I never fully trust the snap type torque wrenches & would put more
faith in the bending beam type (which one do you call cheap & uncalibrated?). Unless the snap type is calibrated before use, there could be quite a bit of error in it. The beam type only has to return to zero after each use. Anyone else have similar or different thoughts on this? The world seems to have gone to snap types. |
On 8 Jul 2005 12:36:56 -0700, "nrp" wrote:
I never fully trust the snap type torque wrenches & would put more faith in the bending beam type (which one do you call cheap & uncalibrated?). Unless the snap type is calibrated before use, there could be quite a bit of error in it. The beam type only has to return to zero after each use. Anyone else have similar or different thoughts on this? The world seems to have gone to snap types. I've got a guaranteed 4% accurate $napOn clicker that comes through cal within the 4%, but needs tweaked about every other year. Don't do much of it anymore, but have got a Mac Tool$ bender ($10 at a garage sale) that gets cal'ed every year (heh) that gets used for cylinder bases & other mission critical stuff. Like you said, if a bender reads O, it's extremely likely to be OK. Cheap clickers tend to crunch instead of click, but have one in the shop that gets sent every 12 months and gets tweaked about every three years (that would be LESS often than my $napOn) Toughest thing to do with a properly cal'ed clicker is not pull it through the click & over-torque a little. TC |
Jimmy B. wrote:
What do you all do? Torque to the specification, or just 1 turn? Torque to specs. I also use the Dow lubricant on the gasket instead of engine oil. What is your opinion? Lycoming says to change the oil in the O-320 series every 4 months or 50 hours of operation, whichever comes first. IIRC, Continental said 4 months or 25 hours with the O-200 with a screen. The recommendation for a 3 or 4 month change period is pretty widespread. I'd be looking for another mechanic. George Patterson Why do men's hearts beat faster, knees get weak, throats become dry, and they think irrationally when a woman wears leather clothing? Because she smells like a new truck. |
George Patterson wrote:
Jimmy B. wrote: What do you all do? Torque to the specification, or just 1 turn? Torque to specs. I also use the Dow lubricant on the gasket instead of engine oil. What is your opinion? Lycoming says to change the oil in the O-320 series every 4 months or 50 hours of operation, whichever comes first. IIRC, Continental said 4 months or 25 hours with the O-200 with a screen. The recommendation for a 3 or 4 month change period is pretty widespread. I'd be looking for another mechanic. The more I deal with this mechanic, the less I like him. For example, I have a Precise Flight standby vacuum system, and the indicator light is out. When I told him about it, his response was that not everything has to work. I told him that without the light, I would not know that my vacuum pump has failed until I got high enough in altitude that the Precise Flight system could not produce enough vacuum and by then, I could be in or above IMC. He just shrugged and walked away. For planned maintenance, it is easy to go to another shop, but he's the only mechanic on the field and I do want to stay on good terms with him just in case I need something done and the plane is unflyable. I would like to find a free-lance mechanic that could come to my field to do work. George Patterson Why do men's hearts beat faster, knees get weak, throats become dry, and they think irrationally when a woman wears leather clothing? Because she smells like a new truck. |
Tell him to fix it. If he won't find another mechanic who will. Don't
tell him you are taking it to another mechanic. It's none of his business. Don't **** him off, just do what you have to do to maintain the airplane. The light should work. I think, ideally, EVERYTHING in my plane should work. But it is UP TO YOU. Don't let a mechanic, or me, dictate the maintenance of YOUR airplane. It is your property, you are in charge of it. |
Jimmy B. wrote:
For planned maintenance, it is easy to go to another shop, but he's the only mechanic on the field and I do want to stay on good terms with him just in case I need something done and the plane is unflyable. I would like to find a free-lance mechanic that could come to my field to do work. Yeah, that would be nice, but it looks like you're stuck with this guy for now. Here's what I would do in your shoes. Don't ask this guy any questions if you can help it. When something needs to be fixed, ask him to fix it, and try to do it in such a way that he won't feel comfortable arguing. I once had to deal with a mechanic who had similar ideas to your man (mine would never have recommended postponing oil changes, however). Pete's problem was that he dealt with cheapskate pilots so much that he just assumed that everybody would want to take shortcuts. Once I had a bad plug wire and he recommended replacing just the bad one. When I told him to put in a new set of plug wires instead, he did what I asked. After I explained that all the wires were the same age and I didn't want to be bringing the plane back in every few months to replace another one, he understood. After that, we could discuss alternatives for each job of work. Sounds like that approach isn't working for you, though. George Patterson Why do men's hearts beat faster, knees get weak, throats become dry, and they think irrationally when a woman wears leather clothing? Because she smells like a new truck. |
If you have any oil contamination factors such as using primarily 100LL
fuels, a lot of engine blowby, and are not able to control the operation for minimum contamination, I agree the oil should be changed fairly often. But I have a 1700 hr TTSN O-320E2D in a 172M that now only flys about 30 hrs/year. I change oil (and always filter too) only every year since the oil stays unusually clean. It takes nearly 20 hours before it even loses its green and gets coffee colored. At change I've randomly checked the oil analysis and it always comes back normal. The oil was Mobil straight grade during its initial 700 hours and has been Shell 20W50 for the last 1000 hrs. We are based in a low contamination area (Minnesota and Wisconsin), and burn 80 Octane or autofuel to minimize lead contamination. When we were flying it more, we changed oil only every 50 hours. Consumption remains 1 qt every 30 hrs. The engine remains quite cold blooded on CHT and oil temp. I climb at higher airspeeds, cruise it leaned and with lower power settings, avoid 100LL, am careful to purge the combustion products on shutdown, always preheat but don't continuosly heat during the winter, & watch the baffling and engine external cleanliness. Interestingly it never has had particularily good compression numbers, but always has had excellent "bounce" |
!!! WARNING -- AOPA credit card holders. The credit card company is trying to change the rules in mid-game. Read the statement sent to you by MBNA. | Chuck | Owning | 22 | May 23rd 05 12:37 AM |
How do you explain why the A/S increases on thermal entry? | Fred | Soaring | 43 | April 24th 05 02:33 PM |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | December 2nd 04 07:00 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
