tuttie wrote:
I used to teach paragliding and have some not-so-positive opinions on the subject... .... If you fly in laminar air--say at the beach--where there is no thermal On hot summer days, the sky above the Swiss Alps is literally filled with paragliders. Summer days over mountains... not exactly what you would call a no-thermal situation. Despite, there are very few accidents, in fact, there are even years without any accident at all. Modern equipment is very safe, if it is well maintained. Paragliding is very safe, if done carefully. Stefan |
![]() I was witness to a paragliding accident in which an expert parachutist (over 1000 jumps) died. The winds were about 5mph right about sunset. He experienced a wingtip deflation and spiraled in to slam his face on a rock. When I got to him he was attempting to breath and air was excaping through his forehead. I gave him CPR for about an hour before the paramedics arrived. Now go tell the family of that young man that Paragliding is "safe" . Sorry my friend, but if you think thermaling in the alps is "safe" you may be dead wrong some day. Antonio |
Antoņio wrote:
Sorry my friend, but if you think thermaling in the alps is "safe" you may be dead wrong some day. Paragliding is not less safe than other aviation activities. There is still a risk in everything you do, of course. Stefan |
![]() Stefan wrote: Anto=F1io wrote: Sorry my friend, but if you think thermaling in the alps is "safe" you may be dead wrong some day. Paragliding is not less safe than other aviation activities. There is still a risk in everything you do, of course. Interesting that this should come up today. I was watching a show on TLC last night with a video shot from a paraglider that crashed. I wasn't aware of their susceptability to turbulence. At the beginning, the pilot and ground crew seemed concerned because the previous day there had been turbulence that caused some scary moments. Right after the pilot reported that conditions seemed better, he hit some turbulence. It appeared that one side of the canopy collapse, sending him into a hard spiral from which he could not recover. Eventually, he had to cut away the canopy and deploy a reserve. He ended up crashing into a tree. Funny part : Right after he told his buddy that he was in a tree and would probably break his leg if he fell, the lines gave way and down he went. He didn't break his leg. Overall, I was surprised that the canopy could collapse so easily because of turbulent air. I've skydived several times (similar looking system) and have never heard about this. Here in Central AZ, skydivers are always jumping, even when the 110F+ temps are creating some nasty convective turbulence. What is it about paragliding that's so different. All I've noticed is that the paraglider canopy looks thinner and is often pointed at the ends. Just wondering, John Galban=3D=3D=3D=3D=3DN4BQ (PA28-180) |
The paraglider is not the same machine as a parachute, as you have
noticed. It has a higher aspect ratio (width to length ratio, for you non-pilots) which gives it a greater glide ratio. Greater glide ratio equates to greater instability in a paraglider. Instablility, in this case, is the tendency of the paraglider to collapse under, for example, the varying the front-to-back air pressures of thermal activity. Paragliders are not designed to take terminal deployment -- that is, a full-fall deployment. They are made of lighter materials in the sail and lines. They can come apart at terminal velocities. Paragliders have more cells to inflate and are not nearly as stable as parachutes. Once inflated, parachutes tend to stay inflated while paragliders do not. Any small end-cell deflation in a paraglider can cause a spiraling down condition. Unless the pilot is on the ball and shifts pressures to the deflated side the spiral develops to a point where it is unrecoverable. This happens in matter of seconds. Finally, the shape and condition of the paraglider is critical. This shape changes over time as the material wears and the lines stretch or the fabric becomes more porous. The flight characteristics of a worn paraglider can make it positively dangerous regardless of the conditions. Antonio |
![]() Anto=F1io wrote: The paraglider is not the same machine as a parachute, as you have noticed. snip Thanks for the thorough explanation. I appreciate it! John Galban=3D=3D=3D=3D=3DN4BQ (PA28-180) |
In article .com, tuttie wrote:
1. You are under a wing that can and does collapse. In fact, in any sort of thermally conditions you *will* experience a partial to full deflation. Really? The paragliding people around here go out and *soar* their paragliders quite deliberately in thermal conditions. They get some pretty good altitude gains too. Sometimes they make us glider pilots a bit envious because they can launch straight into the lift. If we're using the winch, if there's no lift in the immediate vicinity of the airfield we are stuffed... -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
I hope my contribution is not counter-productive, but I also have a friend who
was injured paragliding, and could easily have been killed. He hurt his back in a hard landing, after a deflation - he lived , but won't be doing any more sporting activities. What scares me about it is, according to his account of the incident, there was a ![]() this event, and b ![]() This is different from aviation, where virtually everything that is likely to befall us is the direct result of our actions, and we have, at least theoretically a ![]() ![]() possibility to recover from many situations, even after we have allowed ourselves to get into them. I have no business (or desire) in trying to scare someone away from something that millions enjoy, and that I know little about - but that helplessness doesn't sound like fun to me. I won't be joining you up there, even if the open air must be exhilirating. G Faris |
Greg Farris wrote:
the incident, there was a ![]() this event, I simply don't buy this. He made a mistake. Modern paragliders don't "just collapse". and b ![]() If high enough, modern paragliders will recover, and if everything fails, responsible paraglider pilots wear a security chute. If not high enough, though... well, then you're in about the same situation as in a low spin. I don't know about the place you live, but where I live, there are usually a lot more paragliders in the air than aircraft. Despite this, at the end of each year, there are more dead aircraft pilots than dead paraglider pilots. Of course, if you see die your best friend, you don't care about statistics. Stefan |
Greg Farris wrote:
the incident, there was a ![]() I simply don't buy this. He made a mistake. Modern paragliders don't "just collapse". His mistake may have been as simple as flying in unflyable conditions. this event, and b ![]() If high enough, modern paragliders will usually recover. and if everything fails, responsible paraglider pilots wear a security chute. If not high enough, though... well, then you're in about the same situation as in a low spin. I don't know about the place you live, but where I live, there are usually a lot more paragliders in the air than aircraft. Despite this, at the end of each year, there are more dead aircraft pilots than dead paraglider pilots. As I said, there is always some risk in every flying. And if you see die your best friend, you don't care about statistics, of course. Stefan |
Cheap sailplanes | tango4 | Soaring | 100 | December 21st 04 08:21 PM |
new pictures in Paragliding Gallery | jaro | Soaring | 0 | July 8th 04 11:30 PM |
www with paragliding adds | Mariusz Klos | Aviation Marketplace | 0 | April 22nd 04 11:53 AM |
New Paragliding Gallery | jaro | Soaring | 0 | December 28th 03 08:51 PM |
Red Bull Vertigo 2003 | Red Bull Vertigo | Aerobatics | 2 | August 11th 03 08:02 PM |
