2-stroke diesel is the (near) future?
Old May 17th 05, 01:25 PM
Sport Pilot
On 16 May 2005 11:01:36 -0700, "Sport Pilot"
Steve wrote:
Luke Scharf wrote:
Steve wrote:
But there are more and more small diesels that run just as fast
as
gasoline engines. There's no fundamental limit thats any
different
than a gasoline engine, really, but up until now there's not
been
a
demand for high-RPM diesels.
When I was reading about the Volkswagen TDI engine, I vaguely
remember
coming across someone who said that the redline of that engine
was
set
by the speed which which the burning fuel expanded.
Sounds rather fundamental to me - but, then again, I'm a
computer
guy.
-Luke
In almost ALL real-world engines, the actual limit is set by the
point
at which some mechanical component would fail. The engine's torque
*may*
drop off well before the mechanical failure point if it can't
ingest
enough fuel or air at high speed. In the case of a diesel, you can
pretty much increase the burn rate to as high as the mechanical
parts
can tolerate by increasing turbocharger boost (and injection rate
to
match). Since detonation isn't possible (no fuel exists in the
cylinder
until combustion is supposed to begin anyway) the only limits to
boost
pressure are mechanical in nature. In practical terms, no one
really
wants or needs a 9000 RPM diesel, though.
Diesel fuel is not conducive to high speed running. Nor is a long
injection period through much of the expansion phase. Yes you can
boost the turbocharger and the other things, but an Otto cycle
engine
will respond with even higher speeds. Parts failure from speed is
not
a problem with diesel engines, the rotating parts have to be bigger
than an otto engine because of the higher compression, yet the otto
engine will turn higer RPM's with smaller parts.
Ever seen a "super modified" pulling tractor???
I think, from the sound of one at full tilt, that 9000 RPM would be
on
the low side - turboed, and sometimes also supercharged
(turbo-compounded) they scream like a wildcat in heat.
Compare that maximum to the gasoline maximum. Formula 1 cars will
exceed 20,000 RPM.
BSFC vs gas mileage, 2 stroke vs 4 stroke Jay Home Built 10 August 24th 04 02:26 PM
Diesel Jodel information..........and .........diesel plane groups Roland M Home Built 1 January 4th 04 04:04 AM
Diesel Jodel information..........and .........diesel plane groups Roland M General Aviation 1 January 4th 04 04:04 AM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M General Aviation 2 September 13th 03 12:44 AM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M Rotorcraft 2 September 13th 03 12:44 AM
