Let me add two links to the discussion:
This is on problems with cold weather altimetry: http://www.aircraftbuyer.com/learn/train06.htm This is about the accuracy of unaided GPS altitude in the context of vertical guidance, but it bears some relavence to the discussion of the accuracy of GPS altitude: http://www.bluecoat.org/reports/Graham_2001_RawGPS.pdf John Bell www.cockpitgps.com |
"John Bell" writes:
Let me add two links to the discussion: This is on problems with cold weather altimetry: http://www.aircraftbuyer.com/learn/train06.htm This is about the accuracy of unaided GPS altitude in the context of vertical guidance, but it bears some relavence to the discussion of the accuracy of GPS altitude: http://www.bluecoat.org/reports/Graham_2001_RawGPS.pdf Thanks -- those are good articles. The Nav Canada paper on non-WAAS GPS VNAV (the Graham paper) is especially interesting. All the best, David |
I would say that we are exceedingly fortunate in having Nav Canada as an
information source to supplement (complement?) the FAA. Bob Gardner "David Megginson" wrote in message ... "John Bell" writes: Let me add two links to the discussion: This is on problems with cold weather altimetry: http://www.aircraftbuyer.com/learn/train06.htm This is about the accuracy of unaided GPS altitude in the context of vertical guidance, but it bears some relavence to the discussion of the accuracy of GPS altitude: http://www.bluecoat.org/reports/Graham_2001_RawGPS.pdf Thanks -- those are good articles. The Nav Canada paper on non-WAAS GPS VNAV (the Graham paper) is especially interesting. All the best, David |
John Bell wrote:
Let me add two links to the discussion: This is on problems with cold weather altimetry: http://www.aircraftbuyer.com/learn/train06.htm This is about the accuracy of unaided GPS altitude in the context of vertical guidance, but it bears some relavence to the discussion of the accuracy of GPS altitude: http://www.bluecoat.org/reports/Graham_2001_RawGPS.pdf John Bell www.cockpitgps.com This one's for the Canadians on this thread. A notice on the new Oakland, California (KOAK) "RNAV (GPS) RWY 29" approach (http://www.myairplane.com/databases/.../OAK_agr29.pdf): "BARO-VNAV NA below -15 deg C (5 deg F)" And this is for a decision altitude of only 294 ft AGL. Seems like the FAA is moving towards taking into account temperature errors in barometric alitmetry. And, by implication, this supports the premise that WAAS altitude figures are more accurate than the trusty old "sensitive altimeter." (In the legend they specifically state that WAAS-based VNAV can be used when BARO-VNAV is not approved due to temperature.) |
"Fred E. Pate" writes:
And this is for a decision altitude of only 294 ft AGL. Seems like the FAA is moving towards taking into account temperature errors in barometric alitmetry. Thanks -- that's an interesting note. And, by implication, this supports the premise that WAAS altitude figures are more accurate than the trusty old "sensitive altimeter." (In the legend they specifically state that WAAS-based VNAV can be used when BARO-VNAV is not approved due to temperature.) The altimeter becomes increasingly accurate near the ground (assuming you have the correct altimeter setting) and increasingly inaccurate away from the ground; WAAS, I'll guess, has about the same accuracy all the way down (or up). I don't know at what point they typically cross over, but it would vary depending on the temperature gradiant. All the best, David |
I've never lived in Oakland, but I thought it was exceedingly rare for =
the temperature there to dip below -15C. ---JRC--- "Fred E. Pate" wrote in message = ... =20 This one's for the Canadians on this thread. A notice on the new=20 Oakland, California (KOAK) "RNAV (GPS) RWY 29" approach=20 = (http://www.myairplane.com/databases/.../OAK_agr29.pdf): =20 "BARO-VNAV NA below -15 deg C (5 deg F)" =20 And this is for a decision altitude of only 294 ft AGL. Seems like = the=20 FAA is moving towards taking into account temperature errors in=20 barometric alitmetry. And, by implication, this supports the premise=20 that WAAS altitude figures are more accurate than the trusty old=20 "sensitive altimeter." (In the legend they specifically state that=20 WAAS-based VNAV can be used when BARO-VNAV is not approved due to=20 temperature.) |
On Mon, 29 Sep 2003 00:16:00 -0700, "Fred E. Pate"
wrote: John Bell wrote: Let me add two links to the discussion: This is on problems with cold weather altimetry: http://www.aircraftbuyer.com/learn/train06.htm This is about the accuracy of unaided GPS altitude in the context of vertical guidance, but it bears some relavence to the discussion of the accuracy of GPS altitude: http://www.bluecoat.org/reports/Graham_2001_RawGPS.pdf John Bell www.cockpitgps.com This one's for the Canadians on this thread. A notice on the new Oakland, California (KOAK) "RNAV (GPS) RWY 29" approach (http://www.myairplane.com/databases/.../OAK_agr29.pdf): "BARO-VNAV NA below -15 deg C (5 deg F)" And this is for a decision altitude of only 294 ft AGL. Seems like the FAA is moving towards taking into account temperature errors in barometric alitmetry. And, by implication, this supports the premise that WAAS altitude figures are more accurate than the trusty old "sensitive altimeter." (In the legend they specifically state that WAAS-based VNAV can be used when BARO-VNAV is not approved due to temperature.) It seems a bit strange... .. DH on the ILS at MBS is only 200 feet AGL and that is with no temperature correction. In the winter we regularly see below zero F and it's not rare to see it at minus 20 at night OTOH with those temperatures we either have severe clear, or blowing snow. It's rather uncommon to see clouds near the ground when it's that cold here in the flat lands. That and you can be "on top" of a raging blizzard at 4,000. Roger Halstead (K8RI EN73 & ARRL Life Member) www.rogerhalstead.com N833R World's oldest Debonair? (S# CD-2) |
Roger Halstead writes:
OTOH with those temperatures we either have severe clear, or blowing snow. It's rather uncommon to see clouds near the ground when it's that cold here in the flat lands. Maybe it's just not cold enough. Once you get past -30 degC or so, you can get a dense freezing mist (like smoke) rising off any open water, like a lake or wide river -- the parts that are frozen over start to make a creepy, moaning sound. I agree that truly cold temperatures ( -20 degC) tend to mean VMC, at least where I live -- it's one of the fantastic things about winter flying (clear skies, excellent visibility, good climb performance, minimal turbulence, high ground visibility at night, and early sunsets that make it easy to stay night-current). The downsides are having to plug in the engine heater overnight and dealing with the @#$%#@ wing covers. All the best, David |
On Mon, 29 Sep 2003 17:17:49 GMT, David Megginson
wrote: Roger Halstead writes: OTOH with those temperatures we either have severe clear, or blowing snow. It's rather uncommon to see clouds near the ground when it's that cold here in the flat lands. Maybe it's just not cold enough. Once you get past -30 degC or so, you can get a dense freezing mist (like smoke) rising off any open water, like a lake or wide river -- the parts that are frozen over start to make a creepy, moaning sound. I agree that truly cold temperatures ( -20 degC) tend to mean VMC, at least where I live -- it's one of the fantastic things about winter flying (clear skies, excellent visibility, good climb performance, minimal turbulence, high ground visibility at night, and early sunsets that make it easy to stay night-current). The downsides are having to plug in the engine heater overnight and dealing with the @#$%#@ wing I have a couple layers of the new blankets sewn together to fit around the entire front of the plane from mid windshield forward around the engine compartment and underneath where it completely covers the nose gear doors, and around the front to wrap the first quarter of the prop. The back of the spinner is even warm. Problem is...the Deb doesn't warm up till I'm at cruise, or duri8ng a long climb to altitude. You can actually stay comfortable in heavy slacks and a long sleeve shirt, but that is *after* climb out. :-)) Getting the Cub Cadet with snow blower out, cleaning the ramp and maybe even part of the taxiway does not make the inside of the plane feel any warmersigh It's kinda like working in an unfinished house in the winter. Man, but it gets cold in there. I've flown from Michigan to Gainsville Ga (LGM) without seeing a cloud. Then again, I've flown from the middle of Tennessee and not seen the ground till some where around Jackson Michigan. Unlike the summer storms, you can fly over a blizzard at some where between 3000 and 5000 AGL. The winter storms seldom get very high. But I have been sitting "up there" and after hearing some of the conversations on UNICOM thinking it'd be real nice to have one more fan. That was when I realized it's a good idea to not only have a way out, but have a way down when single engine. If it's really cold you don't have to worry about ice in the clouds either, but since then I make it a point to try to stay near the edges of those big storms when there is no safe way down. covers. Roger Halstead (K8RI EN73 & ARRL Life Member) www.rogerhalstead.com N833R World's oldest Debonair? (S# CD-2) All the best, David |
Roger Halstead wrote:
It seems a bit strange... . DH on the ILS at MBS is only 200 feet AGL and that is with no temperature correction. In the winter we regularly see below zero F and it's not rare to see it at minus 20 at night Yup, but temperature doesn't effect the glideslope, just where you put the MAP along that glideslope. On the so-called "Baro-VNAV" approaches, the glideslope is defined using barometric altimeter data, so the entire glideslope will be shallower and closer to the ground on a cold day. And if there is a low-level temperature inversion the glideslope won't even be a straight line. |
| Thread Tools | |
| Display Modes | |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| Terminology of New WAAS, VNAV, LPV approach types | Tarver Engineering | Instrument Flight Rules | 2 | August 5th 03 04:50 AM |
| Big News -- WAAS GPS is Operational for IFR | Lockheed employee | Instrument Flight Rules | 87 | July 30th 03 03:08 AM |
| Garmin Behind the Curve on WAAS GPS VNAV Approaches | Richard Kaplan | Instrument Flight Rules | 24 | July 18th 03 02:43 PM |
| High Altitude operations (Turbo charge???) | Andre | Home Built | 68 | July 12th 03 12:59 AM |
