GO480
Old June 23rd 05, 01:26 PM
Ron Natalie
Jim Burns wrote:
Mike,
Just a few questions and thoughts, mainly because I'm curious.
I'd be interested to know the HP rating of the GO480 installed in the Helio.
I've been watching a few people that are building Bearhawks and one article
mentions that the GO480 isn't favored for that application for the relative
high weight to HP ratio compared to the 540.
The QueenAir uses supercharged 480's. The unblown engines run about 295HP
I believe.
There's no free lunch. While the gohpers get more HP out of less cubic
inches, the weight doesn't really go down because of the weight of the
gear box. The CG does go forward a bit though.
Old June 22nd 05, 04:36 AM
Jim Burns
If you look at the cylinder bases you can tell if it is a wide or narrow
deck.
Narrow deck engines use interior hex nuts and possibly hold down plates to
hold the cylinder to the case. Wide deck engines have studs, regular hex
nuts, and thicker cylinder flanges holding the cylinders to the case.
Wide deck engines serial numbers end in "A", narrow deck engines serial
numbers do not.
Narrow deck engines are typically older, mid-60's and earlier.
I believe that
http://www.lycoming.textron.com/supp...ns/SI1037M.pdf
shows your cylinder Assembly number to contain an "r" indicating angle
valves (not parallel) and an "e" indicating needing long reach spark plugs.
"Mike Rapoport" wrote in message
ink.net...
When I read about Lycoming engines the terms "wide deck", "narrow deck",
"straight valve" and angle valve are used to describe different
cylinder/case configurations. What is the GO480 in my Helio Courier?
Narrow deck? Wide deck? Angle valve? Straight valve?
Thanks
Mike
MU-2
Old June 22nd 05, 04:44 PM
Orval Fairbairn
deck.
numbers do not.
I believe that
http://www.lycoming.textron.com/supp...Publications/s
erviceInstructions/SI1037M.pdf
ink.net...
Parallel-valve Lycomings have rocker covers that have parallel sides; on
angle-valve Lycomings, the sides of the rocker covers angle toward an
apex somewhere above the cylinder.
I lost a friend last year when his GO-480 threw a rod in his Pilatus
P-3. He hit a tree attempting to make an emergency landing.
Remove _'s from email address to talk to me.
Old June 22nd 05, 03:00 PM
Mike Rapoport
Thanks Jim! I will have a look today.
Mike
MU-2
"Jim Burns" wrote in message
deck.
numbers do not.
I believe that
plugs.
ink.net...
Thanks
Mike
MU-2
