Andrew Gideon wrote:
Matt Barrow wrote: Think about breaking out at the MAP...you've got 0.2 seconds to make your decision. Perhaps I'm misinterpreting what you've written, but how is this different than a 'real' precision approach? - Andrew I believe he is saying that dive and drive gets you broken out sooner, since you are down at the minimum altitude considerably befor the map. |
![]() Doug wrote: A pilot can use either technique. Depending on the pilot, the aircraft, and the approach, there are positives and negatives to using dive and drive vs. stabilized constant descent technique. The accidents stats don't support any positives for dive-and-drive. One thing you frequently hear is that you could IMMEDIATELY descend (helicopter) to the next altitude once you pass the waypoint. NOT true. There is a maximum decent allowed. I don't know what it is, and it is quite steep, but it's not vertical. What is the number? Why express any uncertainty? With one exception you have full obstacle clearance at the earlist point at which a fix can be received (i.e., considering adverse fix error). The exception is in the non-precision final approach segment where a 7:1 gradient may, or may not, be applied to the FAF and/or some stepdown fix in the final approach segment. A pilot has no way of determing from the approach chart whether this design option has been applied (TERPs, Paragraph 289). |
![]() wrote in message ... Doug wrote: A pilot can use either technique. Depending on the pilot, the aircraft, and the approach, there are positives and negatives to using dive and drive vs. stabilized constant descent technique. The accidents stats don't support any positives for dive-and-drive. Cite? |
![]() Matt Barrow wrote: wrote in message ... Doug wrote: A pilot can use either technique. Depending on the pilot, the aircraft, and the approach, there are positives and negatives to using dive and drive vs. stabilized constant descent technique. The accidents stats don't support any positives for dive-and-drive. Cite? How can I cite the negative? There are many, many NPA crashes over the years. |
![]() "Paul Lynch" wrote in message news:K9spe.10456$%Z2.3221@lakeread08... Stable approaches for the heavy metal???? Stable approaches work for all aircraft on non-precision approaches. Wanna re-read my original post. Indeed they do, but the intent was the turbine traffic, not 172's. Maybe someone explained them to you poorly or incorrectly. Stable means a constant descent rate that puts you at MDA shortly before the MAP. I know what they mean. Dive and drive is frowned on by the FAA because of the multiple accidents nor near mishaps or altitude busts that occur. Do you have a cite for that? INHMB "Matt Barrow" wrote in message ... "Roy Smith" wrote in message ... One of the cool things about WAAS is the ability to fly a synthetic glideslope on a non-precision approach. I'd much rather follow a needle smoothly down to MDA than dive-and-drive through a couple of stepdowns, even if the MDA is still the same 500 AGL or whatever. Problem with a smooth descent is that when you arrive at the sectors MDA, you have immediately start down again rather than taking a few moments to sift things out. Stable approaches were build for the heavy metal/turbine crowd. http://www.avweb.com/news/columns/182091-1.html Pelican's Perch #24: Sloppy, Sorry VNAV Flying a non-precision approach has traditionally been a "Dive and Drive" affair in which the pilot descends rapidly to the MDA or step-down altitude and then levels off. Recently, however, pilots of aircraft equipped with glass cockpit FMS systems or VNAV-capable GPS receivers have been encouraged to fly such approaches using a constant descent path. There's even a buzzword for this: CANPA (constant-angle non-precision approach), and these calculated pseudo-glideslopes are now starting to show up on Jeppesen approach plates. AVweb's John Deakin thinks this is a bad idea, one that will result in a lot more missed approaches and perhaps even some accidents. Deakin explains why, and makes a compelling case for flying non-precision approaches the traditional, old-fashioned way that God and Cap'n Jepp intended. ---------------------------------------------- |
![]() Matt Barrow wrote: "Paul Lynch" wrote in message news:K9spe.10456$%Z2.3221@lakeread08... Stable approaches for the heavy metal???? Stable approaches work for all aircraft on non-precision approaches. Wanna re-read my original post. Indeed they do, but the intent was the turbine traffic, not 172's. The intent was certainly directed to turbine airplanes, but the concept was recommended for all airplane operations. As to Deakin's views on the matter, other folks with similar expertise disagree quite strongly with him. He is a smart fellow, but when it comes to dive-and-drive, it's simply his opinion, which is no better than anyone else's that works with that stuff. In fact, Deakin never participated in any Industry/FAA meetings or discussions about constant angle/constant rate NPAs. |
![]() wrote in message ... Matt Barrow wrote: "Paul Lynch" wrote in message news:K9spe.10456$%Z2.3221@lakeread08... Stable approaches for the heavy metal???? Stable approaches work for all aircraft on non-precision approaches. Wanna re-read my original post. Indeed they do, but the intent was the turbine traffic, not 172's. The intent was certainly directed to turbine airplanes, but the concept was recommended for all airplane operations. We hear all sorts of recommendations that are nothing short of ludicrious. As to Deakin's views on the matter, other folks with similar expertise disagree quite strongly with him. Yeah, the experts at TCM and Lycoming disagree, too. He is a smart fellow, but when it comes to dive-and-drive, it's simply his opinion, which is no better than anyone else's that works with that stuff. An opinions worth is based on the evidence and logic from which it is based. Other than that, your remark is nothing but post-modernist bull****. In fact, Deakin never participated in any Industry/FAA meetings or discussions about constant angle/constant rate NPAs. So what? Did you? If not, STFU :~) |
![]() Matt Barrow wrote: wrote in message ... Matt Barrow wrote: "Paul Lynch" wrote in message news:K9spe.10456$%Z2.3221@lakeread08... Stable approaches for the heavy metal???? Stable approaches work for all aircraft on non-precision approaches. Wanna re-read my original post. Indeed they do, but the intent was the turbine traffic, not 172's. The intent was certainly directed to turbine airplanes, but the concept was recommended for all airplane operations. We hear all sorts of recommendations that are nothing short of ludicrious. As to Deakin's views on the matter, other folks with similar expertise disagree quite strongly with him. Yeah, the experts at TCM and Lycoming disagree, too. He is a smart fellow, but when it comes to dive-and-drive, it's simply his opinion, which is no better than anyone else's that works with that stuff. An opinions worth is based on the evidence and logic from which it is based. Other than that, your remark is nothing but post-modernist bull****. In fact, Deakin never participated in any Industry/FAA meetings or discussions about constant angle/constant rate NPAs. So what? Did you? If not, STFU :~) I was at most of those meetings. |
But does this feature work as enhancements to existing SDF/LOC approaches?
I don't think so. We'll have to wait years, if ever, for these LPV approaches to come to our area. My $0.02, {|;-) Victor J. (Jim) Osborne, Jr. VOsborne2 at charter dot net "Roy Smith" wrote in message ... Marco Leon mmleon(at)yahoo.com wrote: It sucks but realistically, how many airports have LPV approaches without an ILS somewhere? Then compare that list to what you will realistically fly; then pare it down to to chances of requiring the 250ft DH to break out of the ceiling. I'd think anyone would come up with a very short list of pilots this would impact. One of the cool things about WAAS is the ability to fly a synthetic glideslope on a non-precision approach. I'd much rather follow a needle smoothly down to MDA than dive-and-drive through a couple of stepdowns, even if the MDA is still the same 500 AGL or whatever. |
Victor J. Osborne, Jr. wrote:
But does this feature work as enhancements to existing SDF/LOC approaches? My reading of the advertising-speak is that it can build a descent profile for any approach. I've some question about that (ie. what if the straight line from FAF to VDP passes under a stepdown), but I don't know that I've interpreted the advertising-speak accurately. - Andrew |
Any inside story re 430/530 WAAS cert.? | [email protected] | Instrument Flight Rules | 0 | May 20th 05 06:13 PM |
WAAS and Garmin 430/530 | DoodyButch | Owning | 23 | October 13th 03 04:06 AM |
Terminology of New WAAS, VNAV, LPV approach types | Tarver Engineering | Instrument Flight Rules | 2 | August 5th 03 03:50 AM |
WAAS | Big John | Piloting | 8 | July 22nd 03 01:06 PM |
Garmin Behind the Curve on WAAS GPS VNAV Approaches | Richard Kaplan | Instrument Flight Rules | 24 | July 18th 03 01:43 PM |
