![]() "Matt Whiting" wrote Exactly. Wire is pretty darn simple. A wireless router is a rather complex assembly of hardware and software. A few runs of wire have been known to function for more than 50 years. I wouldn't bet much on a typical router being function 50 years down the road. While what you say is true, I don't agree with the premise. Wireless routers are no more complex than hard wired routers. You will be carrying around the wire for 50 years, with the weight penalty for that whole time. Servicing the plane will be more complex, working around the extra wire. Less functionality, due to passengers having constraints of being tied down by a wire, in whatever arrangement you put them in, is a fact of life. It also means something more to trip over, not being able to move from seat to seat easily with your computer or other wireless device, and wires tip over drinks and things. If you want to have wireless devices other than computers, like headphones for music or movies added, you don't have to add another whole set of wires. The flexibility is worth the extra complexity, no matter what the possible small difference in reliability could be, if there even is a difference. Given, wireless routers fail. So do hard wired routers. So do airborne high speed data links. If data is that important, you carry a backup data link. Carry an extra wireless router too, and still be ahead on the weight. You would have to have a backup hard wired router, anyway. Things are changing in digital communications so fast, I would say your chance of using the same wire in 50 years is about nil. There will be different standards and needs by then. At upgrade time, you will have to tear out the wire, and do it all again. More unnecessary expensive installation. Drop a new wireless router in, and be up to speed, with zero down time. Another bonus. I don't have a dog in this fight, since I don't have a Falcon, or Jetstream, or even a Bo. I just wanted to air my views. Good'day. :-) -- Jim in NC |
Don Hammer wrote:
Weight and cost, yes, complexity, no. Matt Maybe I don't understand what you are getting at. I put wireless in a Gulfstream G-550. System was a short wire from the onboard server (Part of the hight-speed data system) to the wireless hub and and power to the hub. My other option was wires and jacks to each seat and the cockpit from a hub. Why is wireless more complex? Open up the hub and look inside. Then look at a spool of wire. Matt |
![]() "Matt Whiting" wrote Open up the hub and look inside. Then look at a spool of wire. You *still* have to have a hard wired router. Not much difference. You could argue less complexity for the wireless, because you don't have to have a separate port for each device. -- Jim in NC |
The technology to implement wireless is very complex.
However most of the technology is embedded at the chip level. The users never see the complexity. For the users its plug and play. From an electronics designers point of view. I am a EE I should have made a disclaimer up front. |
![]() "Bob" wrote in message ups.com... The technology to implement wireless is very complex. However most of the technology is embedded at the chip level. The users never see the complexity. For the users its plug and play. From an electronics designers point of view. I am a EE I should have made a disclaimer up front. But it is true, that the construction of said complex chips has been worked on, until the level of reliability is quite high, correct? -- Jim in NC |
Hidden costs of owning a Glider | Doug Snyder | Soaring | 17 | March 16th 05 08:46 PM |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
SMALLL airplanes.. | BllFs6 | Home Built | 12 | May 8th 04 12:48 PM |
FS: 1990 Cracker Jack "War Time Airplanes" Minis 6-Card (CJR-3) Set | J.R. Sinclair | Aviation Marketplace | 0 | April 12th 04 05:57 AM |
Looking for Cessna Caravan pilots | [email protected] | Owning | 9 | April 1st 04 02:54 AM |
