Towplane performance
Old April 2nd 05, 10:57 PM
Roy
Default Towplane performance
Our operation has started the hunt for a new towplane.
The main criteria is that from our 2200ft strip at sea level we need
to have a two seater (janus) "over the fence" at 300ft in still air.
What would you recommend?
Dont dwell on purchase cost but rather performance/running costs
We would consider
a) Used
b) New
c) Experimental/anything else.
Thanks for your thorts.
Old April 2nd 05, 11:45 PM
Markus Feyerabend
We would consider
a) Used
b) New
Roy,
You say that you´re looking for a new towplane! What type did you operate so
far?
A 2200ft strip at sea level and 300ft over the fence in still air with a
Janus in the tow sounds like a challlenge!
I was towed by many different towplanes, but there are very few which can do
that reliably!
One, which can do the job is a YAK-55 though....however, not the usual kind
of towplane!
Check this:
http://tinyurl.com/6jcdt
I tow with our clubs Husky and on our 1600ft strip (1950ft above msl) we are
talking more like 50ft "over the fence" (and much less in the summer) with a
DG-1000 in the tow.
Good luk,
Markus
Old April 3rd 05, 03:48 AM
BTIZ
We have a Pawnee 235HP, most common of tow planes.. there are also 260HP
versions.
Also a CalAir tow plane may work.
We operate from a 2833MSL airport, 3500ft long runway.. normally glider
starts from about 500ft, so that leaves 3000ft of runway to go.. on hot
summer days.. with a 2-33 or a Grob 103 in tow at MaxGW.. we can plan on
200ft at the departure end.
Looking for 300ft in the air at departure end, in a Janus (assume two seats
loaded) at max GW take off from a 2200ft long runway is very optimistic.
I'm not sure what the performance would be with the Wilga... but I'm
guessing not much better.
BT
"Markus Feyerabend" wrote in message
We would consider
a) Used
b) New
Roy,
so
far?
do
that reliably!
kind
of towplane!
Check this:
are
a
DG-1000 in the tow.
Good luk,
Markus
Old April 3rd 05, 07:20 AM
Bruce Hoult
In article SPI3e.2906$ZV5.894@fed1read05,
Our 260 HP Pawnees normally get around 600 fpm at 65 knots with a Janus
(or Grob Twin for that matter) with two people. That's a climb angle of
about 1:11. OK, so you can get a better angle with a slower speeed, but
not *that* much better.
300 ft AGL after 2200 ft is a climb angle of nearly 1:7. The actual
1:11 a Pawnee gives would give you 200 ft AGL after 2200 ft. And that's
assuming that you *start* with runway already with full flying speed.
In reaily you're going to need about half the runway just to get up to
climb speed. And then you're going to have to climb at about 2000 fpm.
Not going to happen.
When we tried a Wilga at our club we found that the tow turnaround was
shorter, but it was because the Wilga came down faster not because it
went up faster.
Bruce | 41.1670S | \ spoken | -+-
Hoult | 174.8263E | /\ here. | ----------O----------
Old April 3rd 05, 08:04 AM
Chris Rollings
I can't think of any regularly used towplane that will
achieve what you want. A 260 hp Pawnee will probaly
launch a Janus safely in anything but a significant
tail-wind component, but you won't usually get 300
feet over the fence, except on cool, windy days. Why
do you need the 300 foot margin?
sea level we need
to have a two seater (janus) 'over the fence' at 300ft
in still air.
costs
We would consider
a) Used
b) New
Old April 3rd 05, 11:25 AM
Stefan
A Pilatus PC6 will do this just nicely. Ok, agreed, not exactly a
"regularly used towplane".
Stefan
Old April 3rd 05, 01:11 PM
M B
It sounds like you don't want a plane, you want an
engine.
How about a
G-164 Super Ag Cat C with a 600hp turbine? Looks like
they are $50,000 US maybe?
The aggies love 'em, so they can't be TOO pricey for
maint.
Fuel cost is maybe a bit higher, but you specified
PERFORMANCE, right? Gotta pay SOMETHING for that...
A nice experimental sticker and a towhook/looksie by
whatever govt. agency and bzzzz...you're off!
Good luck...I hope the propwash doesn't blow the wings
off...
maybe use a longer towrope? :P
sea level we need
in still air.
costs
We would consider
a) Used
b) New
Mark J. Boyd
Old April 3rd 05, 02:38 PM
Bruce Hoult
Don't forget the NZ turbine cropduster offshoot being sold for
skydiving, the PAC 750XL:
http://www.utilityaircraft.com/
Brake release to 12,000 ft takes 12 minutes with a 2 tonne load. The
plane without the skydivers (but with fuel & pilot) weighs 1400 kg, so
it can presumably climb at over 2000 fpm lightly loaded.
Ground roll at MTOW is 1244 ft, so presumably considerably less at
light weights.
Biggest problem: best rate of climb is at 95 knots, best angle is at 85
knots.
Old April 3rd 05, 04:31 PM
Stewart Kissel
It certainly looks like it could do the job....however
not sure which club wants to own the first $500k+ towplane
will
not exactly a
'regularly used towplane'.
sold for
2 tonne load. The
weighs 1400 kg, so
less at
light weights.
best angle is at 85
knots.
Old April 3rd 05, 08:14 PM
Pete Reinhart
I learned behind a 180 hp Super Cub and remember seeing loaded glider and
tow plane off the ground in 3-500 feet depending on wind. plenty fast climb
too.
we were operating out of the middle of a 3000 ' strip so demos coul depart
and arrive at the same place either direction. I understand that there was
an STC for 200 hp on the sme airframe and the extra 20 hp ought to really do
the job on the Janus. Only problem is that Supr Cubs bring a premium these
days.
Cheers!
"Stewart Kissel" wrote in
message ...
will
not exactly a
sold for
2 tonne load. The
weighs 1400 kg, so
less at
light weights.
best angle is at 85
knots.
Glider - Towplane Signals Mike the Strike Soaring 24 March 26th 05 09:33 PM
Performance World Class design proposal iPilot Soaring 85 September 9th 04 09:11 PM
Complex / High Performance / Low Performance R.T. Owning 22 July 6th 04 08:04 AM
Super Cub towplane performance Marc Arsenault Soaring 1 July 11th 03 01:42 PM
