Procedure turn required?
Old June 10th 05, 04:00 PM
Roy Smith
As a matter of definition a feeder route is not a segment of an IAP (but if it
looks like a duck, walks like a duck, and quacks like a duck...).
I think the looks like a duck comment is exactly right. If I were a
terpster, I would worry about that stuff. As a pilot, all I need to
worry about is where I'm going next and how low I can be while I'm
going there. If somebody else wants to split hairs about what to call
the segment I'm on, it's no skin off my teeth.
Old June 10th 05, 04:11 PM
In 1967 when TERPs replaced the former IAP criteria from 1956 (and before) one of
the principles was that the procedures would be simple to understand and fly so
that pilots could safety and with "simplicity" remain within the airspace designed
by the procedures folks.
When you look at some of the missed approach procedures, though, you have to
wonder.
Old June 10th 05, 04:52 PM
Steven P. McNicoll
wrote in message ...
if it looks like a duck, walks like a duck, and quacks like a duck...).
As a
matter of regulation, it is a component of an IAP, which is by procedure
design
an evaluated and designed segment, just like the four set forth in the
definition.
What regulation?
Further, you can find it on any Part 97-issued Form 8260 -3 or -5 that has
a feeder route and you can find it in TERPs Paragraph 220:
220. FEEDER ROUTES. When the IAF is part of the enroute structure there
may be no need to designate additional routes for aircraft to proceed to
the IAF.
In some cases, however, it is necessary to designate feeder routes from
enroute structure to the IAF. Only those feeder routes which provide an
operational advantage shall be established and published. These should
coincide with the local air traffic flow. The length of the feeder route
shall not
exceed the operational service volume of the facilities which provide
navigational guidance unless additional frequency protection is provided.
Enroute airway obstacle clearance criteria shall apply to feeder routes.
The minimum altitude established on feeder routes shall not be less than
altitude established at the IAF.
Based on that it appears to be more closely related to enroute airways than
IAPs.
Old June 10th 05, 07:53 PM
As a
design
definition.
What regulation?
FAR 97.2X, the "X" varying with the type of IAP that is issued under Part 97.
the IAF.
shall not
IAPs.
A feeder route is, indeed, constructed to airway criteria, except the descent
gradient limitations have to be calculated in accordance with initial approach
segment criteria. Further, in non-DMAs there is absolutely no difference in any
aspect of a feeder route or initial approach segment for ground-based IAPs.
Also, airways are issued under Part 95 and feeder routes are issued under Part
97.
Sports class tasking [email protected] Soaring 12 April 25th 05 01:32 PM
Agent86's List of Misconceptions of FAA Procedures Zero for 15 Putz!!! copertopkiller Military Aviation 11 April 20th 04 02:17 AM
Instrument Approaches and procedure turns.... Cecil E. Chapman Instrument Flight Rules 58 September 18th 03 10:40 PM
