Eric Greenwell wrote:
Bob Fidler wrote: EaglePicher has a 9A same sixe as a 7A, cost me about $20. Can you give the model number and where you bought it? The only Eagle Picher I can find that is the same size as the usual 7 AH is also 7.2 AH. Even @ 7 ah, we should support our own. The President of Eagle Picher flies a Discus 2! |
I used to offer Eagle Picher batteries.......the spec's looked impressive
but honestly I had more complaints with these than all other types I offered and ended up replacing more and more often than others....finally elected not to continue with this brand and offer now just Powersonic batteries.......these are low cost and have proven to be excellent. tim www.wingsandwheels.com "Bob Fidler" wrote in message ... Eagle Picher Model No. CF-12V9 1-800-201-0215 or I purchased from a local battery store in Michigan: Batteries Plus 248-644-0666 "Eric Greenwell" wrote in message ... Bob Fidler wrote: EaglePicher has a 9A same sixe as a 7A, cost me about $20. Can you give the model number and where you bought it? The only Eagle Picher I can find that is the same size as the usual 7 AH is also 7.2 AH. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
These 8Ah batteries have worked well for me.
http://www.zbattery.com/zbattery/hr9-12b1.html They are 'High Rate' batteries, which appear to work better under the ~1A that my panel draws. Even so, each battery last about 5 hours. 9B At 23:30 12 January 2005, wrote: Nobody has mentioned the obvious. Not everybody is using the same discharge time. Some are 10 hr, some are 20 hr rates. It makes a difference. Easily enough to change the ads. Longer times (lower discharge rates) make their advertising look better. The other technique is to change the discharged voltage, or the charged voltage. If you want a better comparison, find the curves and compare them. And the weights. And the size. You might be surprised to find that there is little difference in the capacities. Chemistry is chemistry. The other item is to pick a bingo voltage that is correct for the application, not the battery. Compare the curves down to that point. If the radio or other electronics start to go south at 11 volts, while loaded, the curve below 11 volts will not take care of everything that you want to do. Hence twice the batteries so that the amp-hours are way up there, cause you can only use a part of them. Dennis Eric Greenwell wrote in message ... Bob Fidler wrote: EaglePicher has a 9A same sixe as a 7A, cost me about $20. Can you give the model number and where you bought it? The only Eagle Picher I can find that is the same size as the usual 7 AH is also 7.2 AH. -- Change 'netto' to 'net' to email me directly Eric Greenwell Washington State USA |
Udo,
After 20 years on a 12-volt system, I've returned to 14 volts, completely eliminating all problems with battery life. I'm using the PS 12/8 with a 2 volt piggy back. I am very happy with the results. Like Ken, I purchase my batteries from ragebattery. |
Several questions about this thread.
1. How does one piggyback (physical sense) a 2 volt batter on top of the twelve in a well (i.e. Discus) that clamps securely around the 12v battery? 2. How does one identify the dimensions of all the various 12v. batteries offered by ragebatteries? (I just looked at the site suggested two posts back on this thread.) 3. Has anyone ever manufactured a 14v. battery that would be usable? At 01:00 14 January 2005, wrote: Udo, After 20 years on a 12-volt system, I've returned to 14 volts, completely eliminating all problems with battery life. I'm using the PS 12/8 with a 2 volt piggy back. I am very happy with the results. Like Ken, I purchase my batteries from ragebattery. |
The rage site has a physical data sheet for each battery ... or you
could go to the manufacturers site to see dimensions of the entire line. 2. How does one identify the dimensions of all the various 12v. batteries offered by ragebatteries? (I just looked at the site suggested two posts back on this thread.) |
Nyal,
A picture would be best, but here's the narrative. I use hook locks (a substantial step up from velcro) to mate the batteries. I place the back (based on brand position) of the 2V against the terminal end of the 12V about 1 inch above the bottom. This provides clearance at the front of the battery tray and puts the 2V terminals slightly above the 12V terminals. I then use strapping tape to secure the attachment between the hook and lock pads. I tested this arrangement by placing both batteries in the tray of my Ventus 2 while trailering several hundred miles. It has proven more than adequate. I inspect the bond regularly and have found no weakening. Wiring is in series. Be sure to include a fuse. If you have a strong interest, I'll be happy to forward a photo. My wife uses the same set up in her LS-8. The 14V system has dramatically improved the transmission quality and strength of her Microair radio. I am finding I can fly about 7 hours per 14V battery before I'm seeing 14.3V. I generally start the flight around 15.1V. I run an SN-10 with one analog, Dittel FSG-2T, Cambridge Model 25 Data logger and read out, a flap position LED, and gear warning. With a 12V system, my SN-10 would start giving me voltage warning around 4 hours and my radio would become discerably less reliable. The PowerSonic model numbers are PS-1280 (12V) and PS-260 (2V). Rage doesn't appear to carry the 1280 anymore. Try W&W. Nyal Williams wrote: Several questions about this thread. 1. How does one piggyback (physical sense) a 2 volt batter on top of the twelve in a well (i.e. Discus) that clamps securely around the 12v battery? 2. How does one identify the dimensions of all the various 12v. batteries offered by ragebatteries? (I just looked at the site suggested two posts back on this thread.) 3. Has anyone ever manufactured a 14v. battery that would be usable? At 01:00 14 January 2005, wrote: Udo, After 20 years on a 12-volt system, I've returned to 14 volts, completely eliminating all problems with battery life. I'm using the PS 12/8 with a 2 volt piggy back. I am very happy with the results. Like Ken, I purchase my batteries from ragebattery. |
I would appreciate the photo very much. There are
no gimmicks in my address. . One further concern is whether 15.1v be too much for my Volkslogger? I believe the L-Nav and the Dittel radio would take it ok. I'll check that out, but I believe the specs say that it will handle up to 20v. Thanks! Nyal At 21:00 14 January 2005, wrote: Nyal, A picture would be best, but here's the narrative. I use hook locks (a substantial step up from velcro) to mate the batteries. I place the back (based on brand position) of the 2V against the terminal end of the 12V about 1 inch above the bottom. This provides clearance at the front of the battery tray and puts the 2V terminals slightly above the 12V terminals. I then use strapping tape to secure the attachment between the hook and lock pads. I tested this arrangement by placing both batteries in the tray of my Ventus 2 while trailering several hundred miles. It has proven more than adequate. I inspect the bond regularly and have found no weakening. Wiring is in series. Be sure to include a fuse. If you have a strong interest, I'll be happy to forward a photo. My wife uses the same set up in her LS-8. The 14V system has dramatically improved the transmission quality and strength of her Microair radio. I am finding I can fly about 7 hours per 14V battery before I'm seeing 14.3V. I generally start the flight around 15.1V. I run an SN-10 with one analog, Dittel FSG-2T, Cambridge Model 25 Data logger and read out, a flap position LED, and gear warning. With a 12V system, my SN-10 would start giving me voltage warning around 4 hours and my radio would become discerably less reliable. The PowerSonic model numbers are PS-1280 (12V) and PS-260 (2V). Rage doesn't appear to carry the 1280 anymore. Try W&W. Nyal Williams wrote: Several questions about this thread. 1. How does one piggyback (physical sense) a 2 volt batter on top of the twelve in a well (i.e. Discus) that clamps securely around the 12v battery? 2. How does one identify the dimensions of all the various 12v. batteries offered by ragebatteries? (I just looked at the site suggested two posts back on this thread.) 3. Has anyone ever manufactured a 14v. battery that would be usable? At 01:00 14 January 2005, wrote: Udo, After 20 years on a 12-volt system, I've returned to 14 volts, completely eliminating all problems with battery life. I'm using the PS 12/8 with a 2 volt piggy back. I am very happy with the results. Like Ken, I purchase my batteries from ragebattery. |
On their way. Is the ellipses in your email address intended?
Batteries, charger for Yaesu handheld - NiCad or NiMH? | David Herman | Owning | 10 | November 7th 04 04:30 PM |
14 Volt Gel Cell? | Joe Allbritten | Soaring | 32 | May 11th 04 01:37 AM |
Icom A5 Battery Tester ?? | Harry Gordon | Piloting | 5 | January 10th 04 01:29 PM |
ICom A-5 Question - Battery Level Indicator | Harry Gordon | Piloting | 22 | December 5th 03 12:07 AM |
Battery life...how to test? | Jim Kelly | Soaring | 2 | July 11th 03 09:12 PM |
