The Alaraus is not a Light Sport Aircraft by US standards.
Among other things, it has a gross weight of 1,692 lbs; the LSA maximum is 1,320 lbs for SEL. And by definition, there cannot be an IFR certified LSA, as they are only approved for day VFR as an LSA. I've been researching these aircraft for quite a while, and the magic numbers pretty much fall into the $75,000 - $85,000 range, reasonably equipped. Of course, most of them offer upgrades that could push them to $100,000. "Paul Tomblin" wrote in message ... In a previous article, "Morgans" said: "Paul Tomblin" wrote Somebody emailed me as the contact for my flying club trying to convince us to buy a new LSA. The only problem was that this thing only carried about 500 pounds, and it cost $120,000. What is selling for 120,000 bucks? I have not seen any that cost anywhere near that! It's called "AMD Alarus". Useful load 607 pounds, fully IFR equipped $129,900. -- Paul Tomblin http://xcski.com/blogs/pt/ "Grove giveth and Gates taketh away." - Bob Metcalfe (inventor of Ethernet) on the trend of hardware speedups not being able to keep up with software demands |
In a previous article, "Lakeview Bill" said:
The Alaraus is not a Light Sport Aircraft by US standards. Reading over the email, he never actually said it was a LSA - I misinterpreted since first he introduced the Alarus, and then he asked if the club was interested in adding a LSA to the fleet. -- Paul Tomblin http://xcski.com/blogs/pt/ It's better to be on the ground wishing you were flying, than up there wishing you were on the ground. |
gilan wrote:
Do you own or are you planning to buy or build an aircraft that fits into the Light Sport Aircraft rules? The airplane can be an older "factory" certified airplane such as the Cub or Ercoupe, a new "factory" S-LSA or an experimental that does or will comply with the LSA rules. http://groups.yahoo.com/group/Sport_...eys?id=1690505 I just bought N646F, a Kolb Firestar II that's registered experimental A/B (and is well within the LSA restrictions). I don't plan to buy an SLSA. What few that are currently are available are way way too expensive... If I build my next plane, I'll likely simply register it experimental, since about the same amount of work and paperwork will likely be involved and I'll be able to get the repairman's cert without taking the class. I personally don't see any utility for the ELSA and especially the SLSA classifications, at least not at this point. Right now, you basically already have to have a ticket to participate in Sport Pilot since you can't really get a Sport Pilot ticket yet. This is more or less the same situation with the planes as well....... May as well go experimental.. LS N646F |
Light Sport Aircraft for Private Pilots (Long) | Jimbob | Owning | 17 | March 1st 05 03:01 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 1st 04 02:31 PM |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | September 2nd 04 05:15 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
