Speed of Heat
Old March 17th 05, 03:47 AM
Orval Fairbairn
In article
"Kurt R. Todoroff" wrote:
In article R5QZd.71896$Tt.15712@fed1read05,
"BTIZ" wrote:
All of the others talk of temperature rise do to compressibility based on
mach number, but no one really addressed the speed accounting for friction
of air molecules on the sheet metal which warms the aircraft. War story
time, low level over the plains of eastern Montana, near Conrad and Havre
Bomb Plots (Radar Bomb Scoring sites) and the outside air temp was
about -15F, however, we were moving along at about .88mach at 500ft AGL,
and
the skin temperature was about 100F, not a worry about accumulating icing.
Some one else referred to "Speed of heat" as being Mach 1, because most
aircraft need after-burner or "heat" (reheat) as the Brits would say.. to
make Mach1. BTDT
BT
Hi BT,
What were you flying? Most of my time is in the F-111D and the EF-111A.
I've also flown the F-15, C-130, C-141, KC-10, E-3. Did your aircraft
have a skin temperature indicator or a total temperature indicator?
Aircraft component heating is due to Mach compressibility, not skin
friction. I'm confident that your 100F value reflected total
temperature which is based on Mach compressibility.
The "speed of heat" received it's colloquial name because the speed of
sound is based only on the static temperature of the fluid medium, not
on pressure or density as is often mistakenly believed.
Kurt is quite correct in this.
You can determine the temperature by taking the Mach number, finding the
local ambient temperature/total temperature ratio. (all temperatures are
absolute temperatures)
At Mach = 1.0, the ratio is 1.2;
at Mach = 1.5, it is 1.34;
at Mach = 2.0 it is 1.8;
at Mach = 3.0 it is 2.8.
Just add the OAT to 459.7 deg F or 273.2 deg C to get the absolute
temperature.
Old March 17th 05, 05:21 AM
Montblack
("Orval Fairbairn" wrote)
That's-all-you-got? :-)
Montblack
Old March 18th 05, 10:59 PM
David CL Francis
On Tue, 15 Mar 2005 at 22:10:56 in message
R5QZd.71896$Tt.15712@fed1read05, BTIZ
about -15F, however, we were moving along at about .88mach at 500ft AGL, and
make Mach1. BTDT
The stagnation temperature I recall is roughly given by the following:
Ts/T1 = (1 + (M^2)/5)
Where T1 is the absolute air temperature and Ts is the stagnation
temperature. So if the outside air temperature is -10C and the Mach
number is 0.5 then T1 = 263
Ts = 263*(1 + 0.25/5) = 263 *1.05 = +3.15 degrees
That is the _maximum_ temperature rise at the stagnation point.
Elsewhere it will be lower. The heat transfer through the ice and
aluminium and their thermal capacity will affect how long it takes.
The fact that it depends on the square of the mach number brings the
effect down markedly at lower speeds.
David CL Francis
Old March 18th 05, 11:27 PM
Mike Rapoport
"David CL Francis" wrote in message
and
make Mach1. BTDT
temperature. So if the outside air temperature is -10C and the Mach number
That is the _maximum_ temperature rise at the stagnation point. Elsewhere
it will be lower. The heat transfer through the ice and aluminium and
David CL Francis
I have flight manuals that give a correction for airspeed and altitude and
the numbers are much higher than 3C even though the speeds are below M0.5.
In the MU-2, the temp sensor is in the tail section where the cross section
of the fusilage is actually decreasing.. Is there both a compression and a
friction heating of surfaces due to airflow?
Mike
MU-2
Old March 19th 05, 02:57 PM
Julian Scarfe
"Mike Rapoport" wrote in message
link.net...
section of the fusilage is actually decreasing..
I think the problem is only with the numbers that got plugged in. At M =
0.5, you get
Ts/T1 = 1.05. In other words a 5% temp rise. 5% of about 273 K is about 13
K,
i.e. 13 degC.
Is there both a compression and a friction heating of surfaces due to
airflow?
It's the same phenomenon. The "friction" occurs because the air is brought
to stagnation in the boundary layer.
Julian Scarfe
Old March 20th 05, 10:18 PM
David CL Francis
On Fri, 18 Mar 2005 at 23:27:50 in message
.net, Mike Rapoport
Of course; but I don't think the driving temperature can get higher than
the stagnation temperature. Let's try it for Concorde:
At 55,000 ft the outside standard air temperature is 217 deg K
So Ts = To(1 + (2.05^2)/5) = 408 == 126 C
That is very close to the value quoted in Brian Trubshaw's book about
Concorde. The chart on page 34 shows the nose temperature at 127 C, the
leading edge of the wing at 105 C, pilots cockpit area skin temperature
at 97C decreasing towards the rear fuselage at 91 C. Mind the fuel in
the wings kept down their temperature from rising too high!
It does not show the fins or air intakes but I doubt they were much
higher than the forward fuselage section just behind the nose at 100 C.
David CL Francis
Old March 16th 05, 03:15 PM
Mike Rapoport
I found this formula:
http://williams.best.vwh.net/avform.htm#Mach
Which shows a temp rise pretty close to what the MU-2 flight manual shows.
Mike
MU-2
"vlado" wrote in message
Is there a rule of thumb for 'speed of heat'? Meaning the speed in
knots where ice will not form on the leading edges of a wing. For
example, the Saberliner had no de-ice or anti-ice system, just speeding
up would remove or prevent ice build up.
Thanks.
Landing and T/O distances (Was Cold War ALternate Basing) Guy Alcala Military Aviation 3 August 13th 04 12:18 PM
Painting and air cooled motor? CitizenX Home Built 5 June 30th 04 12:47 PM
Va and turbulent air penetration speed. Doug Instrument Flight Rules 70 January 11th 04 08:35 PM
Va and turbulent air penetration speed. Doug Owning 69 January 11th 04 08:35 PM
Speed Astir Guy Acheson Soaring 0 December 11th 03 02:24 AM
