A new direction for an old thread: Crosswind landings
Old February 21st 05, 10:55 AM
Graeme Cant
Bruce Hoult wrote:
If you want, you can side slip and when close to the ground use the
ailerons to level the wings. You are then in precisely the same
situation as if you crabbed and then kicked in rudder, except that
levelling the wings is probably easier and less critical than precisely
timing and judging a bootfull of rudder.
I think both are equally hard/easy in timing. Levelling the wings and
yawing straight both start the aircraft moving sideways across the
runway/strip and require the same accuracy of timing.
Judging the required control input is different. You used the phrase
"use the ailerons to level the wings". Why didn't you say "use rudder
to yaw the glider straight"?
The colourful phrase you actually used - "a bootfull of rudder" - from
an instructor has probably caused more students to find crosswind
landings difficult than any other aspect of the manoeuvre. Do you teach
the final part of a slipped landing as "shove the stick over"?
In my experience, old multiengine pilots like to crab and use rudder.
Old single engine pilots like to slip and use aileron. Which technique
is used just reflects the tribe you give your allegiance to. Both of
them work well if taught properly.
GC
Old February 21st 05, 11:31 AM
Stefan
My opinion exactly. How many pilots use slipping to correct for wind
while flying cross country? My wild guess is: none. We all crab without
even talking about it. So what is the reason they don't do so during the
landing?
I can think of only two reasons: They've never learnt to master the
rudder or they've never learnt to recognize and hold the runway axis
unless it's right ahead of their nose. Both reasons claim for more
training, not a change of method.
Stefan
Old February 21st 05, 12:29 PM
Bert Willing
Additionally, if you don't crab to stay centered during final, you stalling
speed will be higher. I never saw anybody slipping for wind correction in a
glider in Europe...
Bert Willing
ASW20 "TW"
"Stefan" a écrit dans le message de news:
"use the ailerons to level the wings". Why didn't you say "use rudder to
The colourful phrase you actually used - "a bootfull of rudder" - from an
instructor has probably caused more students to find crosswind landings
My opinion exactly. How many pilots use slipping to correct for wind while
flying cross country? My wild guess is: none. We all crab without even
landing?
I can think of only two reasons: They've never learnt to master the rudder
or they've never learnt to recognize and hold the runway axis unless it's
right ahead of their nose. Both reasons claim for more training, not a
change of method.
Stefan
Old February 21st 05, 04:33 PM
Bruce,
An even better way to think of this is simply to let the dihedral
effect roll the wings level. An intent to "roll" the glider level will
produce aileron drag with a yaw in the wrong direction. Since we're
holding stick into the slip, the process only requires a relaxation of
this force. And not even to neutral.
That said, the majority of competent crosswind landings I've seen in
open class ships usually involve flying the glider (wing low) onto the
runway. The big gliders clearly require greater competence and a more
flexible, not necessarily ideal approach to dealing with such problems.
Also, I note that Don used the words "Kick off the drift." This is
inaccurate. Since the crab is used to track down the runway, there is
no longer a "drift." He is, in fact, kicking to align the gear with the
runway. I point this out because sloppiness with terminology percolates
up to our understanding of the model. And then back down to the control
inputs we make.
As for concerns of yawing while increasing angle of attack, remember
you are near the ground. The real disadvantage of the wings level skid
to align the gear is that you are introducing an unbalanced force. If
your touch down is delayed, or you bounce, you will begin to turn
downwind. It is an interesting dilemma. On the one hand, the alignment
slip requires greater skill and understanding. On the other, the
alignment skid requires a "touch" on both the rudder and the stick. I
suspect the wings level approach is safer of low time pilots since they
have greater controlability in the event of turbulence. But the wing
low landing is easier since control movements are intuitive.
There is a great big HOWEVER. A wing low landing into crops is
completely unacceptable (as is flying the glider on). Each method has
its role. We should be competent at both. But to be competent we need
to clearly understand not just the obvious differences, but the
similarities as well.
Those of you who would prefer not to make the "additive" argument in
public, please back channel. I am genuinely interested in understanding
why this concept works... or perhaps, doesn't.
OC
Bruce Hoult wrote:
Don Johnstone wrote:
Can't speak for 25 metres but I can for 20 metres and
it's crabbing. I fly an ASW 17 and the tips are not
that far from the ground, even when the wings are level,
and sideslipping (using bank) near the ground has never
appealed to me. My aim is to keep the wings level near
the ground and kick off the drift at the point of flare
but I have often wondered if it is a really good idea
to apply yaw at the same time as increasing the angle
of attack of the wing. Of course to conteract the further
effect of rudder opposite aileron may have to be applied
to keep the wings level but can be avoided by not being
too heavy footed with the rudder.
precisely
Bruce | 41.1670S | \ spoken | -+-
Hoult | 174.8263E | /\ here. | ----------O----------
Old February 22nd 05, 05:29 AM
Bob Korves
I fly a lot at a mountain site where the winds can be strong, gusty and
turbulent; 20 to 60 degrees (or more) off the runway heading, and constantly
changing. The pattern there can be wicked at times. I am flying 18 and 20
meter gliders off a runway that is 75 feet (22.9 meters) wide with lights,
sagebrush, and rocks past the edges.
On days like that and at places like that there is no time for asking myself
whether I should slip or crab. I just want to get the damn sailplane down
in one piece. For flying like this you need to have your spurs on (be
proactive and decisive). The only rules a Don't ground loop. Don't
cartwheel. Don't hurt the pilot or glider.
I would bet that if you debriefed me just after I stopped and got out of the
glider, I would not be able to tell you very well what I had just done. One
just does what is necessary to get down safely. When you get it slowed down
somewhere near the ground in the middle of the runway and pointed pretty
much down the runway, you had better plant it right then. Better safe than
pretty.
I do know that I have used a combination slip and crab many times, just so I
don't run out of control travel before I get the desired response. Is that
additive? You just lift the upwind wing before it hits the runway and use
rudder as needed to establish/maintain heading. The upwind wing stays
slightly down throughout the flare and rollout.
At a sea level site with a steady wind and no upwind obstructions one can
(yawn) take the time to worry about style points for slipping or crabbing
approaches. :-)
Teaching pilots to fly is, of course, a very different proposition.
-Bob Korves
Bruce,
inputs we make.
OC
precisely
Old February 21st 05, 03:06 PM
Nyal Williams
One advantage for the slip is that it has the upwind
wing low at touchdown. I prefer to have that wing
just a bit down so that the wind is less likely to
get under it on rollout. (Same reason I want that
wing just a bit down for a crosswind launch.
final, you stalling
glider in Europe...
Bert Willing
ASW20 'TW'
'Stefan' a écrit dans le message de news:
You used the phrase
'use the ailerons to level the wings'. Why didn't
you say 'use rudder to
yaw the glider straight'?
The colourful phrase you actually used - 'a bootfull
of rudder' - from an
crosswind landings
crab without even
do so during the
landing?
change of method.
Stefan
Old February 21st 05, 03:48 PM
Stefan
One advantage for the crab is that it has the wings level. I prefer to
have the wings level so that the grass is less likely to catch the wing
and cause a ground loop. Especially important when grass and wings are
both somewhat longer. (Same reason I carefully hold the wings level
during the launch.)
Stefan
Old February 21st 05, 05:20 PM
J.A.M.
Excuse me... I slip for crosswind correction on final, rather than crab
(wich I assume is to correct the wind with heading; sorry, english is not my
native language).
I find it more effective as the fuselage is already aligned with the runway,
and a more elegant manouevre as well.
I live in Spain. Does it count as Europe?
A lot of people does it here. I teach both methods, being crab easier to
grasp at the beggining, slipping more effective and elegant when the student
becomes proficient, IMHO.
Jose M. Alvarez.
ASW-24 'BR'
final, you stalling
glider in Europe...
Bert Willing
ASW20 'TW'
Old February 21st 05, 04:07 PM
Don Johnstone
level. I prefer to
to catch the wing
grass and wings are
the wings level
during the launch.)
Stefan
Amen to that. Long wings tend to be on the floppy side
as well. Do we want to expand this thread to include
launching?
Tailwheel Crosswind Landing Piloting 32 December 6th 04 02:42 AM
Thermal right, land left John Soaring 195 April 1st 04 11:43 PM
Baby Bush will be Closing Airports in California to VFR Flight Again Larry Dighera Piloting 119 March 13th 04 02:56 AM
Warszaw Pact War Plans ( The Effects of a Global Thermonuclear War ...) Matt Wiser Military Aviation 0 December 7th 03 08:20 PM
Dr. Jack's Wind Direction rjciii Soaring 14 October 5th 03 05:37 AM
