A TE probe on a wing would certainly be a very bad idea as the pressure
field near the wing will not show linear variations with angle of attack... -- Bert Willing ASW20 "TW" "Eric Greenwell" a écrit dans le message de news: ... Paul Remde wrote: Hi, I have a question for motorglider owners. I sell variometers and TE probes but I'm still learning. A customer is building a Europa motorglider and he is wondering if he can mount a TE probe on the fin and connect it to the variometer, or will the propwash cause problems. The reading will bounce around, but usable except when trying to center weak lift while under power. Is it necessary to use some sort of pneumatic switch to switch between TE and static input for the variometer? It would likely help. His pitot and static ports are on a boom that is mounted to the wing. Since he is building it, I suggest he consider a TE tube on the wing, clear of the prop wash. That should be easy, since he is already doing that with the pitot and static. Or, use a vario with electronic TE and just use the pitot/static. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Hi,
Is angle of attack a big part of TE compensation? I thought it was mainly pressure changes due to airspeed changes. I'll have to do some reading on this. I think New Soaring Pilot by Welch and Irving has some good information. Thanks, Paul Remde "Bert Willing" wrote in message ... A TE probe on a wing would certainly be a very bad idea as the pressure field near the wing will not show linear variations with angle of attack... -- Bert Willing ASW20 "TW" "Eric Greenwell" a écrit dans le message de news: ... Paul Remde wrote: Hi, I have a question for motorglider owners. I sell variometers and TE probes but I'm still learning. A customer is building a Europa motorglider and he is wondering if he can mount a TE probe on the fin and connect it to the variometer, or will the propwash cause problems. The reading will bounce around, but usable except when trying to center weak lift while under power. Is it necessary to use some sort of pneumatic switch to switch between TE and static input for the variometer? It would likely help. His pitot and static ports are on a boom that is mounted to the wing. Since he is building it, I suggest he consider a TE tube on the wing, clear of the prop wash. That should be easy, since he is already doing that with the pitot and static. Or, use a vario with electronic TE and just use the pitot/static. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Sorry if I gave reasons to misinterprete.
TE is based on pressure changes due to changes in speed (which in turn are caused by changes of angle of attack). But you can expect the pressure change to be significantly different in the vicinity of the wing, than in a free flow section, so the TE would not read correctly for the whole range of airspeed. That's the reason why TE's are mounted either above the middle of the tail boom, or something like half a meter in front of the wing. -- Bert Willing ASW20 "TW" "Paul Remde" a écrit dans le message de news: pT0pd.79775$V41.37553@attbi_s52... Hi, Is angle of attack a big part of TE compensation? I thought it was mainly pressure changes due to airspeed changes. I'll have to do some reading on this. I think New Soaring Pilot by Welch and Irving has some good information. Thanks, Paul Remde "Bert Willing" wrote in message ... A TE probe on a wing would certainly be a very bad idea as the pressure field near the wing will not show linear variations with angle of attack... -- Bert Willing ASW20 "TW" "Eric Greenwell" a écrit dans le message de news: ... Paul Remde wrote: Hi, I have a question for motorglider owners. I sell variometers and TE probes but I'm still learning. A customer is building a Europa motorglider and he is wondering if he can mount a TE probe on the fin and connect it to the variometer, or will the propwash cause problems. The reading will bounce around, but usable except when trying to center weak lift while under power. Is it necessary to use some sort of pneumatic switch to switch between TE and static input for the variometer? It would likely help. His pitot and static ports are on a boom that is mounted to the wing. Since he is building it, I suggest he consider a TE tube on the wing, clear of the prop wash. That should be easy, since he is already doing that with the pitot and static. Or, use a vario with electronic TE and just use the pitot/static. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Bert Willing wrote:
Sorry if I gave reasons to misinterprete. TE is based on pressure changes due to changes in speed (which in turn are caused by changes of angle of attack). But you can expect the pressure change to be significantly different in the vicinity of the wing, than in a free flow section, so the TE would not read correctly for the whole range of airspeed. That's the reason why TE's are mounted either above the middle of the tail boom, or something like half a meter in front of the wing. I didn't think about this effect when I made the suggestion; however, I think the builder should install one in the tail and one on the wing, as it won't cost very much. The tail TE probe will surely work for gliding, and might be OK under power; the wing TE probe might work all the time, or at least, it might be better than the statics if the tail TE probe isn't good under power. The speed range of the Europa while gliding is likely small enough that a superb TE system is not required. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Miniature toggle routing valves are also available
through MSC Industrial Supply Co. mail order. This is page 3950 of their on-line PDF catalog. Note the routing valve at mid-page. http://tinyurl.com/5hv9o This is their web site. http://tinyurl.com/629x5 At 20:30 23 November 2004, Tim Mara wrote: Clippard Industries in Cincinnati Ohio makes several types of Pneumatic switches..... these were commonly used years ago back when sailplane pilots used to have to make their own and a few variometer manufacturers like Richard Ball made alternative Pneumatic inputs for Netto's and Speed to Fly variometers from normal TE variometers tim 'Paul Remde' wrote in message news:f%Lod.141383$R05.121337@attbi_s53... Hi, I received a few very nice e-mails from reputable sources recommending the use of a pneumatic switch to switch between TE and Static input for a motorglider. That is good information. This newsgroup is fantastic! It was suggested that the switch could be made to be automatic. That sounds great. It is my understanding that even very small leaks can cause large inaccuracies in TE functionality - so we must be careful about that of course. Does anyone have any recommendations for manual or automatic pneumatic switches? It would be great to get feedback from someone who has done this already. Thank you, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com 'Paul Remde' wrote in message news:NwKod.141170$R05.69144@attbi_s53... Hi, I have a question for motorglider owners. I sell variometers and TE probes but I'm still learning. A customer is building a Europa motorglider and he is wondering if he can mount a TE probe on the fin and connect it to the variometer, or will the propwash cause problems. Is it necessary to use some sort of pneumatic switch to switch between TE and static input for the variometer? His pitot and static ports are on a boom that is mounted to the wing. Thank you, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com |
Paul,
Yes you need a pneumatic switch, basically it turns your TE vario into a VSI. I had both my LNAV and Sage behind the pneumatic switch and found that the changeover between static pressure and TE pressure wrecks the sage (not nice watching it spin round and round). I moved the sage in front of the switch so it gets TE pressure all the time, it's uselesss when the engine is running (the LNAV indicates vertical speed just fine) but at least it's a little kinder to the instrument. Doug "Paul Remde" wrote in message news:NwKod.141170$R05.69144@attbi_s53... Hi, I have a question for motorglider owners. I sell variometers and TE probes but I'm still learning. A customer is building a Europa motorglider and he is wondering if he can mount a TE probe on the fin and connect it to the variometer, or will the propwash cause problems. Is it necessary to use some sort of pneumatic switch to switch between TE and static input for the variometer? His pitot and static ports are on a boom that is mounted to the wing. Thank you, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com |
If the TE probe is mounted at half-span or more, will
any application of bank not cause a correctly-compensated TE to read climb or descent [because the mounting point is moving up or down as bank is applied] ? Is this significant ? Ian At 15:31 24 November 2004, Bert Willing wrote: Sorry if I gave reasons to misinterprete. TE is based on pressure changes due to changes in speed (which in turn are caused by changes of angle of attack). But you can expect the pressure change to be significantly different in the vicinity of the wing, than in a free flow section, so the TE would not read correctly for the whole range of airspeed. That's the reason why TE's are mounted either above the middle of the tail boom, or something like half a meter in front of the wing. -- Bert Willing ASW20 'TW' 'Paul Remde' a écrit dans le message de news: pT0pd.79775$V41.37553@attbi_s52... Hi, Is angle of attack a big part of TE compensation? I thought it was mainly pressure changes due to airspeed changes. I'll have to do some reading on this. I think New Soaring Pilot by Welch and Irving has some good information. Thanks, Paul Remde 'Bert Willing' wrote in message ... A TE probe on a wing would certainly be a very bad idea as the pressure field near the wing will not show linear variations with angle of attack... -- Bert Willing ASW20 'TW' 'Eric Greenwell' a écrit dans le message de news: ... Paul Remde wrote: Hi, I have a question for motorglider owners. I sell variometers and TE probes but I'm still learning. A customer is building a Europa motorglider and he is wondering if he can mount a TE probe on the fin and connect it to the variometer, or will the propwash cause problems. The reading will bounce around, but usable except when trying to center weak lift while under power. Is it necessary to use some sort of pneumatic switch to switch between TE and static input for the variometer? It would likely help. His pitot and static ports are on a boom that is mounted to the wing. Since he is building it, I suggest he consider a TE tube on the wing, clear of the prop wash. That should be easy, since he is already doing that with the pitot and static. Or, use a vario with electronic TE and just use the pitot/static. -- Change 'netto' to 'net' to email me directly Eric Greenwell Washington State USA |
I think it would cause significant errors because there
are unavoidable but detectable errors in fin mounted TE probes from the relative but small downwards motion of the tail end of the glider as you pull up (in addition to the g effects). The relative motion would be much greater between the fuselage and mid span in rolling than between the fin and centre of rotation in pitching. The best place for a TE probe that is not on the fin would be far in front of the nose. In that position the vertical movement effects would counteract the g effects. John Galloway At 22:30 25 November 2004, Ian Cant wrote: If the TE probe is mounted at half-span or more, will any application of bank not cause a correctly-compensated TE to read climb or descent [because the mounting point is moving up or down as bank is applied] ? Is this significant ? Ian At 15:31 24 November 2004, Bert Willing wrote: Sorry if I gave reasons to misinterprete. TE is based on pressure changes due to changes in speed (which in turn are caused by changes of angle of attack). But you can expect the pressure change to be significantly different in the vicinity of the wing, than in a free flow section, so the TE would not read correctly for the whole range of airspeed. That's the reason why TE's are mounted either above the middle of the tail boom, or something like half a meter in front of the wing. -- Bert Willing ASW20 'TW' 'Paul Remde' a écrit dans le message de news: pT0pd.79775$V41.37553@attbi_s52... Hi, Is angle of attack a big part of TE compensation? I thought it was mainly pressure changes due to airspeed changes. I'll have to do some reading on this. I think New Soaring Pilot by Welch and Irving has some good information. Thanks, Paul Remde 'Bert Willing' wrote in message ... A TE probe on a wing would certainly be a very bad idea as the pressure field near the wing will not show linear variations with angle of attack... -- Bert Willing ASW20 'TW' 'Eric Greenwell' a écrit dans le message de news: ... Paul Remde wrote: Hi, I have a question for motorglider owners. I sell variometers and TE probes but I'm still learning. A customer is building a Europa motorglider and he is wondering if he can mount a TE probe on the fin and connect it to the variometer, or will the propwash cause problems. The reading will bounce around, but usable except when trying to center weak lift while under power. Is it necessary to use some sort of pneumatic switch to switch between TE and static input for the variometer? It would likely help. His pitot and static ports are on a boom that is mounted to the wing. Since he is building it, I suggest he consider a TE tube on the wing, clear of the prop wash. That should be easy, since he is already doing that with the pitot and static. Or, use a vario with electronic TE and just use the pitot/static. -- Change 'netto' to 'net' to email me directly Eric Greenwell Washington State USA |
Yes, it is necessary to have a switch that toggles between TE (free flight) &
Static (engine runs). If the TE is used during an engine start the vario needle pegs up very hard and could cause damage. I use a panel mounted Clippard Mini-Matic with a toggle switch (previously in a Ventus BT) and currently in my Nimbus 3T. Clippard has a great web-site and their dealer list is also provided. After finding the correct size, just call a dealer and they will UPS one to you. Steve (PSU) |
Lambada vs Sinus motorgliders | Andre van Niekekerk | Soaring | 2 | June 9th 04 11:28 AM |
Motorgliders (long) | JJ Sinclair | Soaring | 98 | October 9th 03 10:11 PM |
Motorgliders (long) | M B | Soaring | 1 | September 23rd 03 09:15 PM |
Latest Newsletter Pipistrel Motorgliders | Michael Coates | Home Built | 18 | September 19th 03 01:25 AM |
Latest Newsletter Pipistrel Motorgliders | Michael Coates | Soaring | 20 | September 19th 03 01:25 AM |
