Sharing static and pitot line
Old March 7th 05, 08:08 AM
Istvan Csonka
Default Sharing static and pitot line
Dear All,
I have seen several posts about how to share the TE line between
e-vario and mechanical one. Maybe I am wrong but I can not see any
post about sharing the pitot pressure (dynamic) between ASI, e-vario
(computer) and and the only one static port between e-vario, altimeter
and mechanical vario.
Any good advice or this is not a problem at all ?
Old March 7th 05, 12:02 PM
John Giddy
On 7 Mar 2005 00:08:47 -0800, Istvan Csonka wrote:
Dear All,
The altimeter doesn't need to be connected to a static port unless you
plan on pressurising your glider ;-)
The most important instrument on the static port is the ASI, as this
measures very small changes in pressure, and the fluctuations in
cockpit pressure will make the ASI reading almost useless.
A vario on the static port will give you a completely uncompensated
vario. This is sometimes done for motorgliders to provide a VSI for
climbing under power, but would be unusual these days in a pure
glider. A vario using a capacity on the static line could give
transient errors on the ASI due to resistance in the tubing. If you
really want to do this, separate the tubes for ASI and vario as close
to the static port as possible to reduce common impedance.
Sharing the pitot line seems to be less of a problem, particularly if
the "e-vario" is a pressure one rather than a capacity type. However
if the e-vario is a flow-meter type with a typical 1 pint capacity, it
would be a good idea to separate the tubes as close to the pitot tube
as possible, for the same reason as separating the tubes to different
instruments from the static port or TE probe.
Cheers, John G.
Old March 7th 05, 02:59 PM
BB
I have run in to problems sharing a pitot between ASI and Cambridge
302, resulting in several very frustrating days at Hobbs one year where
it seemed as if I had forgotten to thermal. Separate pitots for the two
instruments solved the problem. Luckily, I have a tail pitot and a nose
pitot so each can have its own. The 302 seems particularly fussy about
having its own pitot and static sources however.
John Cochrane
Old March 7th 05, 09:13 PM
John Giddy
Recognize, however, that opening the window or vent, etc.
can vary your indicated altitude by a few hundred feet, not
to mention any regulatory compliance issues in your country.
Would need to be a very well sealed cockpit to show such a change in
pressure IMHO. I have never seen such a change, but I have seen ASI
errors of 5 or so knots (say 10 km/hr) with window/vent operation.
Compliance issues are not a problem in Australia.
Cheers, John G.
Old March 7th 05, 09:39 PM
1MoClimb
where
two
nose
about
John Cochrane
John,
I'm flying a 302 in my LS8 and cannot recall any problems in having it
attached to the same pitot that supplies pressure to the ASI. How
would you describe the behavior of the 302, just weird
deflections/audio signals?
Herb, J7
Old March 7th 05, 10:39 PM
I went through that learning curve with the 302 in Hobbs last summer.
The working combination was to have the 302's static and TE/static
ports connected to the same source, and (very important!) changing the
302's internal setup to use electronic TE. Once I did that, the 302's
vario and my B-40 danced to the same tune.
2NO
Old March 7th 05, 11:49 PM
Eric Greenwell
Based on my experience with my 302, I don't think it was the 302. On my
ASH 26 E, I went from a tail mounted TE feed to the 302 to using the ASI
pitot/static (electronic TE) with no detectable change in ASI or 302
operation. Just guessing: perhaps your connection involved a leak, or
maybe the 302 was not happy using a nose pitot and a TE probe and static
at the rear of the glider.
Eric Greenwell
Washington State
USA
Old March 8th 05, 12:08 PM
Istvan Csonka
Hello,
Maybe there was a misunderstanding.
I am asking advices for the following:
On a PIK20D, there are 4(four) tubes comming up from the cockpit at the panel:
1. Pitot from the nose
2. TE from the fin
3. Left rear fuselage static
4. Right rear fuselage static
What would be the best (optimal) tubing for the following instruments ?
1. Simple ASI
2. Simple Altimeter
3. Simple PZL mech vario
4. Peschges VP9
Old March 9th 05, 01:23 AM
Bob Korves
On the Pik-20D that I had there were 2 static holes on each side of the
boom, 4 holes total. IIRC, one left and one right hole pair were connected
to one tube toward the panel and the other left and right pair went to the
other tube. It was a good static system with very small position errors.
-Bob Korves
"T o d d P a t t i s t" wrote in message
panel:
2. TE from the fin
On all gliders I've looked at, the right and left tail boom
fuselage statics are hooked together with a T (in the tail)
to produce a single static signal that is insensitive to yaw
angle. I can't say if that's right for a PIK, but I'd be
surprised if it wasn't. You might also want to verify that
there are no under wing static holes. If not, it looks to
me like you have one static, one TE and one pitot.
The ASI needs static and pitot, the VP9 needs the TE. I
know of no reason not to hook altimeter to static with the
ASI, so that leaves the PZL and its capacity. In theory,
you can hook it to either static or TE. There is the
potential to interfere with other instruments when hooking
it either way, so I'd ignore it (leave it disconnected or
not installed) until after I was sure the other instruments
were working well. Then you can try hooking it to the
static or TE. My mechanical vario goes to my extra static
(I've got a pair under the wings, a pair on the boom and one
on the fin).
Old March 11th 05, 01:43 AM
Roger Druce
While on the matter of line sharing, the following is relevant to sharing
the Total Energy line between a number of flow variometers, mechanical
(Winter, PZL, etc.) and / or electrical (Cambridge CAV II etc.)
Each of the variometers fed by the one TE source have flow through the
instrument to their own flask.
All flasks running off one TE source must be the same physically and
thermodynamically. If you mix flasks with different characteristics then
you will get cross flow between the instruments. You can try this test on
the bench provided you do it carefully. Get two identical pneumatic varios
(with hopefully little inherent instrument error) and two diferent flasks,
say one vacuum flask with heat sink material inserted and the other a same
type vacuum flask without heat sink material inside. Apply a signal via a
Tee junction to the two variometers. Note the variometer readings of the
two variometers at different flow rates, ie calibrate one vario relative to
the other. They won't read the same! Then swap the flasks between the
variometers and repeat the calibration. The relative calibration will swap
over between the varios showing that the flasks are influencing things
strongly due to their different characteristics. Install identical flasks
and the varios will resume responding together.
So use identical flasks to avoid cross flow when using a common TE source.
Roger Druce
"Istvan Csonka" wrote in message
om...
Dear All,
Why are TE probes so long? Duane Eisenbeiss Soaring 36 May 9th 04 06:58 AM
Fine example of Tarver Engineering release for service running with scissors Military Aviation 79 March 3rd 04 01:48 PM
Fine example of Tarver Engineering release for service running with scissors Instrument Flight Rules 64 March 3rd 04 05:01 AM
Chuck Yeager-pitot tube Ron Military Aviation 44 October 9th 03 03:13 AM
Pitot and static couplings for a TTU-205 B2431 Home Built 0 August 15th 03 07:25 AM
