Procedure turn required?
Old June 6th 05, 08:35 PM
John Clonts
You are skipping over the part of the regulation which states that the
"point at which the turn may be commenced" is up to the pilot.
No, I'm not skipping that at all. I'm simply pointing out that if the pilot
is permitted to degenerate the entire thing down to just the reversal
itself, how is it that logic doesn't also show that the pilot can degenerate
the entire thing down to the final turn to the final approach course?
After all, ALL of the elements of the "reversal" are at the pilot's
discretion. A 90 degree left turn is "the same" as a 270 degree right turn.
If a 270 degree right turn is allowed, then a 90 degree left turn is too.
The difference between the 90 degree left turn and all of the
variations of the procedure turn (even with a zero-length outbound leg)
is that all those variations have you *established* on the final
approach course *prior* to reaching the FAF. In this sense the 90
degree left turn is not equal to the 270 right turn.
To me this seems the conceptual basis for the fact that the regs
require the procedure turn when it often doesn't "seem" that it should
be necessary.
Now if you happen to be coming from a direction where you *are* already
aligned on the final approach course and at the proper altitude prior
to reaching the FAF, I would agree that it doesn't make sense to do the
PT (though it may still be technically required by the regs). The
basis *I* use for skipping the turn in this case is: 1) I am flying a
hold-in-lieu-of-procedure turn, plus 2) I am established in the hold by
virtue of being established (+/- 10 degrees) on the inbound course
prior to reaching the holding point (the FAF). Ok, its a stretch, but
that's how I look at it!
Cheers,
John Clonts
Temple, Texas
Old June 7th 05, 10:41 PM
Ron Rosenfeld
On Mon, 6 Jun 2005 10:40:11 -0700, "Peter Duniho"
"Ron Rosenfeld" wrote in message
I don't understand what you are trying to say. I don't see it as
degeneration to be following the clearly stated rule that it is pilots
choice for the type of turn and where to start it.
Again, I don't see any similarity (assuming we are talking about the same
approach as started this thread) between a 90° left turn at Seal Beach and
a 270° right turn. So I would disagree with your conclusion that they are
the same.
There is no MINIMUM length of an outbound leg.
And no specific direction of the turn.
That's right; after turning outbound, you can go clockwise or counter
clockwise.
There is only a maximum length.
Depending on where you start the turn, correct.
You can begin your turn (or course reversal if you will), immediately.
And the type of turn is entirely at the pilot's discretion. So rather than
flying a 270 degree right turn, the pilot can choose a 90 degree left turn.
But if you do not see that, then further discussion here is pointless.
Ahh, yes...the old "terminate the thread with an ad hominem" tactic.
Sorry, I did not mean a personal attack. My statement stems from a
realization that nothing I write here is going to convince you that there
is no requirement to return to and fly over the depicted outbound track of
a procedure turn (unless it's one of those fly as charted types); and
nothing you write will convince me that there is such a requirement.
There is certainly nothing wrong with returning to the outbound course
after Seal Beach, flying outbound for some length that you determine you
want to; and then executing a 45° turn on the charted side, so long as you
remain within the mileage limit. But it is not the only valid, legal
method of executing the procedure.
I never said it was.
Well, you seem to be insisting that it is required to fly along the charted
outbound course for some length of time.
Procedure turn required? Yossarian Piloting 85 July 6th 05 08:12 PM
Sports class tasking [email protected] Soaring 12 April 25th 05 01:32 PM
Agent86's List of Misconceptions of FAA Procedures Zero for 15 Putz!!! copertopkiller Military Aviation 11 April 20th 04 02:17 AM
