Corky Scott wrote:
Well I do, I was an auto mechanic with gas started being laced with alcohol, and saw the results several times. Oh, I saw the results. What I meant was that I do not remember what it was in those hoses and such that was affected by exposure to alcohol. One of my friends was a line mechanic for an Oldmobile dealer. His stories were similar to yours. I happened to own a Ford during that period, and my only problems involved hoses in the fuel system. Our other car was an Opel, but it would only run on Amoco high test, so we never had an alcohol-related problem with it. George Patterson Why do men's hearts beat faster, knees get weak, throats become dry, and they think irrationally when a woman wears leather clothing? Because she smells like a new truck. |
On model airplanes using methanol based fuel, they use silicone fuel
tubing. With gas engines you use tygon or neoprene tubing. The alcohol will make those tubings harden and crack withen a few weeks. But not the swelling and turning to liquid. That has to be from a more active solvent such as toulene or acetone. |
Sport Pilot wrote:
On model airplanes using methanol based fuel, they use silicone fuel tubing. With gas engines you use tygon or neoprene tubing. The alcohol will make those tubings harden and crack withen a few weeks. But not the swelling and turning to liquid. That has to be from a more active solvent such as toulene or acetone. Not so. I never used any additives in my cars, and I had problems with softening and swelling of the hoses in the fuel system of my van. Besides, the gas in Georgia and Tennessee (where I lived at the time) was cut with ethanol, not methanol. This was a very definite, well-documented problem at the time, and no amount of theory based argument is going to change that fact. George Patterson Why do men's hearts beat faster, knees get weak, throats become dry, and they think irrationally when a woman wears leather clothing? Because she smells like a new truck. |
In article 6E0oe.883$qE2.219@trndny09,
George Patterson wrote: Corky Scott wrote: Well I do, I was an auto mechanic with gas started being laced with alcohol, and saw the results several times. Oh, I saw the results. What I meant was that I do not remember what it was in those hoses and such that was affected by exposure to alcohol. One of my friends was a line mechanic for an Oldmobile dealer. His stories were similar to yours. I happened to own a Ford during that period, and my only problems involved hoses in the fuel system. Our other car was an Opel, but it would only run on Amoco high test, so we never had an alcohol-related problem with it. George Patterson Why do men's hearts beat faster, knees get weak, throats become dry, and they think irrationally when a woman wears leather clothing? Because she smells like a new truck. I have a book, "Aviation Fuels and their Effecton Engine Performance," dated 1953, by the Ethyl Corp. and supplied to the USAF (P.O. AF-33(600)5312) and USN (Contract no. 52-202). In it they state that hoses subjected to petroleum-based fuels will deteriorate when exposed to paraffins or napthalene-based fuels; likewise, hoses that have been subjected to paraffin or napthalene-based fuels will deteriorate when exposed to petroleum-based fuels. IOW, the hoses work well with either kind of fuel, but you will get into trouble when you switch fuels. This phenomenon is exactly what happened to autos when MTBE became widespread. -- Remove _'s from email address to talk to me. |
![]() "Casey Wilson" N2310D @ gmail.com wrote Additionally, I found more than one company (B.F. Goodrich, for one example) that manufactures elastomeric products specifically for use with alcohol(s). Right, but airplanes, with their "slow to change" mentality, do not use exclusively alcohol resistant seals and hoses. -- Jim in NC |
What does gasahol do to the
fuel system that is destructive? Nobody has hard data. All fuel system tests have been with pure alcohol in a lab beaker. Sort of like feeding rats 100% saccharin and then noting an early rat demise. For that matter, what damage does it do to the engine? None. As a matter of fact, it cleans the hell out of the upper end. 1) You will only get 95% of the engine's output power compared to pure gasoline, Yes, at 100% ethanol. What is the output power degradation at 5% ethanol concentration? 0.05% or something like that. 2) Your fuel system elastomeric seals, diaphrams, floats etc are not compatible with any substantial alcohol content, Your source for the study and verifiable results, please? 3) The vapor pressure of the alcohol-laced fuel is higher, Your source for the study and verifiable results, please? 4) The long term storage properties are horrible. Certainly you must be kidding. I've got a bottle of Everclear that must be 30 years old and still has the same effect as the day I opened the bottle. Alcohol has a MUCH better storage characteristic than gasoline. Did I miss any? Most all of them. Jim |
I agree it does no damage to the mechanical and valve portions of the
engine. According to Marks Engr Handbook, the heating value of an equal mass of 10% ethanol gasahol is 96.1% of an equal mass of gasoline (I used Hexane as an approximation to gasoline & assumed ethanol). Here in MN the car mileage reduction is generally assumed to be about 5%. I see that in the differences between Wisconsin gasoline vs Minnesota gasahol in my vehicles. Since the fuel mass flow in an aircraft carb isn't likely to change significantly, and since the engine is a heat engine, with all other things being equal, a power reduction is to be expected. Other items such as compression ratio, timing, mixture proportions etc could be varied to optimize the use of gasahol, but the heat value just isn't there. Who knows what the seals etc used in an aircraft are - except that there are a lot of legal reasons that they are not being updated in contrast to technical reasons why they should be updated. Actually a simple aircraft engine has few seals as you know, and if the float (let's see we're back to metal again aren't we) don't sink, and the tip of the needle doesn't dissolve, we are back to mostly static seals in the fuel selector etc. I don't know about fuel cell bladders, except that given the regulatory climate, there is a good chance they have not been updated for 50 years either. I just had the seals go and the idle jet varnish over in my '87 Yamaha M/C carb, and lawn mowers here routinely need carb work. Vapor pressure is primarily determined by fuel temperature, although a standard temperature is used for the Reid vapor pressure test. But that standard temp has to be held very closely to make equivalent fuel evaluations. In practical service the significance of the temperature variation seems to never be addressed. For example, where is it written that you can't paint your wings black? A chem prof once noted that the vapor pressure typically doubles every 15 deg F. I have to agree that only in a most marginal situation (probably aggravated by the need for a fuel pump) might ethanol (b.p. = 172 deg F) or especially methanol (b.p. = 148 deg F) put you over the edge into trouble. My original response was hearsay. The long term storage issue - the weed whip (manual) I just bought says to throw away all ethanol laced gasoline after 60 days. I agree booze keeps a lot better but that is primarily an alcohol/water & flavor mix which does not seem to be subject to deterioration (maybe shrinkage?) of alcohol hydroicarbon mixes. Old sour gas is a problem here in MN. It seems to be aggravated by higher fuel storage temperatures. My small-engine repairman neighbor confirms this (as well as the rampant carb problems). |
You would have more power from ethanol if you richen up the mixture.
But I doubt less than 5% ethanol is enough to matter either way. |
Yes - I would think a richer mixture would be necessary to
theoretically get to the 96.1% power level with gasahol. That the mixture has already been optimized for gasoline would make me expect an even greater power reduction for gasahol. Actually, there are many things that affect the mixture distribution more in an engine that the improvement of a mixture shift would be pretty insignificant. The accuracy of the mixture control and distribution in smaller and older aircraft is pretty mediocre by any modern EFI standard. |
No, if you richen up the mixture the gasahol will actually give more
horsepower and better climb, performance etc. But with more fuel consumption. Alcohol has oxygen in the fuel. Although it has less BTU per pound or gallon, if you richen it up to the highest RPM it will be much richer than gasoline, and more BTU per hour. |
Garmin GPS196 Update v.4 - obstacles? | [email protected] | Piloting | 13 | March 16th 05 06:05 PM |
GPS_LOG WinCE update (version 1.2.2.1) | Henryk Birecki | Soaring | 0 | January 14th 05 05:27 PM |
AD: December 2004 update for London Control now available | ShelleyM | Simulators | 0 | December 15th 04 01:12 PM |
Anyone know how to update an old Loran database? | Tom Jackson | Owning | 12 | December 5th 03 06:03 PM |
Anyone know how to update an old Loran database? | Tom Jackson | Piloting | 6 | December 3rd 03 02:15 AM |
