DA40. The spot was probably used by a cessna 172 before. The diamond's wing
span is about 3ft more than the skyhawk. Then again, it's a low-winger. The ropes are not entirely short, just too short to make an additional safely knot... Thanks for the tip about open hooks. -- CD "BTIZ" wrote in message news:XL2ue.17222$iG5.7282@fed1read05... Diamond?? as in DA-20 or DA-40 and the ropes don't reach? what was tied down there before? If you use "straps" with "hooks" do not use open hooks to tie down an aircraft, the hooks should close with a safety keeper. Depending on winds and what ever the other end of the strap is anchored to, cable, ring in concrete etc, the wing can flex, bounce what ever, and the hook can pop off it's attach point and then you will have a "Diamond in the Rough". BT "City Dweller" wrote in message oups.com... Hi all, When trying to tie down my new Diamond at our airport, I discovered that the ropes on my parking spot are too short and I can't even make two decent knots. I remember seeing an interesting tie-down device the other day, something like a hand-operated winch which allows you to tie-up the cable without having to tie any knots. Does anyone know what it's called, and where I can get it? Thanks in advance. -- C. Dweller |
roger on the "span" thing.. our local airports use cables, and then the
chains or ropes used can slide along the cable to the proper span.. not have to be splayed out at an angle.. I did get a chance to fly a new DA-40-180 with the G1000 Nav suite... sweet.. I may change FBOs this fall and fly them instead.. same price for as the Arrow with old crap BT "City Dweller" wrote in message ... DA40. The spot was probably used by a cessna 172 before. The diamond's wing span is about 3ft more than the skyhawk. Then again, it's a low-winger. The ropes are not entirely short, just too short to make an additional safely knot... Thanks for the tip about open hooks. -- CD "BTIZ" wrote in message news:XL2ue.17222$iG5.7282@fed1read05... Diamond?? as in DA-20 or DA-40 and the ropes don't reach? what was tied down there before? If you use "straps" with "hooks" do not use open hooks to tie down an aircraft, the hooks should close with a safety keeper. Depending on winds and what ever the other end of the strap is anchored to, cable, ring in concrete etc, the wing can flex, bounce what ever, and the hook can pop off it's attach point and then you will have a "Diamond in the Rough". BT "City Dweller" wrote in message oups.com... Hi all, When trying to tie down my new Diamond at our airport, I discovered that the ropes on my parking spot are too short and I can't even make two decent knots. I remember seeing an interesting tie-down device the other day, something like a hand-operated winch which allows you to tie-up the cable without having to tie any knots. Does anyone know what it's called, and where I can get it? Thanks in advance. -- C. Dweller |
I had my plane tied out at an airport that didn't have any ropes on the tie
downs. I used a set of the ratcheting tie downs that I picked up in Sam's Club. They worked great and held well when the hurricanes passed over the Carolinas last year. I never had a problem with them as I just threw them in the car or baggage compartment when I left. Make sure you buy a set that's heavy enough. Mine were each rated at the weight of the plane. "City Dweller" wrote in message oups.com... Hi all, When trying to tie down my new Diamond at our airport, I discovered that the ropes on my parking spot are too short and I can't even make two decent knots. I remember seeing an interesting tie-down device the other day, something like a hand-operated winch which allows you to tie-up the cable without having to tie any knots. Does anyone know what it's called, and where I can get it? Thanks in advance. -- C. Dweller |
Aerotow with Diesel engine? | Olfert Cleveringa | Soaring | 44 | November 2nd 04 10:22 AM |
Winch Physics | Bob Johnson | Soaring | 15 | March 27th 04 07:33 PM |
Winch design | c1rrus | Soaring | 10 | January 19th 04 12:18 PM |
Coalition casualties for October | Michael Petukhov | Military Aviation | 16 | November 4th 03 11:14 PM |
using winch instead of aerotow | goneill | Soaring | 5 | August 27th 03 02:46 PM |
