Safety and Hot Wire Foam Cutting
Old February 22nd 05, 10:45 PM
Default Safety and Hot Wire Foam Cutting
A friend of mine just bought a hot wire foam cutting tool for carving
and shaping polystyrene foam. My question is whether the fumes and
smoke from doing such carving are a safety/health hazard? Any
guidelines for using such a tool safely?
Thanks.
-Fleemo
Old February 23rd 05, 01:00 AM
MikeR
Thanks.
-Fleemo
YES! (Duh)
Any guidelines for using such a tool safely?
Don't snort the fumes. Don't touch the hot parts.
You're welcome.
Old February 23rd 05, 02:25 PM
Dude
"MikeR" wrote in message
Thanks.
-Fleemo
YES! (Duh)
You're welcome.
Welcome to Usenet, Fleemo!
Minus the 'tude, he is about right. I haven't seen or heard anything about
using a respirator to cut foam. Of course, they used to not worry about
asbestos either. If you are worried, use a respirator. You might as well
own a good one if you are going to be serious about building planes.
Old February 23rd 05, 02:29 PM
Jean-Paul Roy
Where can I find a hot wire cutting tool? Thanks ahead.
Jean-Paul
"Dude" wrote in message
Thanks.
-Fleemo
YES! (Duh)
You're welcome.
about
Old February 23rd 05, 05:07 PM
Thanks Dude, I appreciate the welcome.
about
about
well
I realize polysterene smoke is probably not something you want to
breathe in like the bouquet of a fine wine, but I was looking for input
on specifically how toxic it is and what steps need to be taken when
carving foam with a hot wire. Is working in a well-ventilated room
enough of a safety precaution, or is a respirator required?
Jean-Paul, check out http://www.HotWireFoamFactory.com
-Fleemo
Old February 23rd 05, 05:17 PM
W P Dixon
Hi,
Your best bet is to get a MSDS on the product you intend on hot cutting. The
product maker will send you one if you ask for it, and alot of them can be
viewed on different companies websites. The sheet will tell you what kinds
of protection you need, and what dangerous chemicals are involved, the
dangers of the product and will even tell you if your children will be born
with a arm sticking out of their forehead. Read the MSDS!
Just for safety sake, always wear a respirator when doing anything like
that. Make sure it is a proper respirator, remember a mask to keep wood dust
out of your lungs will not keep chemicals out! Make sure you have good
ventilation, and a fresh air system would be really nice.
Patrick
student SPL
aircraft structural mech
Old February 23rd 05, 05:28 PM
Dude
about
about
well
-Fleemo
Anyone telling you its safe is walking on thin ice. No one really knows, do
they?
I would not worry about it if I was going to build a plane or two. If I
were going to do it for a living, I would wear protection.
Old February 23rd 05, 07:31 PM
Ed Sullivan
Thanks.
-Fleemo
YES! (Duh)
You're welcome.
As I recall, urethane foam is toxic and shouldn't be hot wire cut. You
can make a cutter with an electric train transformer and stainless
wire on a bow type device. We made one, but it has been a couple of
hundred years ago.
Ed Sullivan
Old February 23rd 05, 08:35 PM
You
hundred years ago.
Yes. Urethane foam releases cyanide gas when heated. If you use
urethane in your plane and catch on fire the release of cyanide is
either a problem or a feature depending on whether or not your
burns are survivable.
Hot-wiring of polystyrene should be done in a well-ventilated
room while wearing a respirator. The respirator protects you
while cutting, the ventilation protects you after you remove
the respirator. You should should 'organic vapor' cartridges.
Be careful where you set teh hot wire down while it is still hot.
Have fun.
FF
Old February 23rd 05, 08:46 PM
Rich S.
There is foam - and then there is foam. Polystyrene foam smoke ain't bad,
but polyurethane foam smoke will give you a dirt nap. Go to
http://www.info-central.org/construction_hotwire.shtml for a good primer on
building a cutter and using it. Most modelers build their own cutter for a
couple of bucks and use a 12 volt power supply. Even a battery charger will
work.
Rich S.
