"Frank van der Hulst" wrote in message
... Yeah. I wonder whether head movement would produce enough power... like the 'self-winding' watches of the 1970s. Probably not, but you don't need a lot. I guess it depends on how long you need it to operate. Using modern digital amp chips (which are amazingly efficient), you can keep consumption down. A couple of gumstick batteries might be alright. Not necessarily... I guess you're talking about a metal firewall shielding the signals, right? But, assuming a fibreglass cowl, mount a self-powered repeater someplace where the engine instruments can see it, That kinda goes against my "as few possible components between the source and the destination" philosophy. I think you'd have to just locate the receiver on the firewall and put an antenna through. Yeah, I know that none of these things is quite right, right now. If you don't keep working through the possibilities, you might miss an opportunity to invent that new gadget that everybody just has to have. Personally, I'm not hopeful that there's a big opportunity for blue tooth on home-built airplanes, but there might be a couple of really good applications. Pete |
Frank van der Hulst wrote:
snippo "Frank van der Hulst" wrote in message ... First thing would be Bluetooth headsets... no more cords tangling round the cockpit. Not to change the subject but where did they come up with 'Bluetooth anyway?... (just lucky maybe?) ![]() -- -Gord. (use gordon in email) |
Pete Schaefer wrote:
So, what things on the airplane are you guys going to replace with self-powered blue tooth devices? I'm typing out loud here... When I suggested bluetooth the other day, what I had in mind was a kit that you would temporarily hang on an airplane for specific tests, much like we hang all the orange on Navy aircraft for flight tests. Much more accurate pitot-static, vib sensors, postion sensors, data loggers, etc. You could, for example, have a kit for flight testing an RV-8. Pop it on, do the tests, and remove it. Or it could be used for "external stores" such as a camera. Afterward, I contemplated replacing all signal wires with wireless. So any wire not carrying power could be replaced. This might be especially useful for a refit, where access is far more difficult than during initial construction. Other harebrained ideas...two planes in semi-close formation could network via bluetooth. Why? Could be low prob. of intercept comms on a private channel, sharing of nav data, text messaging, ipod music files. There's an ongoing thread on rec.aviation.soaring on bluetooth and cellphones aboard planes. |
nafod40 wrote:
Pete Schaefer wrote: So, what things on the airplane are you guys going to replace with self-powered blue tooth devices? I'm typing out loud here... When I suggested bluetooth the other day, what I had in mind was a kit that you would temporarily hang on an airplane for specific tests, much like we hang all the orange on Navy aircraft for flight tests. Much more accurate pitot-static, vib sensors, postion sensors, data loggers, etc. You could, for example, have a kit for flight testing an RV-8. Pop it on, do the tests, and remove it. Or it could be used for "external stores" such as a camera. Afterward, I contemplated replacing all signal wires with wireless. So any wire not carrying power could be replaced. This might be especially useful for a refit, where access is far more difficult than during initial construction. Other harebrained ideas...two planes in semi-close formation could network via bluetooth. Why? Could be low prob. of intercept comms on a private channel, sharing of nav data, text messaging, ipod music files. There's an ongoing thread on rec.aviation.soaring on bluetooth and cellphones aboard planes. Bluetooth: a solution in search of a problem |
William W. Plummer wrote:
Bluetooth: a solution in search of a problem So was the internet for a while. I'm thinking of just wireless in general, of which bluetooth is an implementation (with a really catchy name.) |
nafod40 wrote:
William W. Plummer wrote: Bluetooth: a solution in search of a problem So was the internet for a while. Not at all. TCP, the original name for "TCP/IP" that we know today, was designed to meet certain military needs but the bigger issue of how to communicate through widely-disparate networks was _THE_ problem. You can look up the IEEE Trans. on Communications paper by Kahn and Cerf. 1974 as I recall. |
nafod40 wrote: William W. Plummer wrote: Bluetooth: a solution in search of a problem So was the internet for a while. Not at all. TCP, the original name for "TCP/IP" that we know today, was designed to meet certain military needs but the bigger issue of how to communicate through widely-disparate networks was _THE_ problem. You can look up the IEEE Trans. on Communications paper by Kahn and Cerf. 1974 as I recall. Yea, I guess I meant the Internet as in meaning the http protocol and WWW, which took what was a nifty way of hooking computers together and turned it into an incredible way to hook people together. In short, the "killer app". Bluetooth is still waiting for the killer app. I think as ubiquitous computing continues to grow (everything will have computers embedded...everything) the ability to form networks on the fly will be needed. But I digress from airplanes... |
Vibration Monitor (Hyde, Wanttaja?) | RST Engineering | Home Built | 71 | April 4th 05 04:44 PM |
Pinging Ron Wanttaja - "Unporting?" | Bob Chilcoat | Home Built | 13 | November 24th 04 07:28 PM |
Vibration Testing | Jim Weir | Home Built | 20 | October 10th 04 07:22 AM |
Vibration Testing | Jim Weir | Owning | 21 | October 10th 04 07:22 AM |
Survey - 3 blade prop conversion- Cockpit vibration, happy or not | Fly | Owning | 20 | June 30th 04 05:32 PM |
