If you take off at 45 lbs. over gross in a 172 and are forced to immediately
return to the ground, assuming you don't change anything, such as draining fuel or restarting the engine for some period, you will be over gross for an infinite period. But since nobody ever has to turn back, and no one ever lands "hard" in an emergency, there's really nothing to worry about, is there? "Dave Stadt" wrote in message m... "Jose" wrote in message m... As a practical matter, if being 45 pounds over gross makes the difference between somebody going or being left behind, I can tell you that you'll be as popular as a turd in the punchbowl if you leave that person behind. Leave some gas behind and alter your flight plan if necessary. If your limit is 45 over gross, how far over your limit is ok? If you take off 45 lbs. over in a 172 in how many minutes will you be at gross? Jose -- Nothing takes longer than a shortcut. for Email, make the obvious change in the address. |
If you take off 45 lbs. over in a 172 in how many minutes will you be at gross? Sixty or so, assuming you stay in the air. Which has nothing to do with my question. Jose -- Nothing takes longer than a shortcut. for Email, make the obvious change in the address. |
And just what do you do with that 7 1/2 gallons of gas? Especially if
you are not at you home field. And have you ever tried draining several gallons of fuel out of an airplane? I know it is done but it typically is not that easy especially at a remote location. And after draining 7 1/2 gallons our of a Champ I only have 4 1/2 gallons left. Brian |
you are not at you home field. I suppose it depends how it got there. And have you ever tried draining several gallons of fuel out of an airplane? Yes. For precisely those reasons. And after draining 7 1/2 gallons our of a Champ I only have 4 1/2 gallons left. Then it would be a short flight. ![]() Jose -- Nothing takes longer than a shortcut. for Email, make the obvious change in the address. |
Mortimer Schnerd, RN wrote:
Jose wrote: How much is too much over gross weight? For example.....the 172 has a gross weight of 2300 lbs, but what if you are 2345 at time of takeoff.....is that too much over My answer is that anything over book is too much. It nibbles away at flight regimes that you might need, and discover too late that you are in. As a practical matter, if being 45 pounds over gross makes the difference between somebody going or being left behind, I can tell you that you'll be as popular as a turd in the punchbowl if you leave that person behind. As a former part 135 charter and cargo pilot, I can also tell you that you wouldn't hold on to your job for long if you hold on to your principles so tightly. Some leeway is expected, as nobody operates in the perfect world except the FAA... and apparently, you. Is that why you are a former charter and cargo pilot? :-) Matt |
Matt Whiting wrote:
As a former part 135 charter and cargo pilot, I can also tell you that you wouldn't hold on to your job for long if you hold on to your principles so tightly. Some leeway is expected, as nobody operates in the perfect world except the FAA... and apparently, you. Is that why you are a former charter and cargo pilot? :-) Not even close. Nursing pays much better and the jobs are waiting for me in any town I chose to visit. My last flying position ended in a pilot's meeting on a Thursday telling us that the bank had taken our aircraft and it's been nice knowing us. On Saturday I picked up a newspaper telling me that a new nursing school had just been approved by the State Board and that they were taking applications. I was on the phone to them on Monday. The rest is history. -- Mortimer Schnerd, RN VE |
Matt Whiting wrote: As a former part 135 charter and cargo pilot, I can also tell you that you wouldn't hold on to your job for long if you hold on to your principles so tightly. Some leeway is expected, as nobody operates in the perfect world except the FAA... and apparently, you. Is that why you are a former charter and cargo pilot? :-) Not even close. Nursing pays much better and the jobs are waiting for me in any town I chose to visit. My last flying position ended in a pilot's meeting on a Thursday telling us that the bank had taken our aircraft and it's been nice knowing us. On Saturday I picked up a newspaper telling me that a new nursing school had just been approved by the State Board and that they were taking applications. I was on the phone to them on Monday. The rest is history. Yes, I pretty much figured this was the case ... hence the smiley! Matt |
Addressing this as an intellectual problem, "it depends". With CG in
the middle of its range, smooth air, low density altitude, aircraft and engine in excellent condition, a long runway, and a pilot capable of flying and landing smoothly, I'd guess most light planes would easily handle 10% over certificated weight. Long range ferry pilots often take off overloaded, and I understand it's also common practice in Alaska, where many of the above conditions do not exist. Interesting to see how many people get fired up about this. When you fly, you have to use your brain for all aspects of the flight, not just quote the rules. |
![]() When you fly, you have to use your brain for all aspects of the flight, not just quote the rules. Amen. |
Right. I also like how you put that.
Fred "Paul kgyy" wrote in message ups.com... Addressing this as an intellectual problem, "it depends". With CG in the middle of its range, smooth air, low density altitude, aircraft and engine in excellent condition, a long runway, and a pilot capable of flying and landing smoothly, I'd guess most light planes would easily handle 10% over certificated weight. Long range ferry pilots often take off overloaded, and I understand it's also common practice in Alaska, where many of the above conditions do not exist. Interesting to see how many people get fired up about this. When you fly, you have to use your brain for all aspects of the flight, not just quote the rules. |
Max gross weight | Chris | Piloting | 21 | October 5th 04 08:22 PM |
Apache Alternate Gross Weight | Jim Burns | Owning | 1 | July 6th 04 05:15 PM |
Buying an L-2 | Robert M. Gary | Piloting | 13 | May 25th 04 04:03 AM |
F35 cost goes up. | Pat Carpenter | Military Aviation | 116 | April 11th 04 07:32 PM |
Empty/Gross weight Vs. Max. Pilot weight | Flyhighdave | Soaring | 13 | January 14th 04 04:20 AM |
