Fun weekend buying an Arrow (long)
Old April 15th 05, 02:44 PM
Dave Butler
George Patterson wrote:
Mike Spera wrote:
One well known aviation university teaches you to "fly out on the tank
you flew in on".
I take off on "both." If either one works, I have gas.
Doesn't that also mean that if one of the tanks is contaminated, you're going to
draw the contamination into the engine, with no option of switching to a good
tank (or, at least, you don't know which tank to switch to).
Old April 15th 05, 04:14 AM
Bob Chilcoat
Easy for you, George. The Archer doesn't have that position on the valve
Bob (Chief Pilot, White Knuckle Airways)
"George Patterson" wrote in message
news:beF7e.5519$4v3.1682@trndny03...
you flew in on".
George Patterson
There's plenty of room for all of God's creatures. Right next to the
mashed potatoes.
Old April 16th 05, 01:05 AM
kage
One helpful point:
When changing fuel tanks, keep your hand on the fuel selector valve for
about 30 more seconds and monitor the fuel pressure gauge.
If the fuel pressure drops or the engine quits your hand will already be on
the valve to re-select the good tank.
In my childhood I flew a Beaver amphibian out of King Salmon. The procedure
to maximize the available fuel was to run the tanks dry from the rear to the
front. A beaver has fuel in the belly in two tanks (a bad place and most
Beaver crashes involve fire.)
I could rest my hand on the fuel selector valve and watch the fuel pressure
gauge. Once the fuel pressure just started to drop the tank could be
switched quickly without the engine quitting.
Karl
"Curator"
N185KG
Old April 19th 05, 01:21 AM
Robert M. Gary
Mike Spera wrote in message ...
you flew in on". The theory being that takeoff is not the time to "test"
whether a tank you just switched to is blocked, the fuel valve
malfunctioned, a tank is empty (cuz you forgot to check it), a tank you
just switched to is full of water, etc.
Pretty poor theory. It's a haphazardway of avoiding actually managing
your fuel. I'm more of a measure, calculate type of guy myself. I keep
a log of the tanks in flight in my Mooney (I don't have a "both"
selector).
I also don't buy into the "fill the tanks before take off" B.S. You
should know how much fuel you need and how much extra you'll need. I
just don't see putting 8 hours of fuel in my Mooney and pushing around
like an over stuffed whale.
All this reminds me of the Bonanza pilot who declared a fuel emergency
only to discover he had another 3 hours of fuel. He always put 5 hours
in it, but never let it go below 2 hours, he burned 12gal/hr but
caluclated it as 15 gal/hr, etc, etc. All this "extra safety buffer"
just meant he had NO idea how much fuel he had.
-Robert, CFI
Old April 19th 05, 01:47 AM
Matt Barrow
om...
selector).
http://www.avweb.com/news/columns/182044-1.html
August 9, 1998
Pelican's Perch #7:
Run That Fuel Tank Dry!
AVweb's John Deakin takes aim at yet another OWT (Old Wive's Tale). While
running a fuel tank dry in your recip powered plane may serve to increase
your heart rate, John explains why it's not such a bad thing at all, and it
is probably a really good idea for most of us. In fact, John explains why
it's one of the first things you ought to do with a new plane and how it
could save your life someday.
Old April 19th 05, 03:16 AM
Mortimer Schnerd, RN
Flying the old Cherokee Six with four fuel tanks, you'd end up with almost 10
gallons unusable if you didn't run a tank dry occasionally. I tried to never
let it happen with passengers on board. Screwed up once though... probably
scared the hell out of them though nobody said anything about it once I'd
explained what had happened. Mea culpa.
VE
Old April 19th 05, 06:00 AM
Highflyer
"Mortimer Schnerd, RN" wrote in message
. com...
it
10 gallons unusable if you didn't run a tank dry occasionally. I tried to
never let it happen with passengers on board. Screwed up once though...
probably scared the hell out of them though nobody said anything about it
once I'd explained what had happened. Mea culpa.
I remember one time in a light twin. I decided to run the auxilliary tanks
dry before returning to the mains so that I would have all of my remaining
fuel in the mains for the approach and landing. I flew an hour on the mains
to get some dump space for the overflow from the injectors and then switched
to the aux tanks. After churning along on the auxs for some little time the
right engine quit. As I was reaching for the fuel selector to switch it
back to the main the left engine quit. The sudden total cessation of engine
noise in midtrip got my passengers rather upset until I got them both making
appropriate noises again and explained to them what had happened and why I
did it that way. :-) Mea Maxima Culpa ...
Highflyer
Highflight Aviation Services
Pinckneyville Airport ( PJY )
VE
Old April 19th 05, 12:15 PM
I had essentially the same thing happen to me one night coming back from
Cleveland in a C-402. I'd been up for almost 24 hours and was exhausted (the
flight had been scheduled for early the previous morning, cancelled and then
rescheduled as I was getting ready for bed). I had flown all night in a mix of
clouds, occasional icing, and VFR. I was moving auto parts from Shelby, NC to
CLE, then back to CLT (my home base). No passengers; just me.
I took off from Cleveland IFR and my attitude indicator croaked. There was
another one on the copilot's side but I was on top before long so it was no big
deal. I settled down to cruise on the mains. After an hour of hand flying, I
switched over to the auxillary tanks. Then I fell asleep. I woke up to some
yaw and less noise... the left engine had quit! I reached over to switch tanks
and hit the boost pump to get a restart. Then the other one quit before I could
switch that tank. Holy ****! That got my attention. I switched tanks on the
right engine and hit that boost pump. By that time the left engine started. A
moment later the right one came back. I remember complimenting myself on the
accuracy of my fuel leaning.
Whew! I swore to God I'd never fall asleep again while flying. I broke my
promise twice before completing that flight.
What do they say? Any flight that doesn't end up on the 11 o'clock news
couldn't have been all that bad. It wasn't that great though... I fought 70
knot headwinds up to Cleveland (rode home at mach two), suffered a right brake
failure, failed attitude indicator, got to play with ice, had the company credit
card denied twice (at Charlie West and Cleveland), and ran the tanks dry. I
really prefer the dull life.
VE
Old April 19th 05, 11:49 PM
John Galban
broke my
I read many years ago about a corporate pilot who was repositioning a
plane (big twin) from Indiana to Illinois for a morning flight. He'd
been flying all day and was tired. He fell asleep enroute and woke up
just as the last engine died and the sun was coming up. He made a
successful deadstick on a dirt road. When a farmer came along in a
truck, he asked where he was. He was in New Mexico. I would have
loved to have been a fly on the wall when that guy called his boss and
told him the morning flight would be a little late :-))
Weren't there a couple of snoozing airline pilots on a red-eye that
overshot L.A. and were finally awakened well out over the Pacific? I
seem to recall reading about that one in the paper sometime in the 90s.
Tired pilots with autopilots can be a bad combo :-)
Old April 20th 05, 03:52 AM
Matt Barrow
. com...
While
increase
it
why
10
never
probably
You might want to try Deakin's approach of gathering fuel data when alone
and then be rather cautious of warning passengers that the engine will
"burp" before it happens. One aside is that I'd not recommend it with
passengers that are "Nervous Nellie's" to begin with.
Of all the people that I take as passengers (family and business partners)
all have been around GA a long time and so are comfortable with GA (that
might be a good thread: Those who will fly airlines but not GA). two of my
partners have private tickets, my son has his IR, my daughter her PVT, and
my wife has soloed. They have NO problem with an engine burping.
It is reassuring to know that my useable fuel is actually eight gallons more
than the specs portray...not that I push that foolishly.
Matt
Matthew W. Barrow
Site-Fill Homes, LLC.
Montrose, CO
First Two Aero Lessons This Weekend (Long) David B. Cole Aerobatics 12 December 3rd 04 01:18 AM
Ultralight Club Bylaws - Warning Long Post MrHabilis Home Built 0 June 11th 04 05:07 PM
Flight test update - long nauga Home Built 1 June 5th 04 03:09 AM
SWRFI Pirep.. (long) Dave S Home Built 20 May 21st 04 03:02 PM
Across Nevada and Part Way Back (long) Marry Daniel or David Grah Soaring 18 July 30th 03 08:52 PM
