![]() "Steve B" wrote in message ... I believe that the shoulder restraints are recommended to be anchored no more than 5 degrees below the shoulder and 30 degrees above the shoulder in a vehicle IIRC. In a glider I would think that the reclined position would change the dynamics of the restraint. Because of the reclined position I would think that there would be less of a tendency to compress the spine when the shoulder straps are under a load. Is the 5th strap and submerging the issue? Would a low anchor point help with the upward motion of the pilot? How would a low anchor point respond with a reclined seating position in a crash? Sounds like keeping your head intact is a primary concern and spine is secondary? So I am thinking 2nd set of straps with a low anchor point (for head to canopy interference) and the standard straps to keep from submerging (family jewels to 5th strap interference). Steve snip some stuff Okay, how about this: Below the adjusters on each of the shoulder straps, sew an extra strap. They should be long enough to go over your shoulders and Y together somewhere in the vicinity of the small of your back. A single strap continues down from there, through a slot in the seatpan, to a low anchor point. It continues through the rear low anchor point to a front low anchor point, where it becomes the crotch strap. Now tightening the crotch strap will also pull down on your shoulders. The low anchor point shouldn't compress your spine, because the rear low anchor point should be in front of your shoulders. Because the additional straps pull your shoulders down and forward, you can't slide up and back along the normal shoulder straps to bump your head. Because it's adjustable, it should fit more than one pilot. There's extra strap, but the same number of adjusters, so it shouldn't be too expensive. Obviously, a similar scheme could be used with two straps under the seat pan in a 6-point harness arrangement. Tim Ward |
