Blanche wrote:
Jay -- have you replaced the wing root seal? I agree the bulb is what holds it in place. And trying to replace it (which can be done, go back and read the r.a.o archives) is really awkward, difficult and frustrating. Yes, I've replaced mine. -- __!__ Jay and Teresa Masino ___(_)___ http://www2.ari.net/jmasino ! ! ! http://www.oceancityairport.com http://www.oc-adolfos.com |
Haven't worked on many Jaguars, have you?
Jim .. But I would hope that your mechanic can remove and replace the manifold without taking the engine out of your car. |
(e.drucker wrote)
I am sure that there are any number of such cases in the manufacture of cars. For example, the exhaust manifold is most likely installed on a car's engine before the engine is installed on the assembly line. But I would hope that your mechanic can remove and replace the manifold without taking the engine out of your car. Camaro/Firebirds: GM (eventually) had a square stamped on the inside wall of the passenger fender so you knew precisely where to torch - heater core popped right out once an "easy access" hole was cut. It was back in the early 80's last time I did this (friend's shop). Yikes. I think it was the Camaro with the stamped fender? Yikes, I think it was the heater core and not the blower? OK. I got nothing. Montblack |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 40 | October 3rd 08 03:13 PM |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | September 2nd 04 05:15 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | June 2nd 04 07:17 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
