneously. From 8 years flying there I'd say that the most important factor for winching is the layout of the site. If it is possible for aircraft to land without interrupting winch launching then it's very satisfactory as a launch method, and you might consider moving to winch only. Our site is more difficult - an ex WW2 USAF airfield with a main 3,000 ft runway and a shorter 1,600 ft cross runway. We can only winch from the main runway, which means a crosswind component on the majority of days. In a typical (!) single-seater like a Grob Astir you could expect 800-1,000 ft on a 90 degree crosswind day, and 1,400 ft plus with a 20kt headwind. A reasonable soaring day with, say, a 30 degree crosswind at 10kt should give you around 1,300 ft. From this, if you are a reasonably competent soaring pilot, I estimate you have a 50/50 chance of soaring. This increases if you can delay the launch until "your" cloud arrives over the winch. Frank Whiteley makes some highly relevant points: 3. Launch rate is important. With our single drum winch, I can drive a launch, drag the wire, return to the winch, and launch again with an 8 minute cycle time on a 5000ft run. If the headwind is good, I can have both CG equipped two-seaters in the air at the same time. When there's lift, we launch about every 15 minutes, giving each training sorty about 20-25 minutes. I will chastise anyone who is not ready to launch when the wire arrives. Do your ground school after hours or week nights, not at the launch point. All this is very true, but on a restricted site the launch rate also suffers from aircraft landing on the main run, used for winching. Trainees and early solo pilots will use the main runway most of the time, as will the tug aircraft. Practice winch failures at low hight will land straight ahead. The sudden appearance of three gliders will require at least one to use the main runway. All this means you need to be well organised, so as to clear the gliders waiting to launch if necessary. Given these potential frustrations of the winch launch, unnecessary delays by pilots waiting to launch are to be avoided at all costs. We use a Skylaunch twin drum winch with braided wire cable, and on a good summer day might achieve 50 launches, 35 winch and 15 aerotow. On an evening when instructors fly introductory flights, using two two-seater gliders launching from the main runway and landing on the cross we have achieved 16 launches per hour (6 min flights), winching only. 6. If you get a ground launch endorsement in six launches, you've been cheated. Don't expect to exercise your privileges at my club. There are some insidious things about ground launching that could bite you, and you will practice and understand avoiding them. They can't be exercised in six launches. No matter how many winch launches we've flown or driven, we're still learning. I, for one, haven't seen it all, nor do I care to. Absolutely! From memory from the BGA instructor's manual you need to learn at least: 1. The ground run (quite different from aerotow); 2. A safe transition to the climb, so that a 50ft cable break doesn't leave you with insufficient energy to push over, regain flying speed and round out. Correct use of the airbrakes in this situation is critical. 3. Recovery from a low cable break with a straight ahead landing. 4. Recovery from an "awkward" height cable break, where you can't land ahead but have too little height for a normal circuit. 5. Recovery from a mechanical failure of the winch (usually a gradual loss of power). 6. Signalling too fast and too slow, and what to do if the winch doesn't respond. 7. Laying off for crosswinds to prevent the cable falling off the runway on release. 8. Avoiding over-speeding and under-speeding. This includes understanding the changes in stresses on the glider throughout the launch and the symptoms of an impending stall on the wire (very nasty!). 9. Stalling and spinning from launch failures - these will be simulated at height, e.g. dive to 70kt, pull up into 45 degree climb, as speed falls to around 50kts instructor announces cable break. It takes a second or two to react and push over, by which time speed will be down to 30 kt or so. If you stop the pushover at the normal gliding attitude and turn immediately most gliders will roll smoothly into a spin with no warning signs - don't try this on your own if you haven't been well trained on spin recovery! 10. Inadvertent launching into cloud. This list may sound alarming, but we regularly solo students on the winch with, say, 7 hrs flying time. However, there's no way these matters can be covered in a handful of launches. The UK consensus seems to be that winch launching is as safe as aerotow but *only* if pilots are well trained. So why do we aerotow as well? Obviously, some aspects of pilot training require more height than a winch launch will give. More important, for pilots setting off on a task an aerotow takes you to the lift at a height where it's easier to work. Less mental energy used to get started means more left over to complete the task. |
Did they ever remove the broken up concrete or resurface the runway? It was
in a state 25 years ago. Would have been lethal to aerotow there then. Are you still using that old piano wire winch with the big 'drum'? Frank "Chris Reed" wrote in message ... My club (Rattlesden in Suffolk, England) operates both winch and aerotow simultaneously. From 8 years flying there I'd say that the most important factor for winching is the layout of the site. If it is possible for aircraft to land without interrupting winch launching then it's very satisfactory as a launch method, and you might consider moving to winch only. Our site is more difficult - an ex WW2 USAF airfield with a main 3,000 ft runway and a shorter 1,600 ft cross runway. We can only winch from the main runway, which means a crosswind component on the majority of days. In a typical (!) single-seater like a Grob Astir you could expect 800-1,000 ft on a 90 degree crosswind day, and 1,400 ft plus with a 20kt headwind. A reasonable soaring day with, say, a 30 degree crosswind at 10kt should give you around 1,300 ft. From this, if you are a reasonably competent soaring pilot, I estimate you have a 50/50 chance of soaring. This increases if you can delay the launch until "your" cloud arrives over the winch. Frank Whiteley makes some highly relevant points: 3. Launch rate is important. With our single drum winch, I can drive a launch, drag the wire, return to the winch, and launch again with an 8 minute cycle time on a 5000ft run. If the headwind is good, I can have both CG equipped two-seaters in the air at the same time. When there's lift, we launch about every 15 minutes, giving each training sorty about 20-25 minutes. I will chastise anyone who is not ready to launch when the wire arrives. Do your ground school after hours or week nights, not at the launch point. All this is very true, but on a restricted site the launch rate also suffers from aircraft landing on the main run, used for winching. Trainees and early solo pilots will use the main runway most of the time, as will the tug aircraft. Practice winch failures at low hight will land straight ahead. The sudden appearance of three gliders will require at least one to use the main runway. All this means you need to be well organised, so as to clear the gliders waiting to launch if necessary. Given these potential frustrations of the winch launch, unnecessary delays by pilots waiting to launch are to be avoided at all costs. We use a Skylaunch twin drum winch with braided wire cable, and on a good summer day might achieve 50 launches, 35 winch and 15 aerotow. On an evening when instructors fly introductory flights, using two two-seater gliders launching from the main runway and landing on the cross we have achieved 16 launches per hour (6 min flights), winching only. 6. If you get a ground launch endorsement in six launches, you've been cheated. Don't expect to exercise your privileges at my club. There are some insidious things about ground launching that could bite you, and you will practice and understand avoiding them. They can't be exercised in six launches. No matter how many winch launches we've flown or driven, we're still learning. I, for one, haven't seen it all, nor do I care to. Absolutely! From memory from the BGA instructor's manual you need to learn at least: 1. The ground run (quite different from aerotow); 2. A safe transition to the climb, so that a 50ft cable break doesn't leave you with insufficient energy to push over, regain flying speed and round out. Correct use of the airbrakes in this situation is critical. 3. Recovery from a low cable break with a straight ahead landing. 4. Recovery from an "awkward" height cable break, where you can't land ahead but have too little height for a normal circuit. 5. Recovery from a mechanical failure of the winch (usually a gradual loss of power). 6. Signalling too fast and too slow, and what to do if the winch doesn't respond. 7. Laying off for crosswinds to prevent the cable falling off the runway on release. 8. Avoiding over-speeding and under-speeding. This includes understanding the changes in stresses on the glider throughout the launch and the symptoms of an impending stall on the wire (very nasty!). 9. Stalling and spinning from launch failures - these will be simulated at height, e.g. dive to 70kt, pull up into 45 degree climb, as speed falls to around 50kts instructor announces cable break. It takes a second or two to react and push over, by which time speed will be down to 30 kt or so. If you stop the pushover at the normal gliding attitude and turn immediately most gliders will roll smoothly into a spin with no warning signs - don't try this on your own if you haven't been well trained on spin recovery! 10. Inadvertent launching into cloud. This list may sound alarming, but we regularly solo students on the winch with, say, 7 hrs flying time. However, there's no way these matters can be covered in a handful of launches. The UK consensus seems to be that winch launching is as safe as aerotow but *only* if pilots are well trained. So why do we aerotow as well? Obviously, some aspects of pilot training require more height than a winch launch will give. More important, for pilots setting off on a task an aerotow takes you to the lift at a height where it's easier to work. Less mental energy used to get started means more left over to complete the task. |
Hi,
And of course I've had 4 aero-retrieves. Try that with a winch ![]() I read about a place in Namibia where they take the winch to the landout site. Ciao, MM -- Marian Aldenhövel, Rosenhain 23, 53123 Bonn. Fon +49 228 624013, Fax +49 228 624031. http://www.marian-aldenhoevel.de "I know you believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant." |
![]() "Kirk Stant" wrote in message om... (Mark James Boyd) wrote in message news:41818652$1@darkstar... Steve Hill wrote: I'd really like to see what the actual costs are for a club to purchase a good winch. The "street" has spoken. There are NO winches in California. And the ones I researched that were closest were in Arizona or Washington, and aren't getting anywhere even remotely close to 50 launches a day. I haven't been to Washington yet, but I have talked to the club there and they were closed for a good part of last winter (0 launches). Would a winch in CA do well? I dunno. At Avenal, there are days when it would be fine, but then again there are a lot of days or times of the day when a higher tow or further away is better. And of course I've had 4 aero-retrieves. Try that with a winch ![]() The Prescott (AZ) Soaring Club does well with their winch, apparently. Down here where I usually fly at Turf (just west of Phoenix), we rarely aerotow higher than 1500', I think my usual release altitude is about 1200' just off the end of the runway into the house thermal - ideal for a winch! Of course, this makes for a pretty quick cycle time with a couple of Pawnees, and we would really need a double or triple drum setup to get a race grid off rapidly, but it sure would be fun to watch! Kirk 66 If Babblefish translated it right, the Dutch Nationals launched 60 gliders in 45 minutes with two of their 6-drum winches. That's a LOT cheaper than a fleet of Pawnees. Bill Daniels |
![]() "Kirk Stant" wrote in message om... (Mark James Boyd) wrote in message news:41818652$1@darkstar... Steve Hill wrote: I'd really like to see what the actual costs are for a club to purchase a good winch. The "street" has spoken. There are NO winches in California. And the ones I researched that were closest were in Arizona or Washington, and aren't getting anywhere even remotely close to 50 launches a day. I haven't been to Washington yet, but I have talked to the club there and they were closed for a good part of last winter (0 launches). Would a winch in CA do well? I dunno. At Avenal, there are days when it would be fine, but then again there are a lot of days or times of the day when a higher tow or further away is better. And of course I've had 4 aero-retrieves. Try that with a winch ![]() The Prescott (AZ) Soaring Club does well with their winch, apparently. Down here where I usually fly at Turf (just west of Phoenix), we rarely aerotow higher than 1500', I think my usual release altitude is about 1200' just off the end of the runway into the house thermal - ideal for a winch! Of course, this makes for a pretty quick cycle time with a couple of Pawnees, and we would really need a double or triple drum setup to get a race grid off rapidly, but it sure would be fun to watch! Kirk 66 A single drum winch is the poorest of compromises in effeciency with only cost being the overriding factor. There is simply no reason to drag one rope at a time and doing so can make the entire process more tedious and dampen enthusiasm. Only one thing matters to private owners on the ground, and that's launch rate. For wide adoption, a two drum winch works well. For a large operation, two two-drum winches provide high availability and redundancy, portability is off-site operations are anticipated. Frank |
Smart CDI diesel engine | Hans Zwakenberg | Home Built | 14 | January 9th 05 12:32 PM |
Proposals for air breathing hypersonic craft. I | Robert Clark | Military Aviation | 2 | May 26th 04 06:42 PM |
Diesel engine | Bryan | Home Built | 41 | May 1st 04 07:23 PM |
Emergency Procedures | RD | Piloting | 13 | April 11th 04 08:25 PM |
Autorotation ? R22 for the Experts | Eric D | Rotorcraft | 22 | March 5th 04 06:11 AM |
