Compass turns revisited
Old April 6th 05, 05:25 PM
Michael
I think its easier just to do it on the dg (or even an obs if your dg
has failed and is covered up)-- as
Gardner said, count 10 seconds per "numbered" heading, even if it
means putting your finger physically on the
numbers as you count from your current heading to your desired
heading...
Yeah, that works great unless you have a barrel DG (or the DG is
covered) and an indicator without full view of the numbers. I've flown
IFR in such planes.
Michael
Old April 7th 05, 12:39 AM
John Clonts
"Michael" wrote in message
heading...
IFR in such planes.
Michael
Have you ever flown a plane with OBS's that were designed where you couldn't see most of the numbers around the
perimeter of it? I haven't, but I have seen such on a MS Flight Sim panel for a C210 that I got... It drives
my crazy since it pretty much thwarts the "VOR as a Quadrature Instrument" approach, and other visualizations
that you can otherwise do on the OBS! I have not seen any on the market currently. I wonder during what
years--and by whom--were they manufactured?
Cheers,
John Clonts
Temple, Texas
N7NZ
Old April 7th 05, 02:28 PM
Michael
perimeter of it?
Yes, that's one kind I referred to. In fact, I once had to train a
student whose airplane was so equipped. I believe his CDI's were
Garmin and some model of Narco, but I could be wrong.
There are also others (Terra, Bendix 2000) that are digital - you dial
in the radial on a display rather than have a mechanical ring.
Michael
Old April 6th 05, 09:48 PM
ram
I agree. It also reinforces the direction in which you should be turning
and about how far when your in a panic and lose situational awareness. When
my CFII pointed out this technique, it was a godsend. I can do the math and
was pretty good with timed turns, but it was a nice tool to double check and
speed the process.
Bob
"John Clonts" wrote in message
"David Cartwright" wrote in message
Some students just don't get math. For them, the mental math required
to figure out how many seconds the turn needs to be is too much to do
while flying under the hood. For others, the jumping around, lead, and
lag of the compass is too difficult to deal with - they prefer to time
the turn, the check the compass only in level flight.
For some reason, despite two 'A' levels in maths, I have brain failure
with my three times table when trying to figure out timed turns. So long
as I take a few seconds to double-check your multiplication, though, and
I sanity check it (e.g. if you're turning 120 degrees it should take less
than a minute, not more) it's not a problem.
I think its easier just to do it on the dg (or even an obs if your dg has
failed and is covered up)-- as Gardner said, count 10 seconds per
"numbered" heading, even if it means putting your finger physically on the
numbers as you count from your current heading to your desired heading...
Cheers,
John Clonts
Temple, Texas
N7NZ
Experience with SIRS compass? Ross Oliver Owning 2 March 18th 05 06:21 PM
Vertical Card Compass Mystery Rosspilot Owning 3 November 3rd 04 06:01 PM
Do you use your magnetic compass? Roger Long Piloting 42 May 25th 04 12:08 PM
Strange compass behavior me Owning 10 February 14th 04 04:24 AM
Compass turning error Marty Ross Piloting 3 August 21st 03 02:53 PM
