Service Volumes of VOR's make no sense
Old May 12th 05, 12:45 PM
Peter Clark
On Wed, 11 May 2005 21:10:13 -0700, Antoņio
I was at a CFI safety meeting today and the subject of VOR service
volumes came up. The AIM describes the Standard High Service Volume as
providing positive course guidance at varying distances depending on
your altitude--40nm at 1000ft., 100nm at 14,500ft, 130nm at 45,000ft, etc.
If the VOR is a "line of sight" signal device. How can there be varying
distances of service at varying altitudes? I mean, shouldn't I be able
to pick up a VOR radial from the moon as long as no obstructions intervene?
The way it was explained to me was that once you get above a certain
altitude you can start getting interference from other VORs with the
same frequency, so the 'valid' radius starts getting shorter again.
Old May 12th 05, 10:26 PM
Steven P. McNicoll
"Antoņio" wrote in message
I was at a CFI safety meeting today and the subject of VOR service volumes
came up. The AIM describes the Standard High Service Volume as providing
positive course guidance at varying distances depending on your
distances of service at varying altitudes? I mean, shouldn't I be able to
Yes, and every other VOR on that frequency as well. The altitude/distance
limits ensure you won't receive an unwanted VOR signal. Note that the
service volume decreases from 130 miles to 100 miles above FL 450.
Old May 13th 05, 02:27 AM
Andrew Sarangan
Isn't that the reason certain airways have a MAA - Maximum Authorized
Altitude?
"Steven P. McNicoll" wrote in
nk.net:
"Antoņio" wrote in
message ...
as providing positive course guidance at varying distances depending
on your altitude--40nm at 1000ft., 100nm at 14,500ft, 130nm at
45,000ft, etc.
varying distances of service at varying altitudes? I mean, shouldn't
I be able to pick up a VOR radial from the moon as long as no
altitude/distance limits ensure you won't receive an unwanted VOR
signal. Note that the service volume decreases from 130 miles to 100
miles above FL 450.
Old May 13th 05, 03:11 PM
Steven P. McNicoll
"Andrew Sarangan" wrote in message
1...
Altitude?
Frequency overlap is probably the most common reason but they may also exist
due to conflicts with special use airspace.
Old May 13th 05, 09:07 AM
Antoņio
Exactly! And that was the reason for my confusion and original question.
Antonio
Old May 13th 05, 06:46 PM
Darrell S
The signal strength from a VOR decreases with distance. You are on a
straight line to the VOR from the moon but the signal strength would be too
low to create guidance.
Darrell R. Schmidt
B-58 Hustler History: http://members.cox.net/dschmidt1/
"Steven P. McNicoll" wrote in message
nk.net...
volumes
to
Old May 13th 05, 06:51 PM
Steven P. McNicoll
"Darrell S" wrote in message
news:4R4he.25286$tQ.4405@fed1read06...
too low to create guidance.
I think he was speaking figuratively, aircraft do not operate very well
outside the atmosphere.
Old May 14th 05, 01:08 AM
Morgans
too
Signal is too weak to use with today's receivers, but a signal is never too
weak, with the right receiver. Look at the space robots; still in contact,
at the edge of the solar system. Amazing.
Jim in NC
Old May 14th 05, 02:26 AM
Larry Dighera
On Fri, 13 May 2005 19:08:15 -0400, "Morgans"
wrote in ::
but a signal is never too weak, with the right receiver.
True, provided the random background noise doesn't significantly
exceed the signal strength of the source you want to receive.
Old May 15th 05, 08:10 AM
Don Byrer
Hi...
To try to make a realllllly long explanation short....(er)
Those are the 'design' or 'advertised' service volumes. This is the
required minimum coverage they are flight checked for.
Will the FAA guarantee coverage outside of that? Nope.
Will you pick up a useable signal outside of that?
Possibly....maybe...depending on altitude/distance/terrain
But they don't guarantee xx nm at xxxx feet.
--Don Byrer
Don Byrer
Instrument Pilot Commercial/CFI Student
Electronics Technician, RADAR/Data/Comm @ CLE
Amateur Radio KJ5KB
"I have slipped the surly bonds of earth; now if I can just land without bending the gear..."
millionaire on the Internet... in weeks! Malcolm Austin Soaring 0 November 6th 04 12:14 AM
Copyright Š2004-2025 AviationBanter.
