COLIN LAMB wrote:
Question - will the reading of the pulse oximeter discriminate against carbon monoxide? In other words, does the use of a pulse oximeter reduce the need of a carbon monoxide detector? If carbon monoxide replaces oxygen, then the % of oxygen would decrease and the oximeter would drop substantially when carbon monoxide is present? Right? I've never seen anything discussing the issue at all, so I'm guessing it doesn't (not so much an issue for my ASH 26 E). Jim Skydell had an article in Soaring about oximeters earlier, so you might check with him. He's much more knowledgeable about them than I am. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
COLIN LAMB wrote:
Question - will the reading of the pulse oximeter discriminate against carbon monoxide? Great question Colin. The answer is NO. I had to look it up (from an article in the medical literature by Neil B. Hampson): "Presently available pulse oximeters overestimate arterial oxygenation in patients with severe CO [carbon monoxide] poisoning. An elevated COHb [carbon monoxide bound to hemoglobin] level falsely elevates the [level of oxygen in the blood] as measured [by] pulse oximetry, (CHEST 1998; 114:1036-1041)" What this means is that carbon monoxide, when attached to a hemoglobin molecule (which carries oxygen within red blood cells) fools pulse oximeters into thinking there is more oxygen in the blood than there really is. This is not surprising, since oximetry basically does an analysis of blood color (the redder the blood, the more oxygen it should be carrying). One way to guess that a patient has carbon monoxide poisoning is that their skin and lips frequently look very red. In other words, does the use of a pulse oximeter reduce the need of a carbon monoxide detector? If carbon monoxide replaces oxygen, then the % of oxygen would decrease and the oximeter would drop substantially when carbon monoxide is present? Right? Wrong. Although carbon monoxide does replace oxygen on the hemoglobin molecule, it fools the oximeter in thinking there is more oxygen, when there really is less. Regards, Jim Skydell |
![]() "COLIN LAMB" wrote in message hlink.net... Question - will the reading of the pulse oximeter discriminate against carbon monoxide? In other words, does the use of a pulse oximeter reduce the need of a carbon monoxide detector? If carbon monoxide replaces oxygen, then the % of oxygen would decrease and the oximeter would drop substantially when carbon monoxide is present? Right? Colin N12HS --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.783 / Virus Database: 529 - Release Date: 10/25/04 Pulse oximetry cannot distinguish between different forms of haemoglobin. Carbo-xyhaemoglobin (haemoglobin combined with carbon monoxide) is registered as 90% oxygenated haemoglobin and 10% desaturated haemoglobin - therefore the oximeter will overestimate the saturation. The presence of methaemoglobin will prevent the oximeter working accurately and the readings will tend towards 85%, regardless of the true saturation. So the answer to your question is - you still need a CO monitor if there's an engine about. Ian |
What's minimum safe O2 level? | PaulH | Piloting | 29 | November 9th 04 07:35 PM |
Reprise - Oxygen concerns | Neptune | Soaring | 20 | May 27th 04 03:27 PM |
Need oxygen information | Neptune | Soaring | 3 | May 10th 04 06:06 AM |
Catastrophic Decompression; Small Place Solo | Aviation | Piloting | 193 | January 13th 04 08:52 PM |
