![]() "Steve" wrote In practical terms, no one really wants or needs a 9000 RPM diesel, though. Oh, I don't know. NASCAR might be interested in going diesel ! g -- Jim in NC |
Steve wrote:
In almost ALL real-world engines, the actual limit is set by the point at which some mechanical component would fail. The engine's torque *may* drop off well before the mechanical failure point if it can't ingest enough fuel or air at high speed. In the case of a diesel, you can pretty much increase the burn rate to as high as the mechanical parts can tolerate by increasing turbocharger boost (and injection rate to match). Since detonation isn't possible (no fuel exists in the cylinder until combustion is supposed to begin anyway) the only limits to boost pressure are mechanical in nature. In practical terms, no one really wants or needs a 9000 RPM diesel, though. Actually, detonation can and does occur in Diesels. With today's Diesel fuels and injection methods the fuel does not burn INSTANTLY upon injection. The droplets are too large. The droplets tend to evaporate from their surface area. It IS possible for unburned gases evaporated from the fuel to exist in the chamber and detonate in local regions. The effect is nowhere as severe as the detonation that occurs in spark engines at times. Interesting traces made with high frequency pressure sensors indicate these local "peaks" in combustion pressure when this occurs. It is the cause of the "tinkling" sound that Diesels occasionally make. Detonation is not a full or nothing situation. Local regions can undergo detonation even while the majority of the charge undergoes normal wavefront burning, in either Diesel or SI. |
There's no fundamental limit thats any different than
a gasoline engine, really, but up until now there's not been a demand for high-RPM diesels. Thought I had responded to this before, but cannot find it. There IS a fundamental reason diesels do not turn as many revolutions as a gas engine. Injecting the fuel throught most of the expansion cycle prevents speed, but does give a constant push. You could shorten the injection so that the end of the injection is closer to TDC, but then it would be more of an otto cycle. If you put too much fuel at or near TDC then you would have the same problem as an otto engine with high compression and low octane fuel. Diesel fuel is not high octane. |
2-stroke diesel is the (near) future? | Max Kallio | Home Built | 134 | July 18th 05 12:39 AM |
BSFC vs gas mileage, 2 stroke vs 4 stroke | Jay | Home Built | 10 | August 24th 04 02:26 PM |
Diesel Jodel information..........and .........diesel plane groups | Roland M | Home Built | 1 | January 4th 04 04:04 AM |
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot | Roland M | Home Built | 3 | September 13th 03 12:44 AM |
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot | Roland M | Rotorcraft | 2 | September 13th 03 12:44 AM |
