On Sat, 26 Feb 2005 14:48:17 -0500, "news.mcgraw-hill.com"
wrote in :: During a review of the V-speeds for an airplane I've never flown before, my instructor asked me about glide speed vs. weight, and total glide distance. I got the glide speed vs. weight part right, but the distance part seemed counterintuitive - that the total distance covered (by flying at the correct best glide speed for the weight) would be the same, regardless of the weight. Can anyone explain this so that it makes sense? Here's a clue: http://www.av8n.com/how/htm/power.ht...weight-effects The short answer is that the L/D is virtually unaffected by weight. For a more technical explanation, I've crossposted to rec.aviation.soaring. |
When you add weight to an aircraft ... all points on the polar shift to
the right. i.e. minimum stall increases ... the speed for minimum sink increases ... the speed for best L/D increases ... all almost the same magnitude at the speeds we typically fly at. So, if your L/D was 10:1 at 60 MPH when empty ... when loaded to gross it could be 10:1 .... but at 75 mph. So, if you were gliding from a mile up in a no wind situation ... you would go 10 miles distance in both cases ... but, of course, at a higher speed and in less time if you were heavy. Larry Dighera wrote: On Sat, 26 Feb 2005 14:48:17 -0500, "news.mcgraw-hill.com" wrote in :: During a review of the V-speeds for an airplane I've never flown before, my instructor asked me about glide speed vs. weight, and total glide distance. I got the glide speed vs. weight part right, but the distance part seemed counterintuitive - that the total distance covered (by flying at the correct best glide speed for the weight) would be the same, regardless of the weight. Can anyone explain this so that it makes sense? Here's a clue: http://www.av8n.com/how/htm/power.ht...weight-effects The short answer is that the L/D is virtually unaffected by weight. For a more technical explanation, I've crossposted to rec.aviation.soaring. |
![]() "news.mcgraw-hill.com" wrote: I got the glide speed vs. weight part right, but the distance part seemed counterintuitive It's not counterintuitive when you remember that extra weight at altitude is extra potential energy. The energy that was used to lift the weight to altitude can be recovered in the descent. -- Dan C172RG at BFM |
Take several aircraft at the same altitude. Make it a B-52 H since it can
carry over 300,000# of fuel so it can vary considerably in weight. Make one weigh 300,000#, another weigh 400,000#, and a third one weight 500,000#. The heavier the aircraft, the more energy it took to get it to that same altitude but once it's there and the engines are shut down the heaviest one has more potential energy (due to its greater weight affected by gravity). The heaviest aircraft would have a much higher driftdown speed than the lightest one and would reach the ground sooner than the others. It's higher speed would induce more drag so that would counter the greater energy available due to the greater weight. In no wind conditions all 3 should glide the same distance. The lightest one would stay aloft longest but at a slower driftdown speed producing the same glide distance. The driftdown vertical speed of the heaviest would be the highest. It would travel across the ground faster than the others... but for a shorter period of time. Throw in a wind and you dramatically change things. Gliding into a headwind the heaviest aircraft will glide the furtherest since it's effected by the headwind a shorter time. Gliding with a tailwind the lightest aircraft will glide the furtherest since it glides for a longer time thereby using the most tailwind assist. Darrell R. Schmidt B-58 Hustler History: http://members.cox.net/dschmidt1/ - "news.mcgraw-hill.com" wrote in message ... During a review of the V-speeds for an airplane I've never flown before, my instructor asked me about glide speed vs. weight, and total glide distance. I got the glide speed vs. weight part right, but the distance part seemed counterintuitive - that the total distance covered (by flying at the correct best glide speed for the weight) would be the same, regardless of the weight. Can anyone explain this so that it makes sense? |
more radial fans like fw190? | jt | Military Aviation | 51 | August 28th 04 04:22 AM |
Landing and T/O distances (Was Cold War ALternate Basing) | Guy Alcala | Military Aviation | 3 | August 13th 04 12:18 PM |
Buying an L-2 | Robert M. Gary | Piloting | 13 | May 25th 04 04:03 AM |
Angle of climb at Vx and glide angle when "overweight": five questions | Koopas Ly | Piloting | 16 | November 29th 03 10:01 PM |
