What he said, squared. About the only thing I can think of that you can
do with a DME that you can't with a terminal-certified GPS is use it to fly an ILS-DME (because you don't have the location of the ILS DME ground station in the GPS database). Unless you have some very specific reason to need DME for one of the very few things GPS can't replace it for, I think it would be foolish to invest in DME these days. Roy, you corrected yourself in a later post. If I understand it correctly ILS-DME approaches if loaded into the IFR GPS can be flown with the GPS, How else could the new DA40-180 and Garmin G1000 do it? Waypoints loaded into the ILS course provide the "distance to" information needed for an ILS-DME approach. Review AC90-94 and the AIM on IFR GPS in lieu of DME As a side note, our local FBO got a "new" BE33 on the lease back rental line, DME is broke.. the owner (Private Pilot) did not know what it was.. and did not know what "DME" was. The local radio shop told him he'd spend as much trying to figure out what was wrong as to replace it. The owner decided not to repair it, just placard it INOP. So, he just took away all of his IFR rentals. BT |
![]() What he said, squared. About the only thing I can think of that you can do with a DME that you can't with a terminal-certified GPS is use it to fly an ILS-DME No reason you can't use your GPS to fly an ILS/DME. There's no requirement for the DME shack to be in the database. My GX55 is just such a unit. Terminal/enroute only. You navigate ILS/DME's using a distance from the outer marker. |
Newps wrote: What he said, squared. About the only thing I can think of that you can do with a DME that you can't with a terminal-certified GPS is use it to fly an ILS-DME No reason you can't use your GPS to fly an ILS/DME. AIM 1-1-19(f) gives a specific list of situations where you can use a GPS in lieu of ADF or DME. Determining a fix made up of a LOC course and a DME reading isn't one of them. There's no requirement for the DME shack to be in the database. Well, there's things like: NOTE- When using a facility as the active WP, the only acceptable facility is the DME facility which is charted as the one used to establish the DME fix. If this facility is not in your airborne database, you are not authorized to use a facility WP for this operation. That sure sounds to me like a requirement to have the DME ground station (the antenna, really, not the shack) in the database. My GX55 is just such a unit. Terminal/enroute only. You navigate ILS/DME's using a distance from the outer marker. Can you give me a specific example? |
Roy Smith wrote:
In article , "Dude" wrote: "jsmith" wrote in message ... Don't waste your money on a DME. Too much maintenance. Purchase a good used IFR GPS. What he said! I am presently looking to replace my RNAV/DME with a new GPS. By the time you buy and install a used DME system you will be getting pretty close to a used IFR GPS. What he said, squared. About the only thing I can think of that you can do with a DME that you can't with a terminal-certified GPS is use it to fly an ILS-DME (because you don't have the location of the ILS DME ground station in the GPS database). Unless you have some very specific reason to need DME for one of the very few things GPS can't replace it for, I think it would be foolish to invest in DME these days. I have found the DME location in my KLN 89/B database. I tried it once. ross |
jsmith wrote:
Don't waste your money on a DME. Too much maintenance. Purchase a good used IFR GPS. mindenpilot wrote: Some DMEs seem to have an indicator, and then a separate receiver box, like the ARC 800 DME. Others I've seen just seem to be an in-panel job, like the Narco DME 190 or the King KN62A. I've seen some on Ebay, and wanted to make sure that the Narco 190/ King KN62A don't require an additional recieving unit, like the ARC 800. That is, if I were to purchase a yellow-tagged Narco 190 (and tray and connectors), would that be all I need? Antenna? Adam, that is what I did. I had a ADF that didn't work and no DME. I purchased a factory reconditioned KLN89/B and had it installed and removed the ADF. The 89/B is working for me althought a Garmin 530 would also me nice. Ross -- Regards, Ross ________________________________________ 972.952.3170 Phone 972.949.9249 Pager 972.952.2574 FAX McKinney / Wing A2 North @ 48v72 |
![]() "Ross Richardson" wrote in message ... jsmith wrote: Adam, that is what I did. I had a ADF that didn't work and no DME. I purchased a factory reconditioned KLN89/B and had it installed and removed the ADF. The 89/B is working for me althought a Garmin 530 would also me nice. Ross -- Regards, Ross ________________________________________ 972.952.3170 Phone 972.949.9249 Pager 972.952.2574 FAX McKinney / Wing A2 North @ 48v72 Ross, Since the original post, I've been looking at the KLN 89B. How do you like it? Is it certified for both enroute and approach? I was thinking of selling my Airmap 1000 to help finance the purchase. Is it good enough that I won't miss the moving map, etc? Adam N7966L Beech Super III P.S. Are you in McKinney, TX? That's where I bought my plane last October... |
mindenpilot wrote:
Since the original post, I've been looking at the KLN 89B. How do you like it? Is it certified for both enroute and approach? I was thinking of selling my Airmap 1000 to help finance the purchase. Is it good enough that I won't miss the moving map, etc? The Airmap has an obstruction database and all the airport data, since they are now selling for nearly half the price of what they once were, I'd hold on to it... |
mindenpilot wrote:
"Ross Richardson" wrote in message ... jsmith wrote: Adam, that is what I did. I had a ADF that didn't work and no DME. I purchased a factory reconditioned KLN89/B and had it installed and removed the ADF. The 89/B is working for me althought a Garmin 530 would also me nice. Ross -- Regards, Ross ________________________________________ 972.952.3170 Phone 972.949.9249 Pager 972.952.2574 FAX McKinney / Wing A2 North @ 48v72 Ross, Since the original post, I've been looking at the KLN 89B. How do you like it? Is it certified for both enroute and approach? I was thinking of selling my Airmap 1000 to help finance the purchase. Is it good enough that I won't miss the moving map, etc? Adam N7966L Beech Super III P.S. Are you in McKinney, TX? That's where I bought my plane last October... Yes, I work in McKinney and commute from 35 miles north. Small world. The 89/B is certified for enroute, terminal, and approach. It is old technology but works for me. The owners manual is poor. I got a couple of hours dual with an instructor that had knowledge in the unit and boght the John & Martha King videos on GPS and they use the 89/B as the example. Watched them several time. Keys I discovered: 1) must be in the flight plan mode ( not direct to) to get the approach to activate, and 2) I like the heading up (vs north up or trk up) mode and the moving map (it does have moving map) even as simple as it is, gives good infomation. I update via laptop getting the downloads from the internet.. You will need a enunciator panel and CDI to interface with it. I got a separate CDI (total of 3 now one each radio and GPS). Sure, I would like one of the new Garmins, but couldn't afford it. You can store flight plans, modify the plans you have in use, calculate TAS, wind driection, etc. I bought a factory reconditioned unit. Hope this helps. Ross Email me privately who you brought the plane from if you do not mind. |
jsmith wrote:
Don't waste your money on a DME. Too much maintenance. Purchase a good used IFR GPS. Maintenance? I've had a KN64 in my panel for over a decade. I haven't had any maintenance done to it. Now the rest of the King SC stack is a different story. The GS crumped and occasionally the displays on the KX155's fail. The transponder needs regular attention and the stupid ADF I am never certain if it is ever working. I'm in the middle of switching over to a Garmin stack, the only thing I'm keeping is the KN64. On the other hand, I'm not sure I'd go out of my way to install one if I didn't already have one. Back when I put it in, I knew it was likely to be the first casualty of the GPS era. |
Ron Natalie wrote:
: Maintenance? I've had a KN64 in my panel for over a decade. : I haven't had any maintenance done to it. Now the rest of the : King SC stack is a different story. The GS crumped and occasionally : the displays on the KX155's fail. The transponder needs regular : attention and the stupid ADF I am never certain if it is ever working. : I'm in the middle of switching over to a Garmin stack, the only : thing I'm keeping is the KN64. : On the other hand, I'm not sure I'd go out of my way to install one : if I didn't already have one. Back when I put it in, I knew it was : likely to be the first casualty of the GPS era. I'll pipe in here and say that a DME is still incredibly handy to have. It's stone-cold simple to dial up, independent of databases and the rest of the GPS fiddling cruft. If you already have one and it works, it's got a lot of utility for situational awareness if you have a chart in front of you. The IFR GPS doesn't give you as much quick situational awareness unless it's moving map, since you'll have to fiddle with something to get a distance/bearing to something. That said, for people shelling out big bucks for an install, what everyone said about the GPS makes sense. I put a KNS-80 (ILS/GS/NAV/DME/RNAV) in my Cherokee about 2 years ago, as we needed another NAV and a GS. It's lots of bang for the buck, and they're almost free on ebay these days. If you're going to pay $1000-$2000 for an install, though, the $500 KNS-80 isn't quite as useful as a $1000 IFR GPS UNLESS you need another NAV/ILS/GS as well. Then it makes a lot of sense. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
Phoenix FBO Recommendations | Robert Easton | Piloting | 5 | February 3rd 05 07:22 AM |
FBO Recommendations - Montreal | Jay Somerset | Piloting | 3 | February 1st 05 10:31 PM |
TSA's General Aviation Airport Security Recommendations Might Become Requirements | Larry Dighera | Piloting | 1 | February 25th 04 05:11 PM |
paint shop recommendations wanted (SE) | Stephen N Mills | Owning | 0 | January 29th 04 03:44 PM |
Extra Headset recommendations? | Mike Z. | Piloting | 1 | June 30th 03 10:02 PM |
