Dick,
The hesitation at 1100-1200 rpms in a C-85 is normal. I have it on mine (275 smh with 0-200 conversion stc) as do most of my Luscombe brethren with the C-85. I recently had an exhaust valve to stick in flight. It was interesting to say the least, and in reaction to that experience I would like to pursue a glider rating ;-). My valve in my 275 hour ECI cylinder was stuck but good. My engine guy reamed it out a little as he thought the clearance was a little tight. MMO is now part of my regular maintenance routine. Deb -- 1946 Luscombe 8A (His) 1948 Luscombe 8E (Hers) 1954 Cessna 195B, restoring (Ours) Jasper, Ga. (JZP) "Dick" wrote in message ... Old WW2 mechanic says he hears a sticky valve on my C-85 when I fire up for first time in morning but can't describe the sound and says it lasts only as long as a finger snap. Wants me to add Marvel Mystery oil. I use Aeroshell 100 (50 weight) and change it every 25 hours. I can't detect any roughness upon initial start around 900-1000 rpm in front of my hanger nor during the taxi a couple of minutes to a runup spot. On throttling up to 1500 for the mag check, I notice a slight hesitation around 11-1200 rpm that goes away quickly and thought was just from the low speed taxi. Since I had to put a rental down about 7 years ago for a valve problem (per the FBO), there is a little "pucker" factor regarding this conversation G. Light Plane Maintenance book references "hand proping before first start of day to find 'flat' cylinder". Not sure I can identify a rapid falloff in turning resistance (books definition). Concern doesn't seem to get to the point where the "cold cylinder" test is applicable as doesn't last long (his finger snap). Am I chasing nothing or what is a valid approach? Thanks, Dick |
![]() Deborah McFarland wrote: Dick, The hesitation at 1100-1200 rpms in a C-85 is normal. I have it on mine (275 smh with 0-200 conversion stc) as do most of my Luscombe brethren with the C-85. This is fairly common on a lot of carbureted engines. It usually occurs at the point where the carb is shifting from the idle circuit to the main jet. John Galban=====N4BQ (PA28-180) |
"Deborah McFarland" wrote:
Dick, The hesitation at 1100-1200 rpms in a C-85 is normal. I have it on mine (275 smh with 0-200 conversion stc) as do most of my Luscombe brethren with the C-85. I recently had an exhaust valve to stick in flight. It was interesting to say the least, and in reaction to that experience I would like to pursue a glider rating ;-). My valve in my 275 hour ECI cylinder was stuck but good. My engine guy reamed it out a little as he thought the clearance was a little tight. MMO is now part of my regular maintenance routine. Deb Hey Debby, it's been far too long. Does the gang still get together Saturday afternoons at JZP? Gotta catch up. David O |
![]() Dick wrote: snip Light Plane Maintenance book references "hand proping before first start of day to find 'flat' cylinder". Not sure I can identify a rapid falloff in turning resistance (books definition). I think you can. It should be pretty straight forward. As you rotate the prop you can feel the resistance from each cylinder on the compression stroke. If you hit a cyl. with a stuck valve, you'll notice the difference in resistance right away. If it's quiet, you should also hear hissing at the exhaust pipe if it's an exhaust valve. John Galban=====N4BQ (PA28-180) |
Two of us tried the "armstrong method" (rotating by hand) yesterday and both
thought we got very slightly lower resistance, but on different cylinders on opposite sides of the engine. Him #1 and me #2 .. Decided to do a "differential test" with the engine cold, rather than warmed up. Our thought being that any matter between seat and valve would indicate a lower reading. Observed 78/80 on three and 77/80 on the fourth. For last 5 years the readings have been in the 76-78 over 80 psi range. Don't know if it matters in my case, but realize now that I've never listened for any leaks. My helper did mention that he thought the leakdown period should be about 5 minutes instead of just holding 80 psi long enough to observe where indicator stops... Thanks, Dick ps Glad to hear that 11-1200 rpm hesitation is normal. |
They call that the "Continental cough"...My A-65 doesn't do it, my dad's
C-85 doesn't do it, but my old C-85 on my Chief did. Don't think that is worth worrying about... Scott http://corbenflyer.tripod.com Dick wrote: Two of us tried the "armstrong method" (rotating by hand) yesterday and both thought we got very slightly lower resistance, but on different cylinders on opposite sides of the engine. Him #1 and me #2 .. Decided to do a "differential test" with the engine cold, rather than warmed up. Our thought being that any matter between seat and valve would indicate a lower reading. Observed 78/80 on three and 77/80 on the fourth. For last 5 years the readings have been in the 76-78 over 80 psi range. Don't know if it matters in my case, but realize now that I've never listened for any leaks. My helper did mention that he thought the leakdown period should be about 5 minutes instead of just holding 80 psi long enough to observe where indicator stops... Thanks, Dick ps Glad to hear that 11-1200 rpm hesitation is normal. |
Here are some interesting pictures of what can happen when the engine
is unhappy... http://carneyaviation.com/enginefire/ -Robert |
![]() "Robert M. Gary" wrote in message oups.com... Here are some interesting pictures of what can happen when the engine is unhappy... http://carneyaviation.com/enginefire/ Ahh, that's not so bad! Find all the pieces, and weld them back together. Try to get to that TBO, that you got cheated from! ;-) -- Jim in NC |
![]() Wow - what mayhem! I hope you'll post the prognostication on what failed first. Congrats on a safe landing. From your pix it could look like the con rod failed, but were either of the the rod bolts found? There were some bogus bolts some years back now removed by an AD and a lot of bogus bolt publicity. I understand the normal spec for Lycoming rod bolts does not involve tightening only to a torque, but rather ends with a turn-of-the-wrench method. If the bolt strength happens to be low, the usual torque-only procedure won't detect it unless the mechanic is very experienced and suspicious. Be careful that failed parts don't mysteriously get lost by those that might have some resposnibility for this mechanical carnage. |
Replacing fuel cut-off valve with non-a/c part??? | Michael Horowitz | Owning | 46 | January 15th 05 10:20 PM |
WTB: ASW 27A water valve | Peter Van Camp | Soaring | 0 | April 28th 04 10:37 PM |
Stuck valve versus plugged injector | Viperdoc | Owning | 6 | April 13th 04 12:15 AM |
Dry Valve Lash | jls | Home Built | 6 | April 5th 04 06:43 PM |
Q: Disecting a cut-off valve? | Michael Horowitz | Home Built | 0 | March 6th 04 01:47 PM |
