I think it's misleading to say that modern aircraft "must be 'helped'
into the spin". There are some circumstances when a spin entry can be made without any "odd" control inputs at all. One of my favourite exercises for my annual checkouts as a UK Basic Instructor is the spin off a simulated winch launch (only try this at height with an appropriate instructor with you!). Simulate a winch launch by diving to 90 kt and then pulling up at 45 degrees. As the speed drops to about 60 kt cry "BANG - cable break", and push over into the normal flying attitude. The moment normal attitude is reached, begin a co-ordinated turn. All will be fine for a second or so, as you are flying at reduced G. However, once the G comes back on many gliders will roll smoothly (no buffeting) into a spin so fast that there is little you can do about it (though the purpose of the exercise is to show the spin entry and then a recovery, so I've not tried reducing back pressure as the wing drops). The Puchacz is excellent for this. My understanding is that although everything looks fine, in fact you are flying below 1G stall speed (possible because of the reduced G resulting from the pushover, which is why BGA training requires you to push over beyond the normal attitude after a cable break, monitor the airspeed and not turn until a safe speed is regained). When 1G is restored the wings stall, but because you're already in a turn the down wing stalls earlier and autorotation ensues. If you think about it, an aggressive pull up into a thermal coupled with turning a little later than normal might produce similar effects. I believe there are a number of other modes of spin entry without unusual control movements, though you would need a far more experienced pilot than me to explain them. This is not to say that a glider in normal flight will depart into a spin without abuse of the controls, but I think it important to recognise that co-ordinated flight is not an *absolute* protection and to understand when extra precautions are required (and what those precautions are). wrote: Most important is recognition of prestall and initial departure. Since the spin is a product of yaw moment at departure, you can prevent a spin with coordinated controls alone. IE, modern aircraft must be "helped" into the spin. (Put another way, the vertical stabilizer creates enough yaw dampening to prevent autorotaion at stall so long no pro spin control imputs are made. Since there are two yaw controls, that would mean pro rudder or anti stick.) Thus, any prestall or initial departure that is met with a release of back pressure and use of coordinated controls to level the wings will produce the desired effect before a spin or spiral dive can develop. Even if you choose not to release back pressure, you shouldn't spin. Instead, you might find yourself in a secondary stall. The longer it takes to apply these simple actions, the less likely that it will produce an immediate remedy, as the aircraft will continue into either a spin or spiral dive. |
Interesting set of circumstances. I'll try it, before I comment at
length. However, I will not recover to see if it really is a spin. I suspect I'll see it become a spiral dive based on previous flight testing in this regime. But experimentation will tell. By the way, I do this often, though not in quite the order you state or for the same reason. I enjoy pointing the nose up 60 degrees or so, then letting it park. The stall and pitch through is typically well past vertical. Great fun, and completely self recovering after the stall break. And much, much more exciting than a wing over. Chris Reed wrote: I think it's misleading to say that modern aircraft "must be 'helped' into the spin". There are some circumstances when a spin entry can be made without any "odd" control inputs at all. One of my favourite exercises for my annual checkouts as a UK Basic Instructor is the spin off a simulated winch launch (only try this at height with an appropriate instructor with you!). Simulate a winch launch by diving to 90 kt and then pulling up at 45 degrees. As the speed drops to about 60 kt cry "BANG - cable break", and push over into the normal flying attitude. The moment normal attitude is reached, begin a co-ordinated turn. All will be fine for a second or so, as you are flying at reduced G. However, once the G comes back on many gliders will roll smoothly (no buffeting) into a spin so fast that there is little you can do about it (though the purpose of the exercise is to show the spin entry and then a recovery, so I've not tried reducing back pressure as the wing drops). The Puchacz is excellent for this. My understanding is that although everything looks fine, in fact you are flying below 1G stall speed (possible because of the reduced G resulting from the pushover, which is why BGA training requires you to push over beyond the normal attitude after a cable break, monitor the airspeed and not turn until a safe speed is regained). When 1G is restored the wings stall, but because you're already in a turn the down wing stalls earlier and autorotation ensues. If you think about it, an aggressive pull up into a thermal coupled with turning a little later than normal might produce similar effects. I believe there are a number of other modes of spin entry without unusual control movements, though you would need a far more experienced pilot than me to explain them. This is not to say that a glider in normal flight will depart into a spin without abuse of the controls, but I think it important to recognise that co-ordinated flight is not an *absolute* protection and to understand when extra precautions are required (and what those precautions are). wrote: Most important is recognition of prestall and initial departure. Since the spin is a product of yaw moment at departure, you can prevent a spin with coordinated controls alone. IE, modern aircraft must be "helped" into the spin. (Put another way, the vertical stabilizer creates enough yaw dampening to prevent autorotaion at stall so long no pro spin control imputs are made. Since there are two yaw controls, that would mean pro rudder or anti stick.) Thus, any prestall or initial departure that is met with a release of back pressure and use of coordinated controls to level the wings will produce the desired effect before a spin or spiral dive can develop. Even if you choose not to release back pressure, you shouldn't spin. Instead, you might find yourself in a secondary stall. The longer it takes to apply these simple actions, the less likely that it will produce an immediate remedy, as the aircraft will continue into either a spin or spiral dive. |
A little consideration before I go try this in the air. First, it is
possible to stall a glider while coordinated. No epiphany there. If you stall in a bank, you are likely to have the low wing drop, for the reasons Chris gave. This, however, should not result in a spin. UNLESS... given the variables Chris has introduced, we have a glider that is potentially flying well below its 1G stall speed. This means that the force available to the vertical stabilizer to dampen a yawing motion is significantly diminished. So then is the power of the rudder. Adverse yaw of the ailerons is increased at the stall. Harmonization (ie, required pilot control inputs to maintain coordinated flight) changes as the horizontal stab is now operating at less than design speeds. Interesting. There would seem to be a crossover in this regime, where even if the contols are harmonized (given the relative torques available to VS and ailerons), there simply may not be enough weathervaning potential in the VS to prevent autorotation if a stall develops at the wingtip. Is it safe to say that winch launching is an aerobatic maneuver, and therefore requires very specific training techniques since the glider is likely to be flown outside its design limits? Also, it seems the key to avoiding this situation is to avoid the stall, which means no sudden snatching back of the stick (even to neutral) once a "normal" attitude is achieved. Since this situation is likely to occur near the ground, where the horizon is not a particularly useful airspeed indicator, do you teach close monitoring of airspeed throughout the recovery? And a complicating factor... if there is already a bank during the recovery, how do you address it? You've noted that AOA differential is enough to snap the glider into a spin. Attempting to level the wings would seem to only aggrevate any impending tip stall. I'm not unfamiliar with this regime. Though I typically don't turn at the top of a hard pull into a thermal (I generally start the turn during the pull, if I'm going to turn at all), I do on occasion decide that I've misjudged the thermal's size and its worth a turn. However, the glider's roll is typically so slow, I find myself moving the stick well forward (and sometimes dumping flaps) to increase the roll rate... a normal reaction to sluggish controls near the stall. So again, I'm wondering that the pilot isn't introducing an aggrevating factor (misuse of the elevator), though admittedly, I hadn't considered this narrow flight band when addressing the first, best recovery to an unaticipated loss of control. Chris Reed wrote: I think it's misleading to say that modern aircraft "must be 'helped' into the spin". There are some circumstances when a spin entry can be made without any "odd" control inputs at all. One of my favourite exercises for my annual checkouts as a UK Basic Instructor is the spin off a simulated winch launch (only try this at height with an appropriate instructor with you!). Simulate a winch launch by diving to 90 kt and then pulling up at 45 degrees. As the speed drops to about 60 kt cry "BANG - cable break", and push over into the normal flying attitude. The moment normal attitude is reached, begin a co-ordinated turn. All will be fine for a second or so, as you are flying at reduced G. However, once the G comes back on many gliders will roll smoothly (no buffeting) into a spin so fast that there is little you can do about it (though the purpose of the exercise is to show the spin entry and then a recovery, so I've not tried reducing back pressure as the wing drops). The Puchacz is excellent for this. My understanding is that although everything looks fine, in fact you are flying below 1G stall speed (possible because of the reduced G resulting from the pushover, which is why BGA training requires you to push over beyond the normal attitude after a cable break, monitor the airspeed and not turn until a safe speed is regained). When 1G is restored the wings stall, but because you're already in a turn the down wing stalls earlier and autorotation ensues. If you think about it, an aggressive pull up into a thermal coupled with turning a little later than normal might produce similar effects. I believe there are a number of other modes of spin entry without unusual control movements, though you would need a far more experienced pilot than me to explain them. This is not to say that a glider in normal flight will depart into a spin without abuse of the controls, but I think it important to recognise that co-ordinated flight is not an *absolute* protection and to understand when extra precautions are required (and what those precautions are). wrote: Most important is recognition of prestall and initial departure. Since the spin is a product of yaw moment at departure, you can prevent a spin with coordinated controls alone. IE, modern aircraft must be "helped" into the spin. (Put another way, the vertical stabilizer creates enough yaw dampening to prevent autorotaion at stall so long no pro spin control imputs are made. Since there are two yaw controls, that would mean pro rudder or anti stick.) Thus, any prestall or initial departure that is met with a release of back pressure and use of coordinated controls to level the wings will produce the desired effect before a spin or spiral dive can develop. Even if you choose not to release back pressure, you shouldn't spin. Instead, you might find yourself in a secondary stall. The longer it takes to apply these simple actions, the less likely that it will produce an immediate remedy, as the aircraft will continue into either a spin or spiral dive. |
![]() wrote in message ups.com... Is it safe to say that winch launching is an aerobatic maneuver, and therefore requires very specific training techniques since the glider is likely to be flown outside its design limits? Absolutely not true. Winch launch and the associated maneuvers are well within the design limits of any modern glider. Winch launch is not an aerobatic maneuver. Chris Reed wrote: One of my favourite exercises for my annual checkouts as a UK Basic Instructor is the spin off a simulated winch launch (only try this at height with an appropriate instructor with you!). Simulate a winch launch by diving to 90 kt and then pulling up at 45 degrees. As the speed drops to about 60 kt cry "BANG - cable break", and push over into the normal flying attitude. The moment normal attitude is reached, begin a co-ordinated turn. One of my favorites too but it needs to be understood that, in Chris Reed's example, the glider is at a very high AOA and deeply stalled, or will be as soon as 1G is re-established. The ASI will only be indicating 10 - 15 knots. Initiating a turn while in a deep stall will cause a wing drop and a spin entry - no surprise here. This 'feels' normal only because of the normal glide attitude. It is a variant of an accelerated stall. This maneuver is for instructors so they can anticipate the results if a student botches a wire break recovery. I've sometimes used it with student to demonstrate WHY the nose needs to be well down and the airspeed seen to be above best L/D and increasing before initiating a turn. In all cases, this practice maneuver is done at a safe altitude. To further explain, if a wire break occurs during the nose high part of a winch launch, it's very likely that the best landing option is straight ahead. When the glider is high enough that a turn is needed, the nose attitude will be lower and the height AGL will be much greater. Bill Daniels |
![]() Chris Reed wrote: One of my favourite exercises for my annual checkouts as a UK Basic Instructor is the spin off a simulated winch launch (only try this at height with an appropriate instructor with you!). Simulate a winch launch by diving to 90 kt and then pulling up at 45 degrees. As the speed drops to about 60 kt cry "BANG - cable break", and push over into the normal flying attitude. The moment normal attitude is reached, begin a co-ordinated turn. I've recently been doing this as a student and personally I found it a very valuable lesson as (a) it required no "forcing" from the instructor to initiate the spin and (b) it makes you realise how quickly you can transition from an apparently normal flying attitude into a serious situation. Chris Gadsby |
Bill,
In fact, at least according to US regs, a winch launch IS an aerobatic manuever. But that wasn't my point. If normal recovery from a normal operation places the pilot on the ragged edge of a deep stall, then I think it best to characterize the operation as "ab"normal., requiring reactions unique to that environment. And thus my toying with the term aerobatic. There remains a problem with this argument, however. Maybe the subject of a different thread. BTW, have you demonstrated this maneuver without revocery? IE, have you left the controls in place to let the spin fully develop? |
bush rules! | Be Kind | Military Aviation | 53 | February 14th 04 04:26 PM |
AmeriFlight Crash | C J Campbell | Piloting | 5 | December 1st 03 02:13 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
