TRSA and /X
Old June 11th 05, 03:17 AM
Ron Natalie
Peter Duniho wrote:
"Ron Natalie" wrote in message
m...
The predate ARSA's. TRSA's existed when there were only TCA's nad the
FAA hadn't invented ARSA's.
They both predate, and are left-over from, the relevant time periods.
I don't know what above means, but the original statement is still
correct. TRSA's existed long before ARSA's were "invented."
TRSA's are NOT controlled airspace in themselves. Just wannabe radar
service zones.
I don't understand your statement. I've never heard of a TRSA existing in
Class G airspace. All of the ones I've seen have been in Class E airspace,
which certainly is controlled airspace.
But they are not controlled airspace in themselves. It's entirely
analogous to the old airport traffic areas. They were NOT controlled
airspace. A TRSA is just a bunch of lines on the chart that says
"radar services available here."
You are welcome to that opinion. I happen to disagree. It provides a
higher level of service than that offered by most towers in Class D
airspace, and a lower level of service than that offered by radar facilities
in Class C airspace.
It provides different service. A TRSA provides radar service when
class D does not (generally, although there's almost always a class D
tower in the middle of a TRSA). However some class D's provide
radar services without being TRSA's. TRSA's have the side effect of
not necessarily having all the aircraft within it participate, which
makes it inferior to class D and C.
It is a region within Class E airspace where a slightly different type of
radar service is offered from that normally found in Class E airspace. I
would be amazed if there was a TRSA outside of controlled airspace.
It's not always class E.
I certainly don't disagree with your last sentence. That doesn't mean a
TRSA isn't in controlled airspace though.
It's NOT controlled airspace. There are 5 kinds of controlled airspace
in the US: A, B, C, D, and E. They do not overlap. A TRSA may overlap
controlled airspace, but it's jut another concept like a RESTRICTED AREA
etc...
Old June 11th 05, 07:43 AM
Peter Duniho
I never said they were. You are correcting a statement that was never made.
So I said.
So I said. My statement "It provides a higher level of service than that
offered by most towers in Class D airspace" implies just that, and was
intended to.
"Inferior" is in the eye of the beholder. Class D airspace without radar
provides NO separation services. A TRSA provides better separation services
than any non-radar Class D.
It's always within controlled airspace, and the only exception to the Class
E is when it intersects with Class D. None of that contradicts what I wrote
earlier.
Again (since you seem to be having a hard time comprehending this): I never
said it was.
Pete
Old June 11th 05, 02:44 PM
Steven P. McNicoll
intended to.
That statement does not imply that some Class D's provide radar services
That's not correct, separation is provided between IFR aircraft in Class D
airspace.
Class E is when it intersects with Class D. None of that contradicts what
I wrote earlier.
Earlier you said it was only Class E.
Old June 12th 05, 02:02 AM
Jessica Taylor
So I said.
intended to.
Doesn't class D airspace provide separation adjacent to the runway to
prevent collisions?
earlier.
said it was.
Pete
Old June 12th 05, 04:55 PM
Steven P. McNicoll
"Jessica Taylor" wrote in message
news
prevent collisions?
All towers provide runway separation, that has nothing to do with airspace
classification.
Old June 11th 05, 02:41 PM
Steven P. McNicoll
Do you know of a TRSA which does not have Class D airspace in the middle?
But all of the aircraft in the Class D portion of the TRSA are
participating, just as they are in Class C and other Class D airspace.
Old June 11th 05, 04:22 PM
Jose
Do you know that such a beast is impossible, even if it doesn't exist now?
Jose
The price of freedom is... well... freedom.
Old June 11th 05, 04:48 PM
Steven P. McNicoll
"Jose" wrote in message
m...
No. Why do you ask?
Old June 11th 05, 05:40 PM
Jose
No. Why do you ask?
I ask because your question:
in response to Ron's parenthetical comment
...although there's almost always a class D
implies that
1: there isn't any TRSA without a D, and more to the point
2: Ron should know this, Stephen does, nyah nyah nyah.
You phrase it as a snipe, which comes off as if you are being smug and
superior. Even if you were asking a neutral question because you were
curious, your posting history makes it easy to interpret as a snipe, and
snipes get tiresome, especially when the fine point they are based on
is incorrect or misleading.
Ron's remark ("almost always") remains true even if there are =no= cases
of Dless TRSAs. It implies that there =might= be, but not that there
=are=. So as a snipe at Ron, it misses.
But now I am curious as to your implication that they are impossible.
(Were they actually impossible, Ron's "almost" would be unnecessary,
though not incorrect). Your snipe implies that you know so and want to
belittle him who doesn't, by not telling and instead asking
rhetorically. (If you didn't know, a more pleasant neutral question
would definately be in order.)
Given the earlier discussion about the independence between towers and
class D airspace, I'm curious as to whether these things are in fact
independent, or (as you appeared to imply) not.
And yes, I phrased it as a snipe myself. Sauce for the goose and all.
Jose
Old June 11th 05, 10:29 PM
Peter R.
Yes, I do. The Utica TRSA in central NY, home of Griffiss Approach, at one
time had Griffiss Air Force B-52 airbase as its main airport in the middle
of the airspace. When the Air Force closed the airbase several years ago,
the airport became an uncontrolled airport (with a single 11,800 foot
runway).
However, the TRSA remains, presumably, for Oneida Cty airport. If you look
at the sectional you will note that this class D airport is south of the
"middle" of the TRSA, properly satisfying the criteria of your question.
Peter
----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups
----= East and West-Coast Server Farms - Total Privacy via Encryption =----
R in a Circle (Airport Surveillance Radar) on VFR charts Jeff Saylor Piloting 66 May 12th 04 04:05 PM
UTICA TRSA shape Jeff Saylor Piloting 4 May 10th 04 05:54 AM
