LOL!
Fred "Jose" wrote in message ... Exactly what we were discussing at work..... I guess maybe it might relate to how many drinks can I have in a specified period before driving home..... Actually, I've found alcohol to be quite useful in aviation. In situations where I'd be over gross, I have a few six-packs of beer. If the pilot is already flying, then his weight can be subtracted from the manifest, allowing more cargo, or more fuel. By getting the passengers suitably high also, I can reclaim almost all the payload that way. So then, after the passengers have boarded the airplane, I calculate how much extra fuel each one represents, and have the FBO fill up one of those big fifty gallon drums full and we load it into the cargo compartment... you know, the one in the back that says "200 pounds max". Well, ok 50 gallons is 300 pounds, but if we average that over the whole airframe we're only 25 pounds over per passenger (and the bigger the passenger, the less that 25 pounds is, percent wise). And more fuel makes you safer anyway. So then I get on the runway, open the throttle, and climb as fast as I can. Really pull back on that yoke - the plane should climb like a bat out of hell, since it's virtually empty. Remember - eight bottles, then throttle. ![]() Jose (*) kids - don't try this at home! -- Get high on gasoline. Fly an airplane. for Email, make the obvious change in the address. |
![]() If your limit is 45 over gross, how far over your limit is ok? How about as far as airlines go over-weight on a daily basis as a result of the FAA standard person not being equal to the actual load they're dealing with? Not everyone weights 170lbs or whatever the latest number is.......... |
![]() "Jose" wrote in message m... As a practical matter, if being 45 pounds over gross makes the difference between somebody going or being left behind, I can tell you that you'll be as popular as a turd in the punchbowl if you leave that person behind. Leave some gas behind and alter your flight plan if necessary. If your limit is 45 over gross, how far over your limit is ok? If you take off 45 lbs. over in a 172 in how many minutes will you be at gross? Jose -- Nothing takes longer than a shortcut. for Email, make the obvious change in the address. |
If you take off at 45 lbs. over gross in a 172 and are forced to immediately
return to the ground, assuming you don't change anything, such as draining fuel or restarting the engine for some period, you will be over gross for an infinite period. But since nobody ever has to turn back, and no one ever lands "hard" in an emergency, there's really nothing to worry about, is there? "Dave Stadt" wrote in message m... "Jose" wrote in message m... As a practical matter, if being 45 pounds over gross makes the difference between somebody going or being left behind, I can tell you that you'll be as popular as a turd in the punchbowl if you leave that person behind. Leave some gas behind and alter your flight plan if necessary. If your limit is 45 over gross, how far over your limit is ok? If you take off 45 lbs. over in a 172 in how many minutes will you be at gross? Jose -- Nothing takes longer than a shortcut. for Email, make the obvious change in the address. |
If you take off 45 lbs. over in a 172 in how many minutes will you be at gross? Sixty or so, assuming you stay in the air. Which has nothing to do with my question. Jose -- Nothing takes longer than a shortcut. for Email, make the obvious change in the address. |
And just what do you do with that 7 1/2 gallons of gas? Especially if
you are not at you home field. And have you ever tried draining several gallons of fuel out of an airplane? I know it is done but it typically is not that easy especially at a remote location. And after draining 7 1/2 gallons our of a Champ I only have 4 1/2 gallons left. Brian |
you are not at you home field. I suppose it depends how it got there. And have you ever tried draining several gallons of fuel out of an airplane? Yes. For precisely those reasons. And after draining 7 1/2 gallons our of a Champ I only have 4 1/2 gallons left. Then it would be a short flight. ![]() Jose -- Nothing takes longer than a shortcut. for Email, make the obvious change in the address. |
Jose wrote:
And have you ever tried draining several gallons of fuel out of an airplane? Yes. For precisely those reasons. I'm curious what you did with it, particularly if you were away from home. I have a mental image of Cheech and Chong carrying a metal garbage can full of purloined gas with paper and plastic trash floating at the top. G -- Mortimer Schnerd, RN VE |
When I was at home base, the FBO drained it into a plastic tank which I presume they have for that very purpose, and I assume they put it into another airplane (it's clean gas) or saved it for us later. Other times I've changed airplanes (to one with a bigger payload) and when I was away and was overfueled, I had the FBO drain it and I don't know what they did with it. But the procedure appears to be common enough that they are prepared for it. Jose -- Nothing takes longer than a shortcut. for Email, make the obvious change in the address. |
Max gross weight | Chris | Piloting | 21 | October 5th 04 08:22 PM |
Apache Alternate Gross Weight | Jim Burns | Owning | 1 | July 6th 04 05:15 PM |
Buying an L-2 | Robert M. Gary | Piloting | 13 | May 25th 04 04:03 AM |
F35 cost goes up. | Pat Carpenter | Military Aviation | 116 | April 11th 04 07:32 PM |
Empty/Gross weight Vs. Max. Pilot weight | Flyhighdave | Soaring | 13 | January 14th 04 04:20 AM |
