Take whatever steps you think necessary. I will say this. In 2200 hours
of flying all over the US, Canada and Alaska, I've never seen fuel contamination with water nor have I had debris in my fuel filter. The only problem I've ever had is the fueler NOT topping it off completely, which if you are counting on flying close to your max range with full tanks can be bad news. There are lots of accidents where pilots run out of fuel. Do everything you can not to do that. Take whatever steps you think is necessary. I try and watch the fueler or fill the tanks myself. I check the gas caps (never had anyone put them on wrong though). |
The odds of someone filling your O2 tanks with air instead of O2 is
just as deadly and just as likley to happen as someone putting Drain-O on your sandwitch instead of mustard at a Subway restraunt. Well, maybe not as likley, but you get the idea. Some things in life you just have to risk. Thats not to say fuel sumps need not be checked, or simple inspections shouldn't be made, but there exists a line which seperates reasonable precautions and insanity. |
![]() "buttman" wrote in message ps.com... The odds of someone filling your O2 tanks with air instead of O2 is just as deadly and just as likley to happen as someone putting Drain-O on your sandwitch instead of mustard at a Subway restraunt. Well, maybe not as likley, but you get the idea. Some things in life you just have to risk. Thats not to say fuel sumps need not be checked, or simple inspections shouldn't be made, but there exists a line which seperates reasonable precautions and insanity. I'm aware of a story similar to what the original poster mentioned regarding filling an 02 tank with regular compressed air. It was a C-337 on a photography mission. The passenger (who was in the back, ready to shoot photos) passed out at ~20k ft, and the pilot lost consciousness somewhat higher. The airplane departed from controlled flight, and came apart on the way down. The wings, tail, etc. came down miles from the fuselage. The fuselage came down in a tree, killing the pilot. When the fire department came to pull the body out of the aircraft, the passenger woke up and climbed down the ladder with the firemen with minor injuries. True story. I have met the NTSB guy who was the lead investigator. He indicated that the FBO had been filling O2 tanks with regular compressed air for a lengthy time. They had to notify the FBO's recent O2 customers on an emergency basis to let them know that their oxygen tanks needed to be purged and re-filled. A very interesting tale which goes to show that there are many, many ways to die quickly in an airplane. Some of them unforseen. KB |
An Instructor once told me that it takes 5 minutes per inch of fuel in the
tank for all the water (if any) to show up in the sumps. Don't know where he got that from, but I thought I'd pass it on. |
In rec.aviation.ifr lardsoup wrote:
An Instructor once told me that it takes 5 minutes per inch of fuel in the tank for all the water (if any) to show up in the sumps. Don't know where he got that from, but I thought I'd pass it on. CRC Chemistry. I believe the settling rate of water in 100LL is 1" per minute. Figure your tanks are 9" deep... check after 9 minutes. Adjust for the depth of your tanks. Best regards, Jer/ "Flight instruction and mountain flying are my vocation!" Eberhard -- Jer/ (Slash) Eberhard, Mountain Flying Aviation, LTD, Ft Collins, CO CELL 970 231-6325 EMAIL jer'at'frii.com WEB http://users.frii.com/jer/ C-206 N9513G, CFII Airplane&Glider, FAA-DEN Aviation Safety Counselor CAP-CO Mission&Aircraft CheckPilot, BM218 HAM N0FZD, 228 Young Eagles! |
Actually, it will take a lot longer for all the water to settle to the
bottom. Tiny droplets of water setlle at an extremely slow rate, and even a small agitation will disturb them back into the fuel. The basic idea of the sump drain is not just to remove water, but to indicate that there is a problem with the fuel. Once you detect water in the sumps, it's going to take a lot longer than 5 minutes to get going. "lardsoup" wrote in : An Instructor once told me that it takes 5 minutes per inch of fuel in the tank for all the water (if any) to show up in the sumps. Don't know where he got that from, but I thought I'd pass it on. |
![]() You can't check all possible scenarios, but water and jet fuel are heavier than 100LL, and will sink to the bottom of the tank. It should show up in the sump drain, so there is no excuse for overlooking it. I suppose a contamination ligher than 100LL may not show up until later. You are correct that low probability does not mean impossible. However, we can't live life that way. There is a finite probability that you will win the lottery, but you can plan your life around that. Greg Farris wrote in news:dadpi3$23o4$2 @biggoron.nerim.net: This is purely theoretical - it is not something I am planning for next Saturday : If you are to fly over an expanse of water or other inhospitible terrain, for a distance long enough to require re-fueling immediately prior (US-Europe ferry, for example) - You watch to see that they put the right fuel in your plane, but you can really only see what's stenciled on the side of the truck, not what's inside (call me paranoid - what if the line guy is someone I owe money to). How long do you have to fly before a fuel contamination problem manifests itself? Does this depend on how empty your tanks were? I'm guessing no - I'm guessing this type of problem - any serious fuel contamination problem - would show up within minutes. Anyone really know this. Anyone here learn this the hard way? I've also noted, though far less certain, a number of vacuum or AI failures take place within the first minutes of flight, not to mention engines throwing rods etc. You can see what I'm getting at - how useful a survival instinct would it be to fly, say 20 minutes, up the Icelandic coast, then double back before setting out across the great void? (Obviously you've already taken the other measures, and you are wearing your survival gear etc). Another question : I read an official accident report (not a newspaper report) in which ground personnel refilled a small plane's oxygen tanks with compressed air before a mountain crossing. The pilot died in the ensuing accident, but miraculously the single passenger survived to confirm the oxygen-related unconciousness of the pilot as the cause of the crash. What could this pilot have done to defend against this "rare but not impossible" event? We assume that in aviation - unlike on the road - we may kill ourselves by our own mistakes, but the likliehood of being killed by the mistakes of others is very far removed. This is certainly justified, however very far removed does not mean impossible, and our preventive measures should try to preclude suce events if we can. G Faris |
Regarding your AirVenture trip...
email me: eroodatrrohio.com (make the appropriate substitutions) |
