On 16 May 2005 11:01:36 -0700, "Sport Pilot"
wrote: Steve wrote: Luke Scharf wrote: Steve wrote: But there are more and more small diesels that run just as fast as gasoline engines. There's no fundamental limit thats any different than a gasoline engine, really, but up until now there's not been a demand for high-RPM diesels. When I was reading about the Volkswagen TDI engine, I vaguely remember coming across someone who said that the redline of that engine was set by the speed which which the burning fuel expanded. Sounds rather fundamental to me - but, then again, I'm a computer guy. -Luke In almost ALL real-world engines, the actual limit is set by the point at which some mechanical component would fail. The engine's torque *may* drop off well before the mechanical failure point if it can't ingest enough fuel or air at high speed. In the case of a diesel, you can pretty much increase the burn rate to as high as the mechanical parts can tolerate by increasing turbocharger boost (and injection rate to match). Since detonation isn't possible (no fuel exists in the cylinder until combustion is supposed to begin anyway) the only limits to boost pressure are mechanical in nature. In practical terms, no one really wants or needs a 9000 RPM diesel, though. Diesel fuel is not conducive to high speed running. Nor is a long injection period through much of the expansion phase. Yes you can boost the turbocharger and the other things, but an Otto cycle engine will respond with even higher speeds. Parts failure from speed is not a problem with diesel engines, the rotating parts have to be bigger than an otto engine because of the higher compression, yet the otto engine will turn higer RPM's with smaller parts. Ever seen a "super modified" pulling tractor??? I think, from the sound of one at full tilt, that 9000 RPM would be on the low side - turboed, and sometimes also supercharged (turbo-compounded) they scream like a wildcat in heat. |
![]() wrote: On 16 May 2005 11:01:36 -0700, "Sport Pilot" wrote: Steve wrote: Luke Scharf wrote: Steve wrote: But there are more and more small diesels that run just as fast as gasoline engines. There's no fundamental limit thats any different than a gasoline engine, really, but up until now there's not been a demand for high-RPM diesels. When I was reading about the Volkswagen TDI engine, I vaguely remember coming across someone who said that the redline of that engine was set by the speed which which the burning fuel expanded. Sounds rather fundamental to me - but, then again, I'm a computer guy. -Luke In almost ALL real-world engines, the actual limit is set by the point at which some mechanical component would fail. The engine's torque *may* drop off well before the mechanical failure point if it can't ingest enough fuel or air at high speed. In the case of a diesel, you can pretty much increase the burn rate to as high as the mechanical parts can tolerate by increasing turbocharger boost (and injection rate to match). Since detonation isn't possible (no fuel exists in the cylinder until combustion is supposed to begin anyway) the only limits to boost pressure are mechanical in nature. In practical terms, no one really wants or needs a 9000 RPM diesel, though. Diesel fuel is not conducive to high speed running. Nor is a long injection period through much of the expansion phase. Yes you can boost the turbocharger and the other things, but an Otto cycle engine will respond with even higher speeds. Parts failure from speed is not a problem with diesel engines, the rotating parts have to be bigger than an otto engine because of the higher compression, yet the otto engine will turn higer RPM's with smaller parts. Ever seen a "super modified" pulling tractor??? I think, from the sound of one at full tilt, that 9000 RPM would be on the low side - turboed, and sometimes also supercharged (turbo-compounded) they scream like a wildcat in heat. Compare that maximum to the gasoline maximum. Formula 1 cars will exceed 20,000 RPM. |
![]() "Steve" wrote In practical terms, no one really wants or needs a 9000 RPM diesel, though. Oh, I don't know. NASCAR might be interested in going diesel ! g -- Jim in NC |
Steve wrote:
In almost ALL real-world engines, the actual limit is set by the point at which some mechanical component would fail. The engine's torque *may* drop off well before the mechanical failure point if it can't ingest enough fuel or air at high speed. In the case of a diesel, you can pretty much increase the burn rate to as high as the mechanical parts can tolerate by increasing turbocharger boost (and injection rate to match). Since detonation isn't possible (no fuel exists in the cylinder until combustion is supposed to begin anyway) the only limits to boost pressure are mechanical in nature. In practical terms, no one really wants or needs a 9000 RPM diesel, though. Actually, detonation can and does occur in Diesels. With today's Diesel fuels and injection methods the fuel does not burn INSTANTLY upon injection. The droplets are too large. The droplets tend to evaporate from their surface area. It IS possible for unburned gases evaporated from the fuel to exist in the chamber and detonate in local regions. The effect is nowhere as severe as the detonation that occurs in spark engines at times. Interesting traces made with high frequency pressure sensors indicate these local "peaks" in combustion pressure when this occurs. It is the cause of the "tinkling" sound that Diesels occasionally make. Detonation is not a full or nothing situation. Local regions can undergo detonation even while the majority of the charge undergoes normal wavefront burning, in either Diesel or SI. |
a gasoline engine, really, but up until now there's not been a demand for high-RPM diesels. Thought I had responded to this before, but cannot find it. There IS a fundamental reason diesels do not turn as many revolutions as a gas engine. Injecting the fuel throught most of the expansion cycle prevents speed, but does give a constant push. You could shorten the injection so that the end of the injection is closer to TDC, but then it would be more of an otto cycle. If you put too much fuel at or near TDC then you would have the same problem as an otto engine with high compression and low octane fuel. Diesel fuel is not high octane. |
BSFC vs gas mileage, 2 stroke vs 4 stroke | Jay | Home Built | 10 | August 24th 04 02:26 PM |
Diesel Jodel information..........and .........diesel plane groups | Roland M | Home Built | 1 | January 4th 04 04:04 AM |
Diesel Jodel information..........and .........diesel plane groups | Roland M | General Aviation | 1 | January 4th 04 04:04 AM |
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot | Roland M | General Aviation | 2 | September 13th 03 12:44 AM |
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot | Roland M | Rotorcraft | 2 | September 13th 03 12:44 AM |
