Christopher Campbell wrote:
The W-48 155mm nuclear artillery round is 34" long and weighs about 110 lbs. It could fit diagonally in a large suitcase, errrr no it woudldn't. Typical size of a suitcase (and the one claimed by Lebed) is 24x16x8". And it would take two-three people to carry such suitcase (depending on the required distance). And that's an every day sight on the street or airport, right? Three people carying ONE briefcase - it really doesn't look suspicus at all! By omitting the shielding, your device will trigger the most cheapest toy radiation sensor (not to mention the sophisticated ones that would detect you long before you even get into plane). The relatively short halflife of Pu239 means that a large amount of energy is emitted through radioactive decay. The Pu239 produces about 2 watt/kg. That's why a piece of Pu239 is warm. If you would use "Lebed's suitcase" design with only Pu and explosive, the temperature of suitcase would rise from room temperature to the boiling point of water in less than two hours. (And to the alpha-beta transition point soon after). I guess they deliver you "Lebed's refrigerator" for FREE of charge when you buy "Lebed's suitcase nuke". Or maybe the suitcase has a built *large* cooler and a fan on the outside, making it look like a large scale model of a cpu with intel sticker on it - while 3 people carry it around the airport. The Soviets claimed to have built prototype suitcase weapons 20cm thick. A Do you have some relevant document/reference that proves this? It's getting pretty annoying with stroies of "suitcase nukes", "aliens in area 51" and "We were not on the Moon" conspiracies. (No hard feelings) |
In article , x-ray wrote:
Christopher Campbell wrote: The W-48 155mm nuclear artillery round is 34" long and weighs about 110 lbs. It could fit diagonally in a large suitcase, errrr no it woudldn't. Typical size of a suitcase (and the one claimed by Lebed) is 24x16x8". And it would take two-three people to carry such suitcase (depending on the required distance). And that's an every day sight on the street or airport, right? Three people carying ONE briefcase - it really doesn't look suspicus at all! By omitting the shielding, your device will trigger the most cheapest toy radiation sensor (not to mention the sophisticated ones that would detect you long before you even get into plane). But that's not to say that very small nuclear weapons have not been made (and tested) without killing the operators - they have, and by the United States no less. The Davy Crockett was tested in the early 1960s. The M388 projectile weighed 76lbs (the warhead being 51lbs of this), The projectile was 31 inches long and 11 inches wide at its widest point. 2100 Davy Crocketts were deployed between 1961 and 1971. I'm not exactly the world's strongest guy but even I could manhandle the 76lb Davy Crockett projectile. Since the weapons deployed to soldiers in the field didn't kill the soldiers, we can assume that they had adequate shielding. The Davy Crockett round was tested in the Little Feller II test in 1962. The warhead tested was 11 inches wide and 15 inches long, and weighed in at 50lbs. Both a warhead suspended by cables a couple of feet off the ground, and an actual firing of the whole Davy Crockett weapons system was performed. The yields of the explosions were in the 20t range. (20 tonnes, not kilotonnes, tonnes). Even so that's a big bang for a small bomb. It was the last atmospheric test at the Nevada test site. The smallest diameter nuclear device tested by the US was 5 inches in diameter. It exploded with a yield of 190t (it was actually a fizzle). It weighed 96lbs. That's about the weight of my "portable" Roland A-90 keyboard (which has a travel case with wheels on the bottom. I took it to the P'ville fly in in the back of a Bonanza about 3 years ago). That particular round would also fit in my keyboard case. Whilst hardly a suitcase, not many people are suspicious of musicians moving their kit and the wheeled case would make it pretty easy to move on foot. Some more information on the Davy Crockett (and some discussion on 'suitcase nukes') can be found at the Nuclear Weapons Archive: http://nuclearweaponarchive.org/News...ukesExist.html -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
"Dylan Smith" wrote in message
I'm not exactly the world's strongest guy but even I could manhandle the 76lb Davy Crockett projectile. Me too, but for a limited period of time, with each step walking slower and slower. ![]() the field didn't kill the soldiers, we can assume that they had adequate shielding. Of course they had. Point is that i can't find topics for shielding and cooling in Lebed's suitace articles. That's why i have so much pessimism. And remember, pessimist is - an optimist with experience ![]() It weighed 96lbs. That's about the weight of my "portable" Roland A-90 Arghhh! I hate hammer action. If you will ever need something lighter, i recomend JV-90. http://nuclearweaponarchive.org/News...ukesExist.html That is a very good link. I've been visiting this site quite often after, specially after i bought GM-45 radiation detector (computer controlled) few months ago. Frontier Elite Universe: http://www.alioth.net Well. Greetings from Diso system, from an ex. smuggler and a sicko who uses mining grade lasers to attack other ships. My ASP Explorer is parked for the past 3-4 years. From time to time i think about turning on that old thrusty engine. Wish i could find some free time. I had first flight in 1993 (Ross 154 system). |
Frontier Elite Universe: http://www.alioth.net Well. Greetings from Diso system, from an ex. smuggler and a sicko who uses mining grade lasers to attack other ships. Funny where other Elite fans show up :-) -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
![]() "x-ray" wrote in message ... "Dylan Smith" wrote in message I'm not exactly the world's strongest guy but even I could manhandle the 76lb Davy Crockett projectile. Me too, but for a limited period of time, with each step walking slower and slower. ![]() So you put it on one of those two wheel luggage carriers. Problem solved for $25. |
![]() On 5/12/05 2:04 AM, in article , "x-ray" wrote: Christopher Campbell wrote: The W-48 155mm nuclear artillery round is 34" long and weighs about 110 lbs. It could fit diagonally in a large suitcase, errrr no it woudldn't. Typical size of a suitcase (and the one claimed by Lebed) is 24x16x8". And it would take two-three people to carry such suitcase (depending on the required distance). And that's an every day sight on the street or airport, right? Three people carying ONE briefcase - it really doesn't look suspicus at all! By omitting the shielding, your device will trigger the most cheapest toy radiation sensor (not to mention the sophisticated ones that would detect you long before you even get into plane). I made that same point myself in another part of the thread. Even if you managed to get the weight of the briefcase down to 60 lbs, you would look pretty funny trying to carry it. Imagine trying to carry something like the SADM, though. ![]() The UCRL Swift device was only 5" in diameter and 24.5" long. It would have fit easily into Lebed's suitcase. Of course, the whole package would have weighed about 100 lbs, but a suitcase full of books can weigh that much (I know, AllATP's texts fit into a suitcase and weigh 120 lbs.) If Lebed's bombs actually exist, they would probably use technology similar to the Swift -- a linear implosion design using a football shaped subcritical mass. The Soviets claimed to have built prototype suitcase weapons 20cm thick. A Do you have some relevant document/reference that proves this? It's getting pretty annoying with stroies of "suitcase nukes", "aliens in area 51" and "We were not on the Moon" conspiracies. (No hard feelings) Lebed claimed in 1997 that the Soviets had actually manufactured such a device. Of course, no one has ever seen it and you have to wonder what they would have ever used it for. Nevertheless, I think the W-54 does show that bombs of amazingly small size are possible, even if they are still very heavy. I agree that it is extremely unlikely that any terrorist organization would have the capability to manufacture such a device. Stealing or buying one from the Soviets might be possible, but that assumes a) Lebed was telling the truth and b) no one has noticed that such a device is missing. Besides, supposing a group such as Chechen rebels or the Russian mafia managed to obtain the thing -- would they really be eager to turn it over to bin Laden's boys? More likely they would use it to blackmail Russia. |
120 LBS!,
Heck my wife's purse weighs that much!!!! Patrick student SPL aircraft structural mech |
In article , Christopher Campbell wrote:
never been interested in such a weapon. The smallest weapon ever tested by the US was the UCRL Swift device in 1956. I think the Davy Crockett round they tested in the early 60s was actually smaller than that, I think it had a yield of around 20t (but I could be wrong). -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
Apparently you do not understand nuclear weapons. 1) You can NOT put "A bomb" in a suitcase. The US manufactured (and tested) the Davy Crockett nuclear bazooka. It certainly qualifies as a suitcase-sized nuclear weapon. It was a pure fission implosion design, with a maximum yield of around 250t TNT. It was also pretty close to the smallest theoretical size for a nuclear weapon. It weighed about 76lbs and was man-portable. They were actually deployed in the field without the soldiers dying of radiation sickness. There are photographs of them being tested in the Nevada desert. They were designed to destroy advancing Russian tank columns, but it would have been a last ditch suicide mission for the soldiers to use them - at the range they would probably have had to set the fuse, the prompt ionizing radiation would also have killed the soldiers using them even at the lowest yield settings. -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
1/72 Cessna 300, 400 series scale models | Ale | Owning | 3 | October 22nd 13 03:40 PM |
FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Aviation Marketplace | 1 | November 4th 03 12:57 AM |
FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Owning | 1 | November 4th 03 12:57 AM |
FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Products | 1 | November 4th 03 12:57 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
