Gross Weight
Old July 8th 05, 09:59 PM
Fred Choate
LOL!
Fred
"Jose" wrote in message
Exactly what we were discussing at work.....
I guess maybe it might relate to how many drinks can I have in a
specified period before driving home.....
Actually, I've found alcohol to be quite useful in aviation. In
situations where I'd be over gross, I have a few six-packs of beer. If
the pilot is already flying, then his weight can be subtracted from the
manifest, allowing more cargo, or more fuel. By getting the passengers
suitably high also, I can reclaim almost all the payload that way. So
then, after the passengers have boarded the airplane, I calculate how much
extra fuel each one represents, and have the FBO fill up one of those big
fifty gallon drums full and we load it into the cargo compartment... you
know, the one in the back that says "200 pounds max". Well, ok 50 gallons
is 300 pounds, but if we average that over the whole airframe we're only
25 pounds over per passenger (and the bigger the passenger, the less that
25 pounds is, percent wise). And more fuel makes you safer anyway.
So then I get on the runway, open the throttle, and climb as fast as I
can. Really pull back on that yoke - the plane should climb like a bat
out of hell, since it's virtually empty.
Remember - eight bottles, then throttle.
Jose
(*) kids - don't try this at home!
Get high on gasoline. Fly an airplane.
Old July 8th 05, 09:08 PM
Mike Granby
If your limit is 45 over gross, how far over your limit is ok?
How about as far as airlines go over-weight on a daily basis as a
result of the FAA standard person not being equal to the actual load
they're dealing with? Not everyone weights 170lbs or whatever the
latest number is..........
Old July 8th 05, 10:48 PM
Dave Stadt
m...
As a practical matter, if being 45 pounds over gross makes the
difference
between somebody going or being left behind, I can tell you that you'll
be as
popular as a turd in the punchbowl if you leave that person behind.
Leave some gas behind and alter your flight plan if necessary.
If you take off 45 lbs. over in a 172 in how many minutes will you be at
gross?
Jose
Nothing takes longer than a shortcut.
Old July 8th 05, 11:42 PM
Lakeview Bill
If you take off at 45 lbs. over gross in a 172 and are forced to immediately
return to the ground, assuming you don't change anything, such as draining
fuel or restarting the engine for some period, you will be over gross for an
infinite period.
But since nobody ever has to turn back, and no one ever lands "hard" in an
emergency, there's really nothing to worry about, is there?
"Dave Stadt" wrote in message
m...
m...
difference
you'll
be as
gross?
Jose
Old July 9th 05, 06:09 AM
Jose
gross?
Sixty or so, assuming you stay in the air. Which has nothing to do with
my question.
Jose
Old July 9th 05, 12:24 AM
Brian
And just what do you do with that 7 1/2 gallons of gas? Especially if
you are not at you home field.
And have you ever tried draining several gallons of fuel out of an
airplane? I know it is done but it typically is not that easy
especially at a remote location.
And after draining 7 1/2 gallons our of a Champ I only have 4 1/2
gallons left.
Brian
Old July 9th 05, 06:10 AM
Jose
I suppose it depends how it got there.
airplane?
Yes. For precisely those reasons.
gallons left.
Then it would be a short flight.
Jose
Old July 9th 05, 10:36 AM
Mortimer Schnerd, RN
airplane?
I'm curious what you did with it, particularly if you were away from home. I
have a mental image of Cheech and Chong carrying a metal garbage can full of
purloined gas with paper and plastic trash floating at the top. G
VE
Old July 9th 05, 03:32 PM
Jose
When I was at home base, the FBO drained it into a plastic tank which I
presume they have for that very purpose, and I assume they put it into
another airplane (it's clean gas) or saved it for us later.
Other times I've changed airplanes (to one with a bigger payload) and
when I was away and was overfueled, I had the FBO drain it and I don't
know what they did with it. But the procedure appears to be common
enough that they are prepared for it.
Jose
Old July 8th 05, 11:24 PM
Matt Whiting
Mortimer Schnerd, RN wrote:
Jose wrote:
How much is too much over gross weight? For example.....the 172 has a gross
weight of 2300 lbs, but what if you are 2345 at time of takeoff.....is that
too much over
My answer is that anything over book is too much. It nibbles away at
flight regimes that you might need, and discover too late that you are in.
As a practical matter, if being 45 pounds over gross makes the difference
between somebody going or being left behind, I can tell you that you'll be as
As a former part 135 charter and cargo pilot, I can also tell you that you
wouldn't hold on to your job for long if you hold on to your principles so
tightly. Some leeway is expected, as nobody operates in the perfect world
except the FAA... and apparently, you.
Is that why you are a former charter and cargo pilot? :-)
Matt
Max gross weight Chris Piloting 21 October 5th 04 08:22 PM
Apache Alternate Gross Weight Jim Burns Owning 1 July 6th 04 05:15 PM
Buying an L-2 Robert M. Gary Piloting 13 May 25th 04 04:03 AM
F35 cost goes up. Pat Carpenter Military Aviation 116 April 11th 04 07:32 PM
Empty/Gross weight Vs. Max. Pilot weight Flyhighdave Soaring 13 January 14th 04 04:20 AM
