At 12:00 16 January 2005, John Galloway wrote:
In another thread Ian Strachan wrote: 'The standard recovery procedure once a full spin has developed that works for most aircraft is, 1. Full rudder opposite to the spin direction (make sure it really is opposite to the rotation, I for one have applied the wrong rudder in a spinning jet when I was caught by a surprise departure).' ======================================= I have long surmised that application of the wrong rudder in a panic situation might be a cause of failure to recover from a spin. If it can happen to a military test pilot of Ian's calibre then it can certainly happen to me. The yaw string *always* points to the inside of a spin (according the Reichmann and others) and modifying the teaching to 'apply full rudder opposite to the direction of the yaw string' would be a more certain way of choosing the life rudder pedal rather than the death one at low altitude Slip balls do not, apparently, invariably point to the outside of spins so they are not as certain a guide. 'Every saiplane should have a yaw string' - said Helmut Reichmann for this reason. John Galloway Good post, but I must point out a trap. I learned from a student that it is easy to misunderstand which end of the string is doing the pointing. I always taught students to 'step on the head of the snake.' One student could never get it right (never been around snakes) and he was stepping on the tail -- the aft, unattached end. I found that other students had figured out their own way of bringing the string into line and just ignored my comments. We should have a conversation with students specifically about which end of the yaw string is the pointer/tail/indicator, etc. and which foot does what to that end of the string under discussion. On the other hand, perhaps my analogies are just weird. |
![]() "Nyal Williams" wrote in message ... We should have a conversation with students specifically about which end of the yaw string is the pointer/tail/indicator, etc. and which foot does what to that end of the string under discussion. View the string as a pointer. The forward end (the point) points at the required rudder pedal. Duane |
![]() "Duane Eisenbeiss" wrote in message ... "Nyal Williams" wrote in message ... We should have a conversation with students specifically about which end of the yaw string is the pointer/tail/indicator, etc. and which foot does what to that end of the string under discussion. The above post was incomplete. Over sensitive Send button. View the string as a pointer. The forward end (the point) points at the required rudder pedal to continue the turn or stop yaw. Therefore opposite rudder in a spin would be the other rudder pedal or the top of the string. Duane |
Duane Eisenbeiss wrote:
The above post was incomplete. Over sensitive Send button. View the string as a pointer. The forward end (the point) points at the required rudder pedal to continue the turn or stop yaw. It is impossible for the forward end to "point" at anything, since it is fixed in place by tape. The string pivots around its stationary forward end. Any "pointing" is of course done by the free aft end of the string, away from the pivotal point. Same thing as the hands of a clock. The minute hand points "right", not left, at five past twelve. If you give left rudder you will slip to the right and the string will point left. Cheers CV |
CV wrote:
Duane Eisenbeiss wrote: The above post was incomplete. Over sensitive Send button. View the string as a pointer. The forward end (the point) points at the required rudder pedal to continue the turn or stop yaw. It is impossible for the forward end to "point" at anything, since it is fixed in place by tape. The string pivots around its stationary forward end. Any "pointing" is of course done by the free aft end of the string, away from the pivotal point. Same thing as the hands of a clock. The minute hand points "right", not left, at five past twelve. If you give left rudder you will slip to the right and the string will point left. So do you tell students that the wind sock points to where the wind is going? Impossible or not, by using my *imagination* early in my flying career, I was able to simply and quickly make sense of what the yaw string was indicating without having to think about where the relative wind was coming from, or which pedal to push. Jeez. Shawn |
"Apply full rudder opposite to the direction of the yaw string" -- what
does that mean? What is the direction of the yaw string? If the loose end of the yaw string is on the right side of the canopy, is the direction of the yaw string to the right, or is it to the left? I think you mean that if the loose end of the yaw string is on the right side of canopy, you apply right rudder? Or the opposite of the normal rule? The yaw string *always* points to the inside of a spin (according the Reichmann and others) and modifying the teaching to 'apply full rudder opposite to the direction of the yaw string' would be a more certain way of choosing the life rudder pedal rather than the death one at low altitude |
At 18:30 16 January 2005, Nyal Williams wrote:
Good post, but I must point out a trap. I learned from a student that it is easy to misunderstand which end of the string is doing the pointing. I always taught students to 'step on the head of the snake.' One student could never get it right (never been around snakes) and he was stepping on the tail -- the aft, unattached end. I found that other students had figured out their own way of bringing the string into line and just ignored my comments. We should have a conversation with students specifically about which end of the yaw string is the pointer/tail/indicator, etc. and which foot does what to that end of the string under discussion. On the other hand, perhaps my analogies are just weird. I don't think they are weird, mine were 'kick the ball' and 'draw the string'. Of course these days I never have to use them that is why I remember them so well. Isn't stepping on snakes a bit dangerous? :-) |
At 19:00 16 January 2005, Greg Arnold wrote:
'Apply full rudder opposite to the direction of the yaw string' -- what does that mean? What is the direction of the yaw string? If the loose end of the yaw string is on the right side of the canopy, is the direction of the yaw string to the right, or is it to the left? Seems like there is some potentially confusing terminology being used here that I've never heard before. I've always been taught that the the 'direction' of the yaw string is the side of the glider it leans to, and so you correct by pressing the rudder on the opposite side. Here I think people are saying that if the yaw string is displaced to the right side of the glider it is 'pointing' left. While I can understand how you might naturally want the front end to be the tip of the 'pointer', I think it's confusing to refer to 'pointing' at all because of this left/right confusion. I prefer to say the yaw string is 'to the left' or 'to the right' as position is less ambiguous that the 'pointing' direction. To be honest, I've never looked at the yaw string in a spin as it has never been ambiguous to me which way the world was turning - if the world is going round and round counter-clockwise how can this not be spinning to the right? I guess I presumed that for a spin to persist the glider would have to stay skidding, but in a fully established spin you might wonder, if the yaw string was far enough forward (say in a two-seater), whether the rotation overcomes the skid in terms of the local flow across the canopy - apparently not given the comments here. Boy I'd hate for that to be wrong though. Years ago when I was flying a Ventus A 16.6 (easy to spin unintentionally in my experience) I taught myself that if the inside wing in a turn ever dropped, to push the stick forward and into the turn and to hit top rudder. You try to make it as instinctive as possibe, but it takes practice. The top rudder is the easiest part - the stick movement is against most people's instincts. 9B |
Andy,
Remember my spin entry tests in the V2b a year and a half ago. One of the departures was so violent, I lost reference, and even though I knew which way I entered, I can see how a surprise stall with the same sort of departure could cause disorientation and application of pro spin rudder. At low altitudes (during a save, for instance), the delay in recovery could be very bad news. As for spin dynamics, it might be interesting to look at airfoil tufts throughout to see what's going on. Anyone have a link? I think most of us envision a spin as a straight line down, the aircraft rotating about this axis. That seems too simple. At any rate, the yaw string should always be displaced into the direction of spin (or average there if oscillating). Staying in the spin requires that the inside wing be producing higher drag (as a result of AOA), and thus the pro-rotation displacement. I won't be able to fly until April, but maybe one of you southwestern types could provide some video of the yaw string through 2 or three full rotations. We can discuss this ad nauseum, but a few pictures would make the discussion much more interesting and possibly fruitfull. Andy, you up for it? |
Spin Training | JJ Sinclair | Soaring | 6 | February 16th 04 04:49 PM |
String in the middle does not protect you from a spin | Jim | Soaring | 10 | January 30th 04 02:57 PM |
Cessna 150 Price Outlook | Charles Talleyrand | Owning | 80 | October 16th 03 02:18 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
