"normal" procedure for pop-up filing
Old May 26th 05, 08:40 PM
Steven P. McNicoll
"OtisWinslow" wrote in message
m...
Here's what he said and what I reply to:
"pre-file your VFR flight plan with DUATS
so ATC already has a strip on you at initial call-up, just like with IFR."
Yeah, and here's what he said earlier in the thread and what I initially
replied to:
"I've been told you can play tricks with DUAT, filing an IFR flight plan and
putting 'VFR' in the remarks section, but you shouldn't have to resort to
subterfuge like that for what seems like such a simple and logical thing."
We're talking about filing an IFR flight plan through DUATS with "VFR" as
the requested altitude for the purpose of generating strips for flight
following, not about filing a VFR flight plan for search and rescue
purposes.
If you file an IFR flight plan with a VFR altitude they'll assume you
want FF.
Exactly.
Old May 27th 05, 03:55 AM
Jose
if you file an IFR fight plan through DUATS with "VFR" as the
requested altitude it WILL go to ATC
Will it also go to FSS (to be used for SAR?)
Jose
The price of freedom is... well... freedom.
Old May 27th 05, 11:01 AM
Steven P. McNicoll
"Jose" wrote in message
No.
Old May 25th 05, 12:39 PM
Dan Luke
"Steven P. McNicoll" wrote:
Forget about the remarks, just use "VFR" as the requested altitude.
Interesting tip, Steven.
I just tried this and the Cirrus interface software refused it,
demanding an integer for the altitude. However, DUATS accepted it when
I used the direct, interactve connection.
I plan to file this again for a real trip this weekend to see how the
TRACON reacts. I suspect it's something they rarely, if ever, see.
Dan
C172RG at BFM
Old May 25th 05, 04:24 PM
Dave Butler
I've had the clearance delivery guy here at RDU swear there couldn't possibly be
a strip for me if I'm VFR... followed by "oh, here it is...".
DGB
Old May 25th 05, 11:05 PM
Steven P. McNicoll
"Dan Luke" wrote in message
It won't work everywhere, some ARTCCs inhibit the processing of VFR flight
plans like this to TRACONs they host. Chicago ARTCC is one, I don't know
how many others there are.
Old May 25th 05, 12:42 PM
Matt Whiting
Steven P. McNicoll wrote:
"Roy Smith" wrote in message
By the same token, I've never understood why the FAA doesn't make it
easier to get flight following. You should be able to pre-file your
VFR flight plan with DUATS so ATC already has a strip on you at
initial call-up, just like with IFR. Then you wouldn't have to waste
so much time on the frequency with where you're going, aircraft type,
etc.
plan and putting "VFR" in the remarks section, but you shouldn't have
to resort to subterfuge like that for what seems like such a simple
and logical thing.
Is this an "official" FAA procedure or just something that most
controllers understand as an indication that FF will be requested?
Matt
Old May 25th 05, 12:54 PM
Ron Natalie
I've never seen it published, but it is known to work. Oakland
actually encourages it for VFR class B transitions. It's how
ADIZ and FRZ flight plans get routed in the DC Area as well (although
you are not authorized to use that ploy to get ADIZ flight plans
for VFRs).
Old May 25th 05, 11:08 PM
Steven P. McNicoll
"Matt Whiting" wrote in message
Depends what you mean by "official", I suppose. I've never seen anything in
print about filing it through DUATS as I explained here, I just tried it one
day and it worked. The entry of VFR flight data into the NAS computer is
certainly "official", the procedure is described in the flight data
processing manual.
Old May 25th 05, 11:11 PM
Matt Whiting
processing manual.
I meant official in the sense that it was documented somewhere such that
most knowledgeable controllers would know what it mean when they saw it,
or that the computers would handle it properly. Sounds like the answer
is basically, yes.
Matt
Parachute fails to save SR-22 Capt.Doug Piloting 72 February 10th 05 05:14 AM
Procedure Turn Bravo8500 Instrument Flight Rules 65 April 22nd 04 03:27 AM
Normal EGT - Very Low CHT markjen Owning 7 March 4th 04 01:54 PM
Unusual Procedure at DFW Toks Desalu Piloting 9 December 17th 03 05:27 PM
Instrument Approaches and procedure turns.... Cecil E. Chapman Instrument Flight Rules 58 September 18th 03 10:40 PM
Copyright Š2004-2025 AviationBanter.
