Ron Wanttaja wrote in message . ..
Sorry for being late. I was busy during the last days so I couldn't answer. There are two main airworthiness categories: Standard and Special. Standard airworthiness aircraft are proven to meet certain FAA standards, and they must be maintained to ensure their continued compliance with those standards. At given intervals they must be inspected to ensure they still conform to the Type Certificate they receive. Since these aircraft are known quantities, they may be placed into commercial service with no further FAA certification action (although some additional equipment may be required for some operation). Standard airworthiness includes normal, aerobatic, utility, transport, commuter, and transport categories. Special airworthiness is used for airplanes that either have not undergone the FAA certification process, or specific changes are made to them that take them outside the limits established by their type certificate. Operation of Special airworthiness aircraft is basically governed on a *per aircraft* basis. The FAA assigns operations limitations to each aircraft, and these limitation are not blanket to a given aircraft type nor are they transferrable to an identical aircraft. Ok. So that means if I build a kitplane and get an airworthiness certificate this doesn't necessarily mean that my neighbour building the exactly same kit with exactly the same parts. Understandable, as even with the same parts the quality of work may differ. Special airworthiness categories include Limited, Primary, Restricted, Special Light Sport, and Experimental. Commercial operations are *not* prohibited, but they require specific FAA approval. The degree to which the FAA grants such permission varies. Ok. So if I want to use my experimental commercially I need to get FAA approval first. The Experimental category under the Special Airworthiness includes a number of categories, such as racing, market survey, R&D, Exhibition, experimental LSA, and amateur-built. Racing is clear. What is the difference between the other categories? I assume amateur-built means a plane built by hobbyists. R&D probably is something like an experimental airplane from a plane manufacturer like the YF-22, right? What is experimental LSA? I also wonder when a plane is amateur-built. I assume it's the case if someone without special knowledge builts a plane by itself. What about if he does that commercially (building planes and selling them)? Or what about if a aircraft construction engineer builds a plane? He probably can't be considered as amateur? The FAA's *policy* may be to deny permission for these aircraft to operate commercially, but such policies can be waived. You just have to give the FAA a good reason why the waiver is a good idea. So in the end that means it's basically not allowed to use them commercially, but this can be overcome by a waiver. As others have described very nicely, the L-39 Albatross may be a safe, professionally-designed aircraft, but it never was awarded a US type certificate, nor any similar type certificate that the US is treaty-bound to honor. Hence, it can never be operated normal or any other Standard category. That tosses it into the Special airworthiness category, and the category it apparently best fits into the Experimental/Exhibition one. I understand. Obviously, with dozens L-39s being imported to the US, having a school that can check folks out in them is a real good idea. So the FAA will issue a waiver allowing them to operate one or several aircraft to train folks. Similarly, having a school for training civilian test pilots is also beneficial to aviation, hence a waiver was possible. Similarly, manufacturers of high-performance homebuilts have received waivers allowing them to provide training in a company-built example. I understand The FAA waiver usually demands that these planes receive professional-type maintenance similar to that of standard airworthiness aircraft (e.g., the L-39 instructor won't be allowed the maintain the plane himself unless he has an A&P license). So basically if You maintain Your plane according to the manufacturer standards and if You have a valid reason chances are good that You can get a waiver to allow commercial operation. Thank You very much for your very detailed explanation. And of course to everyone here that answered to my (probably somehwat stupid) questions. JJ. |
![]() "John D. Abrahms" wrote in message om... I know that all the airplanes that people build by themselves fall into the experimental category, because they are not factory-made, serialized products but individually built with different quality and with different modifications. Not really. You can restore a certified airplane from a dataplate and a single piece of metal and build everything yourself. If you can get an IA to sign off on it, and the FAA to agree, it doesn't have to be experimental. I also know that GA airplanes made of composites usually fall into the experimental class category, too. No. Cirrus, Lancair and a few others are composites and they are certified aircraft. What really annoyed me is that there also are planes that are not composite and also are factory-made in high numbers that fall into experiemnat category, like the Aero L-39 Jet airplane. That's because it's an ex-military airplane that was never put through normal certification. In order to fly in private hands it has to have an experimental airworthiness certificate. From what I know a pilot who wants to fly a L-39 jet airplane needs 1000hrs of PIC time, and after that needs a Letter of Authorization to be able to fly the L-39. Correct. What if the L-39 would not be registered as experimental but as normal/utility/aerobatic airplane? The manufacturer, as far as I know, has no interest in spending the oodles of money required to achieve this. And most likely you wouldn't be able to afford the airplane if they did. Would this also require 1000hrs of PIC time before someone can fly with this L-39? It would require a type rating. Are there any PIC hours required to be allowed to fly turbine airplanes? To my knowledge, that is only the case on the few ex-military experimentals being sold out there. I also heard that it's not possible to use an experimental plane for training (PPL, CPL, IFR, whatever). No. A CFI can use your experimental to train you to fly it. Juan |
Used to be ex military aircraft were in the Restricted category. I
dealt with a Grumman Goose and a Lodestar years ago where that was the case. Is that no longer true or are fighters and trainers different? The way I remember it was the FAA came out with the hours and LOA requirement because there were too many doctors and lawyers that had more money than brains and got out of their Bonanza and into a P-51 and killed themselves. Posted Via Usenet.com Premium Usenet Newsgroup Services ---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY ** ---------------------------------------------------------- http://www.usenet.com |
The LOA is no longer called an LOA, but from what the FSDO told me about
the requirements, it is still a rose by another name. Don Hammer wrote: Used to be ex military aircraft were in the Restricted category. I dealt with a Grumman Goose and a Lodestar years ago where that was the case. Is that no longer true or are fighters and trainers different? The way I remember it was the FAA came out with the hours and LOA requirement because there were too many doctors and lawyers that had more money than brains and got out of their Bonanza and into a P-51 and killed themselves. Posted Via Usenet.com Premium Usenet Newsgroup Services ---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY ** ---------------------------------------------------------- http://www.usenet.com |
LOA's are still around. For the ex-mil's now they have a weird
pseudo-type-rating system that shows up on your license. But that applies only to ex-mil on that AC that's been recently updated. For my BD-5J, for example, I was told to apply for an LOA, and that's what the FSDO will issue me if aero-medical ever gets around to handling my special issuance renewal. "AINut" wrote in message ... The LOA is no longer called an LOA, but from what the FSDO told me about the requirements, it is still a rose by another name. Don Hammer wrote: Used to be ex military aircraft were in the Restricted category. I dealt with a Grumman Goose and a Lodestar years ago where that was the case. Is that no longer true or are fighters and trainers different? The way I remember it was the FAA came out with the hours and LOA requirement because there were too many doctors and lawyers that had more money than brains and got out of their Bonanza and into a P-51 and killed themselves. Posted Via Usenet.com Premium Usenet Newsgroup Services ---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY ** ---------------------------------------------------------- http://www.usenet.com |
![]() "Don Hammer" wrote in message ... Used to be ex military aircraft were in the Restricted category. I dealt with a Grumman Goose and a Lodestar years ago where that was the case. Is that no longer true or are fighters and trainers different? Don't know about the Goose or Lodestar but the ex-mil fighters are covered by an AC, can't remember the number. The way I remember it was the FAA came out with the hours and LOA requirement because there were too many doctors and lawyers that had more money than brains and got out of their Bonanza and into a P-51 and killed themselves. Still applies. ![]() |
![]() "Don Hammer" wrote in message ... Used to be ex military aircraft were in the Restricted category. I dealt with a Grumman Goose and a Lodestar years ago where that was the case. Is that no longer true or are fighters and trainers different? Flavors and trends do change over time. It did indeed, used to be the case that most warbirds that didn't have a civilian type certificate were certified in the "Restricted" category with the specific restrictions determined on a case by case basis. As I recall there were also some in the "Limited" category, with the specific limitations also determined on a case by case basis. At that time it was also true that the "certificate" given to an amateur built aircraft was only valid for one year. Every year you had to have the FAA come out and inspect the airplane to renew it. Then the FAA figured out that they were in the business of giving free annuals for homebuilts and instituted the present permanent "certificate" that must be inspected every year by a certified mechanic. Note that a "repairman certificate" holder is a "certified mechanic" whose "certification" extends only to one specific airplane. :-) Nowadays most of the warbirds are finding their certification easier in the "Exhibition" category. This category generally allows some radius of operation, of several hundred nautical miles, for "pilot proficiency maintenance" where you can fly pretty much as you please. Trips outside of that radius require that the FAA be "notified" prior to the trip. Generally you can fax the FAA office a "notification." You can also send them a list of the shows and flyins that you plan to attend once a year. Much of this change is because of the changing view of warbirds. At one time they were just big, expensive, impractical airplanes. Now they are antiques and collectors items and people pay money to see them up close and see them fly. I can remember when you could buy a surplus fighter for a couple of thousand bucks because nobody wanted the headaches. I just wish I had bought a few dozen of them an stored them in the back of my hangar! :-) I did meet one older gentleman down in Louisiana who had thirty Stearman trainers brand new in the crate stored in the back of his hangar. He said whenever he needs a little extra money he puts one together and sells it. Since that was back in the sixties, I doubt that any of them are left in the hangar. He was in his sixties then as well and may not need extra money anymore! Highflyer Highflight Aviation Services Pinckneyville Airport ( PJY ) |
On Thu, 7 Apr 2005 16:36:28 -0500, "Highflyer" wrote:
I can remember when you could buy a surplus fighter for a couple of thousand bucks because nobody wanted the headaches. I just wish I had bought a few dozen of them an stored them in the back of my hangar! :-) Dunno, HF...I've *seen* your hangar. Sure there ain't a couple of P-40s stashed in back? :-) Ron Wanttaja |
![]() "Ron Wanttaja" wrote in message ... On Thu, 7 Apr 2005 16:36:28 -0500, "Highflyer" wrote: I can remember when you could buy a surplus fighter for a couple of thousand bucks because nobody wanted the headaches. I just wish I had bought a few dozen of them an stored them in the back of my hangar! :-) Dunno, HF...I've *seen* your hangar. Sure there ain't a couple of P-40s stashed in back? :-) Ron Wanttaja No P-40s Ron. However, there ARE a couple of Vultees. :-/ Back behind the Stinson and the Pietenpol and the Cavalier and the Apache. It is getting crowded in there. One of these days I will get ALL of them together and flying. Then I WILL have a parking problem! :-) Highflyer Highflight Aviation Services Pinckneyville Airport ( PJY ) |
PA-32 on Experimental Certificate | Mike Granby | Owning | 3 | July 21st 04 03:04 AM |
Crashing Experimental on America's Funniest Home Videos | Jay | Home Built | 7 | March 10th 04 12:11 AM |
USA: Experimental Certificates | C.Fleming | Soaring | 4 | October 30th 03 10:48 PM |
A couple Questions-Ramp Checks and Experimental Operations | Badwater Bill | Home Built | 48 | October 8th 03 09:11 PM |
2 Place Experimental.... | [email protected] | Soaring | 8 | September 7th 03 03:03 AM |
