Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Rotorcraft
2-stroke diesel is the (near) future?
Old May 25th 05, 06:36 PM
Steve
Thomas Tornblom wrote:
Steve writes:
Sport Pilot wrote:
Why the obvious apple and orange comparision?
To refute the statement that "more speed is more power."
You need to compare engines of equal size.
OK, Lets do it!
Dodge 5.9 Liter v8 gasoline engine: 230 horsepower at ~5000 RPM
Compared to:
Dodge/Cummins 5.9 Liter turbo-diesel engine: 325 horsepower at 2900 RPM
More speed is NOT more power any more than more torque at the same
uh?
huh. Read it again.
More torque at the same speed *is* more power.
That's exactly what I've been saying. You can get more power by
increasing torque OR rpm or both.
Old May 25th 05, 07:08 PM
Thomas Tornblom
Steve writes:
Steve writes:
uh?
huh. Read it again.
Ok.
English is not my native language, and I read the sentence such that
the "NOT" in the first half also implied that there was an implicit
"NOT" in the second half, which made the statement wrong.
Then we agree :-)
Thomas
Old May 25th 05, 09:45 PM
Steve
Steve writes:
Ok.
And I'll admit, it was a poorly written sentence. My bad.
Old May 25th 05, 02:02 AM
Sport Pilot
OK, Lets do it!
Compared to:
More speed is NOT more power any more than more torque at the same speed
is more power.
Steve,
As you said power is torque * RPM, so for the same torque more speed
is power. In fact with 0 RPM you have no power only a force. No I
have not argued that desiels cannot deliver power by increasing torque.
Only that their inherent design and fuel limits their maximum speed.
Your example is a poor one most diesels of equivelant size will deliver
more torque at less RPM and have less total horsepower. I don't know
where you found that pitiful Dodge 5.9 liter engine. I have a 4.7 V8
in my Grand Cherokee and it puts out 260+ HP. I know that the 5.7
Liter hemi V8 puts out about 320 or so HP and it is not turbocharged.
So that is a more equal comparison. Unlike the apple orange examples
you put up.
Old May 25th 05, 07:03 PM
Steve
Sport Pilot wrote:
Steve,
is power.
Or for the same SPEED, more TORQUE is more power. That's the part of the
equation that you've never acknowledged.
Not always true (obviously), and when looking at modern diesels its not
even GENRALLY true anymore. That's EXACTLY why I picked the example that
I did! If you don't like the Dodge comparison, go look at a
Ford/Navistar 6-liter diesel and compare it to the closest-sized Ford
(5.4L) gasoline engine tuned for a truck application. 10 years ago, the
diesel would have won on low RPM torque, but been lacking in peak HP.
That is no longer the case most of the time, because diesels are now
*always* turbocharged, and most of the time have modern electronic
injection control over both injection rate AND duration.
I don't know
There's nothing pitiful about it at all, it was an EXCELLENT truck
engine used from 1972 until 2003. When built for power rather than
torque, it can easily put out well over 400 Hp without turning 7000 RPM,
but as delivered in factory trucks, it was tuned for a torque band
that's flat as Kansas over about a 3500 RPM span, and that results in a
rather modest 230 HP.
I have a 4.7 V8
The 4.7 is the replacement for the 5.2, and while a fine engine in its
own right, its a little bit low in the torque department. It doesn't
move the fullsize Ram pickup or even the Durango with much authority-
the old lower-HP rated 5.9 actually "feels" a lot peppier in around-town
driving because it has more torque below 3000 RPM than the 4.7L does,
despite a lower peak HP rating. That's a symptom mostly of its small
size- when you excessively constrain the displacement of an engine, you
start HAVING to spin it faster and faster to get the same power and you
sacrifice torque at the lower RPM levels- Which is a key part of the
point I've been driving home. Modern gasoline-powered cars and trucks
tend to have very high peak horsepower ratings- and yet many of them
feel weak compared to older cars, simply because all that high-RPM
horsepower comes at the expense of useful low-RPM torque, and they need
5- and 6-speed transmissions just to match the performance of older
torquier engines.
Gas engines have been pushed smaller and lighter by fuel economy and
emissions considerations, resulting in peaky torque curves, poorer
low-RPM torque, and higher peak HP to compensate.
Old May 24th 05, 10:48 PM
Steve
Sport Pilot wrote:
The model
diesel engines will not turn as fast as the gas or methanol/nitro
engines because the fuel (ether and kerosene) will not burn as fast.
I say again: there is no magic rule that says "diesel burns slower" than
gasoline. Increasing the boost pressure can increase the burn rate AS
MUCH AS YOU WANT. Its just not done most of the time, because no one
WANTS a 7000 RPM engine when a 4000 RPM engine is available to do the
same job. People only build 7000 RPM engines when there's no other way
to get the power.
This is because the fuel burns slower,
not because of the cycle, because all, the spark ignition gas engine,
the glow plug methanol/nitro engine, and the compression ignition
engine, are actually otto cycle engines.
No, that's already been covered. Diesel (true diesel with either direct
or pre-chamber injection) is a subtly different cycle than the Otto
cycle. Its constant-pressure combustion instead of constant-volume
combustion.
Old May 25th 05, 02:21 AM
Sport Pilot
Steve wrote:
Sport Pilot wrote:
The model
to get the power.
combustion.
I was not quite correct if I said desiel fuel burns slower, it is
however made to ignite better with desiel engines so that the fuel
ignites spontanously when injected. The fuel burns slower because it
is injected over a period of time. However, I may have been correct
about the model fuel. There are diesel conversion heads for model glow
engines. This replaces the head and glow plug with a head with a
varible compression. You adjust the timing by adjusting the
compression. The fuel is a mix of kerosene, ether, amyl nitrate, and
oil. This fuel will ignite at a much lower temperature than true
desiel fuel. The ether and amyl nitrate are the componets which ignite
at a low temp. Though ether is extremely volatile it is not a very
high energy fuel and I think it burns slowly. These converted engines
will turn large propellers at slower speeds than the glow engines they
were converted from.
Another example of a high energy fuel that limits speed is
nitromethane. Because it is a monopropellent the racers can pretty
much inject as much as their ignition can ignite, except for
hydrolocking. That is if more fuel is injected than the combustion
chamber volume the engine will blow up. But nitro burns slowly so RPM
is more or less limited to just over 10,000 RPM loaded. The slow
burning is why you see huge flames coming out the exhaust.
Old May 25th 05, 03:34 PM
Don Stauffer
Steve wrote:
Sport Pilot wrote:
The model
to get the power.
Hydrogen, for example, is a very rapid burning fuel. Hydrogen can and
has been used in Diesels. I also suspect that natural gas, another
common diesel fuel, burns at a high rate. The slow burn rate with many
liquid diesel fuels is due to the time it takes the surface area of the
droplets to vaporize.
2-stroke diesel is the (near) future? Max Kallio Home Built 134 July 18th 05 12:39 AM
BSFC vs gas mileage, 2 stroke vs 4 stroke Jay Home Built 10 August 24th 04 02:26 PM
Diesel Jodel information..........and .........diesel plane groups Roland M Home Built 1 January 4th 04 04:04 AM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M Home Built 3 September 13th 03 12:44 AM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M Rotorcraft 2 September 13th 03 12:44 AM
