OK, if all you want is to record data, then yeah, whatever you want to use
is just fine as long as you can keep it from interfering with any critical functions on your plane. However, debugging all the potential EMI stuff could be hell just to get things to work. I was being sarcasting about the hacking comment....yeah, it was silly. There are already enough other decent options that will work just fine without the hassles of dealing with radio frequency stuff. Look at the aviation versions of CAN. Well supported, cheap, and really easy. There's also 1394, which is used a bunch in some new aviation systems. "nafod40" wrote in message ... It's coming to aircraft. In fact, it's already there via people that don't turn off their cell phones and laptops etc., just uncontrolled. Good article. http://developer.intel.com/technolog...cles/art_4.htm |
Pete Schaefer wrote:
OK, if all you want is to record data, then yeah, whatever you want to use is just fine as long as you can keep it from interfering with any critical functions on your plane. However, debugging all the potential EMI stuff could be hell just to get things to work. I hate cables. They are a gawdawful pain to manufacture, install, even worse to troubleshoot, and hell to fix. Installing new ones to odd points on a plane is sometimes impossible. I flew the E-2C (whistling s%$# can) and most of our class alphas were due to cables abrading and causing shorts, wandering signals, fires, etc. Obviously the bad things came from the power-carrying cables failing, but everything in the bundle went south when they did. EMI is obviously an issue, in ways I don't understand since I'm not a tron-bender, but the idea that you could plunk down a sensor and have *no* additional wiring whatsoever appeals to me. I wonder how much wire weighs and costs in the typical airplane? What are the EMI issues for your Mark I Mod 0 homebuilt? Nav system, obviously. What else? Sounds like an experimental airplane kind of thing to me. A company a friend of mine owns is developing the self-powered sensors, so I'm familiar with the work. The ones they sell now are bigger and (I think) battery-powered, but they are installing them on Navy ships, which have emmisions and EMI concerns too. http://www.rlwinc.com/ |
Are you suggesting that a bad engine will give clues to it's demise enough
in advance that you could actually do something about it? Clues that a monitor could pick up on, but an experienced pilot wouldn't? My company makes ~200MM/yr on this premies. Adam N7966L Beech Super III |
oops... I meant "premise".
"mindenpilot" wrote in message ... Are you suggesting that a bad engine will give clues to it's demise enough in advance that you could actually do something about it? Clues that a monitor could pick up on, but an experienced pilot wouldn't? My company makes ~200MM/yr on this premies. Adam N7966L Beech Super III |
![]() "mindenpilot" wrote in message ... oops... I meant "premise". Was that a Freudian slip? ![]() |
Vibration Monitor (Hyde, Wanttaja?) | RST Engineering | Home Built | 71 | April 4th 05 04:44 PM |
Pinging Ron Wanttaja - "Unporting?" | Bob Chilcoat | Home Built | 13 | November 24th 04 07:28 PM |
Vibration Testing | Jim Weir | Home Built | 20 | October 10th 04 07:22 AM |
Vibration Testing | Jim Weir | Owning | 21 | October 10th 04 07:22 AM |
Survey - 3 blade prop conversion- Cockpit vibration, happy or not | Fly | Owning | 20 | June 30th 04 05:32 PM |
